opeygon Posted February 5, 2008 Share Posted February 5, 2008 what's up with the second fire button? by that i mean what is it and how does it operate? please consider that i know what the interface adapter is and how that works. i'm just wondering how the second fire button ties into it all. thanks in advance to all who reply Quote Link to comment Share on other sites More sharing options...
SRGilbert Posted February 5, 2008 Share Posted February 5, 2008 Simple, some (a few anyway) 5200 games required a second firebutton. Since the Masterplay allowed you to use the standard one button 2600 joysticks, this would let you use the second button! Quote Link to comment Share on other sites More sharing options...
opeygon Posted February 5, 2008 Author Share Posted February 5, 2008 Simple, some (a few anyway) 5200 games required a second firebutton. Since the Masterplay allowed you to use the standard one button 2600 joysticks, this would let you use the second button! roger that. but how does it tie in to the adapter. i mean, i've seen one and i know it has a standard 2600 connection and a 5200 connection on one side, and a 5200 plug on the other, but where does the second fire button plug in? and is it easy to use with the 2600 controller? i never knew that you could get a second fire button. it seems to me that it would be hard to use. does it attach to the 2600 controller or something? Quote Link to comment Share on other sites More sharing options...
Charlie_ Posted February 5, 2008 Share Posted February 5, 2008 The button plugs into the interface via a 1/8 mono jack. The button came with 2 sided tape so you could mount it where you want. To be honest it is horribly awkward and of little use. However it is a standard 1/8 mini plug on the interface. So you can easily modify other controllers with a wire and plug to go in to the adapter. I use a Coleco Gemini Joystick I modified with an extra button. Here is a good picture of it: Quote Link to comment Share on other sites More sharing options...
opeygon Posted February 5, 2008 Author Share Posted February 5, 2008 The button plugs into the interface via a 1/8 mono jack. The button came with 2 sided tape so you could mount it where you want. To be honest it is horribly awkward and of little use.However it is a standard 1/8 mini plug on the interface. So you can easily modify other controllers with a wire and plug to go in to the adapter. I use a Coleco Gemini Joystick I modified with an extra button. Here is a good picture of it: bingo! thanks man. just what i needed to know Quote Link to comment Share on other sites More sharing options...
ymike673 Posted February 5, 2008 Share Posted February 5, 2008 The button plugs into the interface via a 1/8 mono jack. The button came with 2 sided tape so you could mount it where you want. To be honest it is horribly awkward and of little use.However it is a standard 1/8 mini plug on the interface. So you can easily modify other controllers with a wire and plug to go in to the adapter. I use a Coleco Gemini Joystick I modified with an extra button. Here is a good picture of it: bingo! thanks man. just what i needed to know Just curious. Since you have the Wico Keypad why not just use the Wico stick with it instead of the interface and a reworked Coleco Gemini Stick? Quote Link to comment Share on other sites More sharing options...
opeygon Posted February 5, 2008 Author Share Posted February 5, 2008 i was wondering that too Quote Link to comment Share on other sites More sharing options...
Charlie_ Posted February 6, 2008 Share Posted February 6, 2008 The wico stick is analog. I'm no fan of it. I have a few, even one boxed with the manual, but they are all too sensative, and the stick bounces when returning to center if you let it go. Sounds wierd but when I use one my player always seems to be turning around and going the other way when I wanted to just stop. Plus I hate the feel of the bottomless buttons. Funny thing is, I like the Gemini stick, even though it is very "cheap" after all. For games that don't need an analog stick, the masterplay is the way to go. (or equivelant) Quote Link to comment Share on other sites More sharing options...
+Mitch Posted February 6, 2008 Share Posted February 6, 2008 Yeah, I built an adapter so that I can use my 7800 arcade stick with the masterplay. Mitch Quote Link to comment Share on other sites More sharing options...
