Fort Apocalypse Posted November 6, 2007 Share Posted November 6, 2007 Compiles. Won't run. Have tried commenting out various new sections of code, but haven't found the issue. Any ideas? Thanks in advance! Code: ultindy500_0.9.bas.bin Minikernel that code uses: 4 player scores minikernel Quote Link to comment Share on other sites More sharing options...
meshounah Posted November 6, 2007 Share Posted November 6, 2007 can you post source please Quote Link to comment Share on other sites More sharing options...
SeaGtGruff Posted November 6, 2007 Share Posted November 6, 2007 Compiles. Won't run. Have tried commenting out various new sections of code, but haven't found the issue. It didn't compile all the way-- notice that the .BIN is only 2.43K, not 4K. You didn't post the source, but looking at the .BIN in DIS6502, and comparing it to an assembly listing from the 0.8 version, it looks like it stopped assembling at the point where you're doing something with the paddle. Here's the last bit of code from the (aborted) assembly of 0.9: LF9AF LDA L0091 ; A5 91 SEC ; 38 SBC #$26 ; E9 26 LSR ; 4A LSR ; 4A LSR ; 4A LSR ; 4A STA L00ED ; 85 ED <-- This is the last line that assembled, so the error must be right after this. And here's a similar-but-different section of the assembly listing from 0.8: 3161 f9eb .paddletotempdir16max 3162 f9eb ; paddletotempdir16max 3163 f9eb 3164 f9eb .L0219 ; tempdir16max = ( paddle / 5 ) + 1 3165 f9eb 3166 f9eb ; complex statement detected 3167 f9eb a5 91 LDA paddle 3168 f9ed a0 05 LDY #5 3169 f9ef 20 0c f4 jsr div8 3170 f9f2 18 CLC 3171 f9f3 69 01 ADC #1 3172 f9f5 85 ef STA tempdir16max 3173 f9f7 .L0220 ; if tempdir16max > 16 then tempdir16max = 1 3174 f9f7 3175 f9f7 a9 10 LDA #16 3176 f9f9 c5 ef CMP tempdir16max 3177 f9fb b0 04 BCS .skipL0220 3178 f9fd .condpart105 3179 f9fd a9 01 LDA #1 3180 f9ff 85 ef STA tempdir16max 3181 fa01 .skipL0220 3182 fa01 .L0221 ; if tempdir16max < 1 then tempdir16max = 16 3183 fa01 3184 fa01 a5 ef LDA tempdir16max 3185 fa03 c9 01 CMP #1 3186 fa05 b0 04 BCS .skipL0221 3187 fa07 .condpart106 3188 fa07 a9 10 LDA #16 3189 fa09 85 ef STA tempdir16max 3190 fa0b .skipL0221 3191 fa0b .L0222 ; return 3192 fa0b 3193 fa0b 60 RTS Here's the batari Basic code for that part, from the source of 0.8: paddletotempdir16max tempdir16max = (paddle / 5) + 1 if tempdir16max > 16 then tempdir16max = 1 if tempdir16max < 1 then tempdir16max = 16 return It seems like you may have tried to do something to that section of code-- perhaps to make it more compact?-- and maybe it got too complex for bB to handle. But that's just a guess, and it's hard to tell without the source for 0.9. Michael Quote Link to comment Share on other sites More sharing options...
Fort Apocalypse Posted November 6, 2007 Author Share Posted November 6, 2007 (edited) Man I really messed that up. Here's the source. Sorry about that. That part changed in 0.9. I tried commenting it out though (in all 4 places - I wish I could refactor it but it doesn't make sense to) and it still complained. ultindy500_0.9.bas Edited November 6, 2007 by Fort Apocalypse Quote Link to comment Share on other sites More sharing options...
