Tom_Explodes Posted December 12, 2007 Share Posted December 12, 2007 I got one together, but this next one, I can't get the damn thing in under the stupid start, pause and reset buttons. it's driving me insane. is there a tutorial or something on this crap somewherE? SDAKFHAKL:! Quote Link to comment Share on other sites More sharing options...
+remowilliams Posted December 12, 2007 Share Posted December 12, 2007 (edited) Sounds like you are doing some things wrong there. The start button pad unit and bezel should be removed (to make your life easier) as part of disassembly, so there is no 'get the thing under' to worry about. Some instructions at BE's site http://www.best-electronics-ca.com/cx52_j.htm Also a post from Lord Thag http://www.atariage.com/forums/index.php?showtopic=113543 Edited December 12, 2007 by remowilliams Quote Link to comment Share on other sites More sharing options...
Tom_Explodes Posted December 12, 2007 Author Share Posted December 12, 2007 HOW? Quote Link to comment Share on other sites More sharing options...
A.J. Franzman Posted December 12, 2007 Share Posted December 12, 2007 (edited) Use a small straight blade screwdriver on the short ends of the frame around the buttons to pry the frame off. Then the elastomeric buttons come out. Now you can easily put the mylar through the slot, and then after the case is completely assembled, put the buttons and frame back on. P.S. It's better to remove the frame and button trio before opening the case, to reduce the chance of damaging the mylar. Edited December 12, 2007 by A.J. Franzman Quote Link to comment Share on other sites More sharing options...
82atari5200 Posted December 12, 2007 Share Posted December 12, 2007 A long time ago I didn't realize that the top bezel came off either. Something happened to the controller and it wouldn't go down. So being and inquisitive eight year old I took it apart and couldn't get the damned thing back together. It was 10 years later when I realized that the bezel came off. Quote Link to comment Share on other sites More sharing options...
Tom_Explodes Posted December 12, 2007 Author Share Posted December 12, 2007 Sorry about the psychoticness. Got very frustrated very quickly. All set now. Thanks guys. Back in the box, do not open 'til XMAS. Bruggrag, gug. Quote Link to comment Share on other sites More sharing options...
Bruce Tomlin Posted December 22, 2007 Share Posted December 22, 2007 If you don't remove the bezel first, you can very well damage a good flex circuit. I've seen evidence in more than a few controllers I've found that someone probably ruined it by opening the controller the wrong way, then cramming it back together again the wrong way. Also there are two kinds of bezels. One is more easily removed and is therefore better. When you have more bezels than good controllers, just throw the crappy bezels into your junk pile. Quote Link to comment Share on other sites More sharing options...
JB Posted December 22, 2007 Share Posted December 22, 2007 If you don't remove the bezel first, you can very well damage a good flex circuit. I've seen evidence in more than a few controllers I've found that someone probably ruined it by opening the controller the wrong way, then cramming it back together again the wrong way. Also there are two kinds of bezels. One is more easily removed and is therefore better. When you have more bezels than good controllers, just throw the crappy bezels into your junk pile. Is the beveled one the easier one to remove? I remember having trouble pulling the straight-up ones out, but I went with beveled for aesthetic reasons. Quote Link to comment Share on other sites More sharing options...
Bruce Tomlin Posted December 28, 2007 Share Posted December 28, 2007 Is the beveled one the easier one to remove? Much easier. I can pop them off with just my fingernails. Quote Link to comment Share on other sites More sharing options...
