mathwontmissyou Posted November 26, 2007 Share Posted November 26, 2007 (edited) I have this tape drive but not the computer. I plugged it in and the rewind function kind of works. After rewinding a tape about 3/4 of the way, it stopped. It does nothing when the advance or play buttons are pushed down. Is this a lost cause or is it possible that any parts of it could be salvaged? Edited November 26, 2007 by mathwontmissyou Quote Link to comment Share on other sites More sharing options...
Rybags Posted November 26, 2007 Share Posted November 26, 2007 The Atari "program recorders" need computer control to enable Play. Lost cause? Probably not. Likely you just have a broken belt drive. Quote Link to comment Share on other sites More sharing options...
mathwontmissyou Posted November 26, 2007 Author Share Posted November 26, 2007 I, see. I guess what I really want to know is if this is something that someone would find useful in any way. As neat as it would be to have an Atari 400, I doubt I'll ever get one. Quote Link to comment Share on other sites More sharing options...
Rybags Posted November 26, 2007 Share Posted November 26, 2007 Just get an XL or XE from eBay. $20-$30 will get a basic setup. Don't chuck the 410 away - there's still collector value in them. Plus, if it's cactus it can still serve as the basis for modding into something else such as a HDD enclosure. If it is the belt, they can still be sourced, or there's always the old fallback of dental floss. Quote Link to comment Share on other sites More sharing options...
atariksi Posted November 26, 2007 Share Posted November 26, 2007 I, see. I guess what I really want to know is if this is something that someone would find useful in any way. As neat as it would be to have an Atari 400, I doubt I'll ever get one. I remember converting my Atari 410 into a normal tape recorder, but the tape speed was a bit off-- probably because the tape recorder wasn't functioning probably. If you look at sio jack: 2 4 6 8 10 12 1 3 5 7 9 11 13 1 = Clock in 2 = Clock out 3 = Data in (blue wire) 4 = Ground (GND) 5 = Data out (red wire) 6 = Ground (GND) 7 = Command 8 = Motor Control 9 = Proceed 10 = +5V/Ready 11 = Audio in 12 = +12V DC 13 = Interrupt You can turn on the tape recorder by applying +5V to Motor Control line (and pressing play) and hear the audio by using Audio in + GND. Haven't played around with it since a long time ago since I simulated the relevant functions of the device in the Peripheral Simulator. Quote Link to comment Share on other sites More sharing options...
