yorgle Posted November 2, 2007 Share Posted November 2, 2007 Anyone know of a source (besides ebay) for an Atari Assembler Editor cart? I know that Best Electronics has them but they have a minimum $50 order for paypal but I just want the cart and I've already bought a bunch of other Atari stuff (e.g., another 1200xl) so my budget is growing short. Quote Link to comment Share on other sites More sharing options...
nathanallan Posted November 2, 2007 Share Posted November 2, 2007 You can call them and pay them with your credit card over the phone, and there's no minimum. I've done it. Works great. Nathan Quote Link to comment Share on other sites More sharing options...
Rybags Posted November 2, 2007 Share Posted November 2, 2007 You could easily enough make a binary load version for a 48K or higher machine. I have a disk image somewhere with one. Or, burn one to EPROM and use an existing game cart. Or, best option - just get a Mac 65. Quote Link to comment Share on other sites More sharing options...
dwhyte Posted November 2, 2007 Share Posted November 2, 2007 What about the actual source code for the Atari assembler? Does that exist anywhere on the intersurf? Quote Link to comment Share on other sites More sharing options...
tjb Posted November 2, 2007 Share Posted November 2, 2007 I have to agree with Rybags, go with Mac/65. Far superior to the Assembler Editor. tjb Quote Link to comment Share on other sites More sharing options...
yorgle Posted November 2, 2007 Author Share Posted November 2, 2007 You could easily enough make a binary load version for a 48K or higher machine.I have a disk image somewhere with one. Or, burn one to EPROM and use an existing game cart. Or, best option - just get a Mac 65. I found the mac65 code somewhere but it downloaded as a .rom file. For some reason, it won't load into APE so I used makeATR to convert it to an .atr file. I then transferred it to my sio2sd but I get a BOOT ERROR when I try to load it. The same thing happens when I try to load Assembly Editor as an .atr- that's why I gave up and just want to find a cart. Quote Link to comment Share on other sites More sharing options...
Rybags Posted November 2, 2007 Share Posted November 2, 2007 (edited) There's 2 versions of MAC-65. A banked cart (which also has DDT built in) and the original binary file which was loaded into RAM on real machines. You can't use .ROM files with APE. Atari_ASM.zip There's a Zip with my Atari Assembler Editor as a binary file. ASM is the cart image which you should load from DOS as a binary load - on an XL and you can switch between BASIC and the Assembler by SHIFT-RESET, although you lose any source code by switching. Note that it uses a routine just under screen memory to allow the switching and to initialize. If you open a GRAPHICS screen which uses more RAM than GR.0, it will overwrite it. POKE 9,1 if you do this. You can load ASM2 (also a binary file) which will re-initialize without having to load the entire thing again. I have the Disk based MAC-65, but it seems that I haven't got it on the PC, only 5.25 floppy. But, it should be downloadable somewhere. Edited November 2, 2007 by Rybags Quote Link to comment Share on other sites More sharing options...
yorgle Posted November 2, 2007 Author Share Posted November 2, 2007 There's 2 versions of MAC-65. A banked cart (which also has DDT built in) and the original binary file which was loaded into RAM on real machines. You can't use .ROM files with APE. Atari_ASM.zip There's a Zip with my Atari Assembler Editor as a binary file. ASM is the cart image which you should load from DOS as a binary load - on an XL and you can switch between BASIC and the Assembler by SHIFT-RESET, although you lose any source code by switching. Note that it uses a routine just under screen memory to allow the switching and to initialize. If you open a GRAPHICS screen which uses more RAM than GR.0, it will overwrite it. POKE 9,1 if you do this. You can load ASM2 (also a binary file) which will re-initialize without having to load the entire thing again. I have the Disk based MAC-65, but it seems that I haven't got it on the PC, only 5.25 floppy. But, it should be downloadable somewhere. Thanks, I'll give that a try tonight. But if anyone has an Assembler Editor cart they'd like to part with, I'd still be interested in purchase/trade. Quote Link to comment Share on other sites More sharing options...
guus.assmann Posted November 2, 2007 Share Posted November 2, 2007 Thanks, I'll give that a try tonight. But if anyone has an Assembler Editor cart they'd like to part with, I'd still be interested in purchase/trade. You could also buy a Turbofreezer from www.abbuc.de This piece of hardware can emulate the Mac65 / Bug65 cartridge, or any Atari-cartridge. Contense is stored in a Flash-Rom. (29F040, flashable from the Atari) It can handle 60 x 8K or 30 x 16K. Quote Link to comment Share on other sites More sharing options...