Fort Apocalypse Posted November 6, 2007 Author Share Posted November 6, 2007 (edited) P.S. Thanks for the info on how you figured it out. I need to start looking at the partially compiled code to help myself... I just see stuff like: ---------- Capture Output ---------- 2600 Basic compilation complete. DASM V2.20.07, Macro Assembler (C)1988-2003 bytes of ROM space left 83 bytes of ROM space left Possible duplicate label: L0278 fb78 > Terminated with exit code 0. then try commenting code or putting stuff like: if asfd = fdas then asfd = 4 : asff = 5 into the code and recompiling (because putting bad code in sometimes help expose other bad code). And if that doesn't work I usually have started just commenting out parts of the code, until I find the offending piece. Your way is much better! BTW- sorry I haven't done much stuff in bB side of wiki. I kind of froze up when I started into it and have been wondering since how to get batari/Random Terrain's great single html page (which is easy to search, etc) into a lot of different pages easily and so it looks good. The only way I can think to start it is by copying the whole html into the wiki page and converting to wiki (the body without the right nav/link bar) but then I freeze up thinking about how to start copying those functions and creating their own pages, and I somehow think I'm going to run into problems converting it into just a straight list of functions... I just need to do it though. Edited November 6, 2007 by Fort Apocalypse Quote Link to comment Share on other sites More sharing options...
SeaGtGruff Posted November 6, 2007 Share Posted November 6, 2007 That's weird, it appears to compile all the way-- the assembly listing goes all the way to $FFFF and the startup vectors-- but the .BIN isn't 4K. I'll check the .BIN disassembly against the assembly listing tonight to see what I can figure out. Michael Quote Link to comment Share on other sites More sharing options...
SeaGtGruff Posted November 7, 2007 Share Posted November 7, 2007 That's weird, it appears to compile all the way-- the assembly listing goes all the way to $FFFF and the startup vectors-- but the .BIN isn't 4K. I'll check the .BIN disassembly against the assembly listing tonight to see what I can figure out. Michael Okay, I see what happened. The assembly listing does go all the way to the end, but it didn't resolve all of the addresses. Here's the last section of code in the 0.9 .BIN file, as displayed by DIS6502: LF9A7 LDA L0091 ; A5 91 SEC ; 38 SBC #$26 ; E9 26 LSR ; 4A LSR ; 4A LSR ; 4A LSR ; 4A STA L00ED ; 85 ED And here's the equivalent section of the assembly listing, along with the part that immediately follows it: 3116 f9a7 .incrdir 3117 f9a7 ; incrdir 3118 f9a7 3119 f9a7 .L0214 ; tempx = (paddle - 38) / 16 3120 f9a7 3121 f9a7 ; complex statement detected 3122 f9a7 a5 91 LDA paddle 3123 f9a9 38 SEC 3124 f9aa e9 26 SBC #38 3125 f9ac 4a lsr 3126 f9ad 4a lsr 3127 f9ae 4a lsr 3128 f9af 4a lsr 3129 f9b0 85 ed STA tempx 3130 f9b2 .L0215 ; tempdirmax = tempdirmax + tempx 3131 f9b2 3132 f9b2 ad 00 00 LDA tempdirmax 3133 f9b5 18 CLC 3134 f9b6 65 ed ADC tempx 3135 f9b8 8d 00 00 STA tempdirmax 3136 f9bb .L0216 ; return 3137 f9bb 3138 f9bb 60 RTS This is the specific statement that's causing the assembly to fail: tempdirmax = tempdirmax + tempx And this shows why it's failing: 3132 f9b2 ad 00 00 LDA tempdirmax That line should be loading the accumulator with the contents of tempdirmax, but the address of tempdirmax is $0000-- i.e., it hasn't been defined. If you search your bB code for "tempdirmax," you'll see it's used in the "incrdir" and "decrdir" subroutines, but it's never dimmed anywhere. However, you do make extensive use of a variable named "tempdir16max," so I'm guessing that you just forgot to type the "16" in that variable name when you wrote those two subroutines. Michael Quote Link to comment Share on other sites More sharing options...
Fort Apocalypse Posted November 8, 2007 Author Share Posted November 8, 2007 I'm guessing that you just forgot to type the "16" in that variable name when you wrote those two subroutines. Michael Doh! That was it. Thanks, Michael! (BTW- it is so out of control now when it does compile. ) Quote Link to comment Share on other sites More sharing options...
SeaGtGruff Posted November 8, 2007 Share Posted November 8, 2007 Doh! That was it. Thanks, Michael! You're welcome. By the way, I highly recommend DIS6502. It was written for working with files and programs for the 8-bit Atari computers, but you can easily set it up to work with ROM images for the 2600. I should try to post some how-to instructions for using it, because it's a great alternative to Distella. Assembly listings are also extremely helpful. I definitely recommend modifying your DASM command line to generate a listing when you assemble your games. Michael Quote Link to comment Share on other sites More sharing options...
