Clint Thompson Posted December 23, 2007 Share Posted December 23, 2007 I'm just asking as I obviously don't know, but.... was it? : Quote Link to comment Share on other sites More sharing options...
DanBoris Posted December 23, 2007 Share Posted December 23, 2007 I'm just asking as I obviously don't know, but.... was it? : The schematics on this page: http://www.jsobola.republika.pl/schematy.htm refer to this as a test connector. These schematics are not official so we can't be sure why it was labeled that way, but where it connects to in the circuit seems to bear this out. For example there is a pin that connects to the power adapter jack, but no pin that connects to the regulated power. If the connector was intended for an add on it would probably have a connection to the regulated power. Dan Quote Link to comment Share on other sites More sharing options...
Clint Thompson Posted December 23, 2007 Author Share Posted December 23, 2007 interesting, thanks =) Quote Link to comment Share on other sites More sharing options...
Forrest Posted February 23, 2008 Share Posted February 23, 2008 Short answer - yes it's upgradeable. My Atari 1030 modem has been upgraded to include ethernet, USB and audio. Pictures and more info to be posted shortly... Quote Link to comment Share on other sites More sharing options...
JayoK Posted February 23, 2008 Share Posted February 23, 2008 I'm just asking as I obviously don't know, but.... was it? : Off-Topic: What's the motherboad underneath the modem with the 6805 chip? Quote Link to comment Share on other sites More sharing options...
Forrest Posted February 24, 2008 Share Posted February 24, 2008 (edited) Click on the link below to see what happens when an Atari 1030 modem is combined with an Apple Airport Express with a bad power supply. The end result is a strange looking wireless router/streaming client/print server. Atari Apple Express The +5VDC power supply circuit from the Atari 1030 was put into service to feed a +3.3VDC power supply constructed on a prototype board (and mounted upside down to fit in the case). Check out the glue stick/light pipe on the right side of the Apple Airport Express - so the status LED can be seen from the back of the case! This may be the only Atari Apple Airport Express in existence Edited February 24, 2008 by Forrest Quote Link to comment Share on other sites More sharing options...
Clint Thompson Posted February 24, 2008 Author Share Posted February 24, 2008 I'm just asking as I obviously don't know, but.... was it? : Off-Topic: What's the motherboad underneath the modem with the 6805 chip? Just Atari 1020 circuitry.... nothing special. Quote Link to comment Share on other sites More sharing options...
doctorclu Posted February 24, 2008 Share Posted February 24, 2008 Click on the link below to see what happens when an Atari 1030 modem is combined with an Apple Airport Express with a bad power supply. The end result is a strange looking wireless router/streaming client/print server. Atari Apple Express The +5VDC power supply circuit from the Atari 1030 was put into service to feed a +3.3VDC power supply constructed on a prototype board (and mounted upside down to fit in the case). Check out the glue stick/light pipe on the right side of the Apple Airport Express - so the status LED can be seen from the back of the case! This may be the only Atari Apple Airport Express in existence Now this is cool. So I imagine this works with your Mac, but put in an Atari case. You know, this just inspires me to take my original 1030 modem and hack a 56K modem into it's power and somehow connect the serial somehow. (Might use "More Than Games" Speedier 19.2K SIO to serial module wired directly into the SIO port on the 1030 to achieve this, and then pack all into the case. Don't ask me why, but I have a slight desire to get my original Atari equipment from back in the day updated to work in this day. Not updated my much mind you, my 400 will still have 48K, but maybe add the "Longhorn Engineer's" 5200 A/V mod (have talked to him on doing this) and for the 1030, just get that thing doing better speed, because 300 baud is really useless. Which is a shame really. How little my dad knew that I would spend HOURS and HOURS online as a kid, starting with a $20 purchase of a used 1030 modem. Quote Link to comment Share on other sites More sharing options...
Forrest Posted February 24, 2008 Share Posted February 24, 2008 Thanks for the kind words The Atari Apple Airport Express works with both Macs and PC's. The Airport Express was just 3 years old when it died suddenly - which is a lot less time than my Atari equipment worked. After I googled this problem, I determined this wasn't an uncommon problem and could be fixed cheaply - compared to buying a refurbished Airport Express for $79. I choose the Atari 1030 modem case because it was plastic (didn't want to block the built-in WiFi antenna), it was the right size and according to ebay it was worth less than $5. If you look closely at the inside layout picture, the Airport Express is carefully wedged into the case on all four sides and there was no need to mechanically fasten the Airport Express. Quote Link to comment Share on other sites More sharing options...
