Ross PK Posted March 15, 2008 Share Posted March 15, 2008 typing in a program? Thanks. Quote Link to comment Share on other sites More sharing options...
+Philsan Posted March 15, 2008 Share Posted March 15, 2008 typing in a program?Thanks. Perhaps you want technical details. Otherwise, why don't you just buy Basic rev. C chip or use Turbo-Basic XL? Quote Link to comment Share on other sites More sharing options...
Ross PK Posted March 15, 2008 Author Share Posted March 15, 2008 Hmmmm, what do you mean by technical details? Quote Link to comment Share on other sites More sharing options...
kenfused Posted March 16, 2008 Share Posted March 16, 2008 (edited) Depends how much your time is worth? Save as often as what you are willing to loose. You may want to alternate between a couple of filenames. It's not how long you have been editing that causes the lockup so much as the number of bytes that is stored with each line and where the edited line will be put into memory. I really would recommend using Turbo Basic XL, or at the very least find a disk loadable version of BASIC Rev C. --Ken Edited March 16, 2008 by kenfused Quote Link to comment Share on other sites More sharing options...
Rybags Posted March 16, 2008 Share Posted March 16, 2008 From memory, Rev C is near identical except for several bytes which have to be patched - so there should be small programs around which do that. I used to just Save regularly - using different filenames is the norm, e.g. Game01 Game02 etc. then just do a cleanup once in a while. Rev B also generously gives you the 16 byte bloat feature each Save, so doing a LIST / ENTER once in a while cures that. Also gets rid of unused variable names. The problem is that you can have a perfectly working program and LIST / ENTER exposed you to the nasty memory move bug which can lockup the machine. In such case you have a LISTed program which locks up, I believe you can sometimes get around it by having some existing code which changes where in memory things are moved. e.g. NEW then 0 REM ABCDEF, then ENTER your program from disk. Quote Link to comment Share on other sites More sharing options...
accousticguitar Posted March 16, 2008 Share Posted March 16, 2008 I really would recommend using Turbo Basic XL, or at the very least find a disk loadable version of BASIC Rev C. --Ken Why the disk loadable version instead of the cart? Quote Link to comment Share on other sites More sharing options...
kenfused Posted March 16, 2008 Share Posted March 16, 2008 I really would recommend using Turbo Basic XL, or at the very least find a disk loadable version of BASIC Rev C. --Ken Why the disk loadable version instead of the cart? price or quick availability. Cart or changing the BASIC ROM if someone wants to heavily use the standard Atari BASIC. Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted March 16, 2008 Share Posted March 16, 2008 All versions of Atari Basic are not copy-protected, so you could just boot a copy of the Rev.C version from a disk (renaming it to "autorun.sys" will accomplish this automatically). Or, you could try to track down an actual cartridge of Basic...even Rev. A is better to use than the internal Rev. B. There was a program that was published by somebody (Compute!, I think) that you could type in that copies the internal Rev. B Basic to the underlying RAM in 800XL's and fixes it...but I can't seem to find it online. REV. C is just REV. A with a couple of bytes NOP'ed out. So if you have no access to a dumped cartridge file, and no way to copy to Ram...the solution is just to avoid using the SAVE or CSAVE commands. Use LIST instead (which stores the program to the specified device un untokenized format...avoiding the problem entirely). Use the ENTER command to load it back. There's only a few problems with using this method: Untokenized program files are quite a bit larger than tokenized program files. Atari Basic has a maximum line length of 120 characters (3 screen lines). This could be an issue if you've used shorthand commands to exceed the character limit. This solution does not correct Basic programs that have already been scrambled by the bug. Description of the lockup bugs in Rev. A and B: http://atarimagazines.planetmirror.com/com...SIGHT_Atari.php Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted March 16, 2008 Share Posted March 16, 2008 (edited) I found the B Basic fixing program HERE The program listing is pretty short if you don't have an SIO... 10 REM BASIC BUG EXTERMINATOR 20 ? CHR$(125):? "{inverse} B BASIC BUG EXTERMINATOR {normal}":? 