RSS Bot Posted November 30, 2007 Share Posted November 30, 2007 Just discovered an obscure bug today! David Mrozek has been reviewing MM and was having a problem with the lower-right shield being flipped. In this section of the code: KernelGameBottomCode SUBROUTINE sta WSYNC cpy BLyOddRow ; 3 4 php ; 3 7 cpy M1yOddRow ; 3 10 php ; 3 13 cpy M0yOddRow ; 3 16 php ; 3 19 ldx #ENABL ; 2 21 txs ; 2 22 READ_TWO_PADDLES ;23 45 ldx #8 ; 2 47 sta REFP1 ; 3 50 <---- should have been stx REFP1 ldx #0 ; 2 52 stx REFP0 ; 3 55 dey ; 2 57 lda Player4X ; 3 60 sec ; 2 62 sta WSYNC ; 3 65 Just below the macro READ_TWO_PADDLES, the ldx #8, sta REFP1 should have been ldx #8, stx REFP1. The macro READ_TWO_PADDLES is MAC READ_TWO_PADDLES ldx Paddles2Read ; 21-23 3 lda INPT0,x ; | 4 bpl .save1 ; | 2 3 .byte $2c ; | 4 0 .save1 sty Paddle1,x ; | 0 4 lda INPT2,x ; | 4 bpl .save2 ; | 2 3 .byte $2c ; | 4 0 .save2 sty Paddle3,x ; | 0 4 ; +-23 worse case scenerio ENDM so the last data value read into A would have been either INPT2 or INPT3 depending which 2 paddles were being read for the current frame (one frame reads paddles 0 & 2, the next frame reads paddles 1 & 3). INPT2 and INPT3 only return a value in bit 7, the other bits are undefined, and as I understand it normally return the same bits as the address. INPT2 = address $A, INPT3 = address $B $A=%00001010, $B = %00001011. The 8 used to flip the sprite = %00001000, so the "normally returns same bits as address" explains why it works for most people as the bit for 8 is turned on for both $A and $B. Attached File(s) mm20071129NTSC.bin ( 32K ) Number of downloads: 0 mm20071129PAL.bin ( 32K ) Number of downloads: 0 Medieval_Mayhem.zip ( 146.03K ) Number of downloads: 0 http://www.atariage.com/forums/index.php?a...;showentry=4184 Link to comment Share on other sites More sharing options...
