Champions_2002 Posted December 31, 2007 Share Posted December 31, 2007 As the title says, can anybody help me get the atari 800 emulator work on a vista machine please Quote Link to comment Share on other sites More sharing options...
rdhays82604 Posted December 31, 2007 Share Posted December 31, 2007 As the title says, can anybody help me get the atari 800 emulator work on a vista machine please I have been using both atari800 and atari 800win on a vista system. What did you need help with? Quote Link to comment Share on other sites More sharing options...
Champions_2002 Posted January 1, 2008 Author Share Posted January 1, 2008 when i run it i got the following error message 'Directdraw does not support the graphics display mode. Try running with ".blt" or "width640" on the command line' What i want to know is how do i get it to work Quote Link to comment Share on other sites More sharing options...
rdhays82604 Posted January 1, 2008 Share Posted January 1, 2008 (edited) when i run it i got the following error message 'Directdraw does not support the graphics display mode. Try running with ".blt" or "width640" on the command line' What i want to know is how do i get it to work I assume you are using the emulator from sourceforge.net - atari800.exe? You need to create a batch file to include the command line options. drive:/path to emulator/atari800 -blt or drive:/path to emulator/atari800 -width 640 if the batch file is in the same folder as the emulator then you can eliminate the drive and path names and just use: atari800 -blt or -width 640 to start the emulator using a specified disk like an atr file use- drive:/path to emulator/atari800 -blt "drive:/path to file/filename.ext" or drive:/path to emulator/atari800 -width 640 "drive:/path to file/filename.ext" Again eliminating the drive and path names to the emulator if the batch file is in the same folder as the emulator. hope this helps! Edited January 1, 2008 by rdhays82604 Quote Link to comment Share on other sites More sharing options...
Champions_2002 Posted January 2, 2008 Author Share Posted January 2, 2008 (edited) Thanks A lot, that works great Edited January 2, 2008 by Champions_2002 Quote Link to comment Share on other sites More sharing options...
rdhays82604 Posted January 3, 2008 Share Posted January 3, 2008 Thanks A lot, that works great No problem!!! Let me know if you need any thing else! Quote Link to comment Share on other sites More sharing options...
Roydea6 Posted March 19, 2008 Share Posted March 19, 2008 Thanks A lot, that works great No problem!!! Let me know if you need any thing else! How to save file association in windows vista? for Atari800win from this site: http://www.a800win.atari-area.prv.pl/ TIA Quote Link to comment Share on other sites More sharing options...