21 ? "THIS PROGRAM CREATES AN AUTORUN.SYS FILE WHICH CORRECTS THE NASTY BUG" 22 ? "THAT PLAGUES THE VERS B BASIC RESID- ENT IN SOME 800XL MODELS.":? 23 ? "PLACE A FORMATTED BOOT DISK CONTAIN- ING ATARI DOS IN DRIVE #1 AND THEN" 24 ? "PRESS [START].":? :? "A FILE {inverse}AUTORUN.SYS{normal} WILL BE WRITTEN TO YOUR BOOT DISK. NOW,WHENEVER YOU" 25 ? "BOOT YOUR COMPUTER, YOUR RESIDENT BASIC WILL BE FIXED.":? 26 ? "PRESS {inverse}START{normal} WHEN DISK IS READY!" 27 IF PEEK(53279)<>6 THEN 27 30 ? :? "CHECKING DATA STATEMENTS" 40 READ A:IF A=-1 THEN PASS=PASS+1:READ A:IF PASS=3 THEN 60 50 CHECKSUM=CHECKSUM+A:GOTO 40 60 IF CHECKSUM<>A THEN ? CHR$(253):? "DATA STATEMENTS INCORRECT":? "RECHECK PROGRAM":END 70 I=1536:RESTORE 190:? CHR$(125):? :? "DATA STATEMENTS CORRECT--PROCEEDING" 80 READ A:IF A=-1 THEN 100 90 POKE I,A:I=I+1:GOTO 80 100 OPEN #1,8,0,"D:AUTORUN.SYS" 110 READ A:IF A=-1 THEN 130 120 PUT #1,A:GOTO 110 130 X=USR(1536) 140 READ A:IF A=-1 THEN 160 150 PUT #1,A:GOTO 140 160 CLOSE #1:? CHR$(125):? :? "NOW GO TO DOS MENU":? "AND REWRITE DOS FILES" 170 POKE 6156,129:POKE 6160,155 180 END 190 DATA 104,169,0,133,203,169,160,133, 204,162,16,169,11,157,66,3,169,205,157, 68,3,169,0,157 200 DATA 69,3,169,0,157,73,3,169, 1,157,72,3,160,0,177,203,133,205, 32,86,228,24,165,203 210 DATA 105,1,133,203,144,2,230, 204,165,204,201,192,208,3,76,234, 6,201,169,208,41,165,203,201 220 DATA 76,208,217,169,76,133, 205,32,86,228,169,120,133,205,32, 86,228,169,155,133,205,32,86,228 230 DATA 24,165,203,105,3,133, 203,144,187,230,204,76,36,6,201, 172,208,30,165,203,201,168,208,64 240 DATA 169,76,133,205,32,86,228, 169,96,133,205,32,86,228,169,155, 133,205,32,86,228,76,96,6 250 DATA 201,188,240,3,76,36,6, 165,203,201,130,240,3,76,36,6, 169,76,133,205,32,86,228,169 260 DATA 110,133,205,32,86,228, 169,155,133,205,32,86,228,76,96, 6,201,87,240,25,201,100,240,3 270 DATA 76,36,6,169,220,133, 205,32,86,228,24,165,203,105,1, 133,203,144,2,230,204,169,220,133 280 DATA 205,32,86,228,24,165, 203,105,1,133,203,144,2,230, 204,76,36,6,96,-1 290 DATA 255,255,65,0,65,0,0,0, 6,61,6,169,129,133,12,169,155, 133,13,169,0,133,204,169 300 DATA 188,133,205,169,0,133, 206,169,156,133,207,160,0,177,204, 145,206,200,192,0,208,247,230,205 310 DATA 165,205,201,192,240,7, 230,207,160,0,76,26,6,169,1,133, 9,169,0,141,68,2,76,0 320 DATA 160,96,155,255,155,32, 242,171,165,212,240,4,73,128,133, 212,76,177,172,32,81,218,169,7 330 DATA 133,192,76,134,188,208, 4,202,208,1,96,76,84,169,169,255, 133,8,208,17,173,158,23,201 340 DATA 32,240,243,32,64,21,169, 0,133,8,76,155,155,32,64,21,32, 213,155,169,0,133,204,169 350 DATA 156,133,205,169,0,133, 206,169,188,133,207,160,0,177,204, 145,206,200,192,0,208,247,230,205 360 DATA 165,205,201,160,240,7, 230,207,160,0,76,176,155,169,129, 133,12,169,155,133,13,76,0,160 370 DATA 83,58,169,152,133,106, 162,48,169,3,157,66,3,169,211, 157,68,3,169,155,157,69,3,169 380 DATA 8,157,74,3,169,0,157,75, 3,32,86,228,169,12,157,66,3,32,86, 228,96,226,2,227 390 DATA 2,213,155,0,160,255,191,-1 400 DATA 65,0,65,0,1,224,2, 225,2,0,6,-1,61046 Edited March 16, 2008 by Nukey Shay Quote Link to comment Share on other sites More sharing options...
Ross PK Posted March 16, 2008 Author Share Posted March 16, 2008 Thanks NS. I don't have a disk drive though. Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted March 16, 2008 Share Posted March 16, 2008 Then a cartridge of rev. A or C would be the better choice (you pretty much only need to worry about rev. A when deleting program lines). I'm sure that there's some guys around here that have dozens of 'em if you ask Quote Link to comment Share on other sites More sharing options...
