dmd2060 Posted December 7, 2007 Share Posted December 7, 2007 I have Atari800Win PLus 3.0 emulator and set it up per directions I found on the web. I have the 5200.rom, ataribas.rom, atariob.rom, atarixl.rom, mydos45d.atr, etc... and set them up in the emulator, but the only games I can play is through the load executable (.xex) files. I have a lot of .bin files and everytime I try to Auto boot image it indicates to select cartridge type (it usually has anywhere from 2 to 4 different cartridge types) No matter what I select nothing happens. How can I get these .bin files to work? Any help would be greatly appreciated...... thanks Quote Link to comment Share on other sites More sharing options...
kenfused Posted December 7, 2007 Share Posted December 7, 2007 I have Atari800Win PLus 3.0 emulator and set it up per directions I found on the web. I have the 5200.rom, ataribas.rom, atariob.rom, atarixl.rom, mydos45d.atr, etc... and set them up in the emulator, but the only games I can play is through the load executable (.xex) files. I have a lot of .bin files and everytime I try to Auto boot image it indicates to select cartridge type (it usually has anywhere from 2 to 4 different cartridge types) No matter what I select nothing happens. How can I get these .bin files to work? Any help would be greatly appreciated...... thanks Be sure to have them emulator set to the correct type 5200 or 8-bit before "attaching the cartridge". If you are in 8-bit computer mode and attach a 5200 bin, you will not get choices for 5200 cartridges, for example. Quote Link to comment Share on other sites More sharing options...
dmd2060 Posted December 8, 2007 Author Share Posted December 8, 2007 I have Atari800Win PLus 3.0 emulator and set it up per directions I found on the web. I have the 5200.rom, ataribas.rom, atariob.rom, atarixl.rom, mydos45d.atr, etc... and set them up in the emulator, but the only games I can play is through the load executable (.xex) files. I have a lot of .bin files and everytime I try to Auto boot image it indicates to select cartridge type (it usually has anywhere from 2 to 4 different cartridge types) No matter what I select nothing happens. How can I get these .bin files to work? Any help would be greatly appreciated...... thanks Be sure to have them emulator set to the correct type 5200 or 8-bit before "attaching the cartridge". If you are in 8-bit computer mode and attach a 5200 bin, you will not get choices for 5200 cartridges, for example. Thanks....got it to work....But one more thing...dont want to sound like a idiot, but when the game is visible, how do you start to play it? Function key??? Quote Link to comment Share on other sites More sharing options...
+Cafeman Posted December 8, 2007 Share Posted December 8, 2007 There is an option for control method. One option is the control keys and right ctrl = fire button1 for example. I bought a $10 PSX-style USB game controller and use that, works fine for most games. Quote Link to comment Share on other sites More sharing options...
