Jess Ragan Posted January 17, 2008 Share Posted January 17, 2008 So, I was wondering... is there any way to build a 2600 paddle adapter for the 5200? I'm not talking about ripping apart a 5200 controller and hot gluing a 2600 paddle into it, but just something I could use to connect a 2600 paddle directly to a 5200. I know that the potentiometers in the 5200 joystick vary in resistance from 0-500K Ohms. I also know that the pots in the 2600 joystick use the same range of resistance. However, I think there's some fundamental difference in how the two potentiometers are powered. I'm just not sure how I would wire the adapter to accommodate those differences. Quote Link to comment Share on other sites More sharing options...
Prodos8 Posted January 17, 2008 Share Posted January 17, 2008 Yeah it can be done - though I've never done it. You might find a detailed write-up somewhere that'd be better. Wire as follows: 5200 GND --------------- 2600 GND 5200 Pot Common ------ 2600 +5v 5200 H-pot -------------- 2600 Paddle A or B (depending on which you wanted to use) 5200 bottom fire -------- 2600 ? (one of directional pins that is fire for paddle A or B --- can't recall right now) I think the movement might be inverted (e.g. left goes right and right goes left) though. If so you can open the paddle and move the wire on the outside connection of the pot to the opposite outside connector to fix it. Quote Link to comment Share on other sites More sharing options...
phonedork Posted January 17, 2008 Share Posted January 17, 2008 Yeah it can be done - though I've never done it. You might find a detailed write-up somewhere that'd be better. Wire as follows: 5200 GND --------------- 2600 GND 5200 Pot Common ------ 2600 +5v 5200 H-pot -------------- 2600 Paddle A or B (depending on which you wanted to use) 5200 bottom fire -------- 2600 ? (one of directional pins that is fire for paddle A or B --- can't recall right now) I think the movement might be inverted (e.g. left goes right and right goes left) though. If so you can open the paddle and move the wire on the outside connection of the pot to the opposite outside connector to fix it. I just bought two at the Atari 2600 store. Whats wrong with that version? I see there not selling anymore. I was gonna post the link. Quote Link to comment Share on other sites More sharing options...
Charlie_ Posted January 17, 2008 Share Posted January 17, 2008 If your talking about the 5200 controller converted to a paddle, there is nothing wrong with it at all. In fact it is the way to go. I think Jess was just wondering if he could easily use a 2600 paddle controller. Quote Link to comment Share on other sites More sharing options...
Jess Ragan Posted January 17, 2008 Author Share Posted January 17, 2008 There is, actually. The side buttons are too mushy for my tastes, and I'd like to avoid them. Quote Link to comment Share on other sites More sharing options...
jetset Posted January 17, 2008 Share Posted January 17, 2008 I can't believe with all the programmers, hackers, a/v modders and other assorted geeks here that this hasn't been done yet. Quote Link to comment Share on other sites More sharing options...
jcleverly Posted January 17, 2008 Share Posted January 17, 2008 There is, actually. The side buttons are too mushy for my tastes, and I'd like to avoid them. what about using a paddle with a wico josystick keyboard or something? Quote Link to comment Share on other sites More sharing options...
Jess Ragan Posted January 17, 2008 Author Share Posted January 17, 2008 Too expensive. What I'd like to do is make a small chassis with the paddle and two arcade-style buttons... if I felt really extravagant, I could even drop in a keypad, divorcing the 5200 from the stock controller entirely. All of this stuff could be had for around the same price as a Wico stick with a Y-cable, and I wouldn't have to mutilate a collector's item to make it. I should probably shop around for small potentiometers with a 500K Ohm rating; something that could theoretically fit inside a stock NES controller. I have some 1K pots but they don't put up nearly enough resistance to make them of much use. I suppose that with some clever wiring, I could take one of those cheap Taiwanese NES controllers (the ones with two extra buttons for rapid fire), replace the D-pad with a 500K pot, cap the pot with a dial, and wire out the remaining buttons for top fire, bottom fire, start, pause, #, and *. That's probably a really extravagant project, especially since such a controller would be useful for only three or four games, but the wiring would be relatively simple. It's just straight connections, without any logic circuits, so even a klutz like me could handle the job. Quote Link to comment Share on other sites More sharing options...
Jess Ragan Posted January 17, 2008 Author Share Posted January 17, 2008 Also, a quick side note... anyone know where I could find a steel dial that rolls on casters or ball bearings? Something that would offer or at least approximate a real arcade feel. Quote Link to comment Share on other sites More sharing options...
ninermaniac Posted January 17, 2008 Share Posted January 17, 2008 If I'm not mistaken I think Shawn Sr. made this type of controller.......Shawn Sr.? Did you? Quote Link to comment Share on other sites More sharing options...
Charlie_ Posted January 17, 2008 Share Posted January 17, 2008 You can find info on this sort of thing over at www.arcadecontrols.com My brother has something like a Tempest spinner in his mame cabinet. It's very nice. Quote Link to comment Share on other sites More sharing options...
CV Gus Posted January 23, 2008 Share Posted January 23, 2008 My second 5200 controller project was a paddle controller (for Super Breakout). It was actually easy to build. Quote Link to comment Share on other sites More sharing options...
Shawn Posted January 23, 2008 Share Posted January 23, 2008 If I'm not mistaken I think Shawn Sr. made this type of controller.......Shawn Sr.? Did you? Many times over for alot of the members here at AA. I don't really make them that often anymore. I did a big write up about how to make them youself with diagrams and posted it here in the 5200 forum about a year ago. Quote Link to comment Share on other sites More sharing options...
