Primordial Ooze Posted March 19, 2008 Share Posted March 19, 2008 I am trying to set it so if the left switch is set to A, the second paddle controller controls the left(player 2) paddle. However when i try that in the emulator i get the following results: Switch B - 1 PlayerMouse is Paddle 0 *Normal* Switch A - 2 Player Mouse is Paddle 0 *Error* Paddle 0 doesn't work Switch A - 2 Player Mouse is Paddle 1 *Error* Paddle 1 controls both paddles I have checked my code for errors, and i can see no errors on my part. Here is my code: rem Open Source Pong rem an Open Source Pong Remake rem Updated: March 17, 2008 rem Website: http://opensourcepong.freepgs.com goto setup rem setup all the game variables setup rem include for multiplication include div_mul.asm rem include for lives counter include 6lives.asm rem set the rom size set romsize 4k rem set kernel options rem readpaddle - set it so the paddle controlers are read set kernel_options no_blank_lines readpaddle rem set an alias for the ball's x velocity dim ballxvelocity = a rem set an alias for the ball's y velocity dim ballyvelocity = b rem set an alias for troggling the 2 player mode dim playervsplayer = c rem color the background green COLUBK = 198 rem set the color of the playfield to white COLUPF = 14 rem define the playfield playfield: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX ................................ ................................ ................................ ................................ ................................ ................................ ................................ ................................ ................................ XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX end rem define player 1's sprite player0: %00011000 %00011000 %00011000 %00011000 %00011000 %00011000 %00011000 %00011000 end rem define player 2's sprite player1: %00011000 %00011000 %00011000 %00011000 %00011000 %00011000 %00011000 %00011000 end rem set the lives counter layout to compact rem dim lives_compact = 1 rem set the player live counter to blue lifecolor = 140 rem finished seting up the game variables rem start the game loop goto startNewGame rem start a new game and reset everything that was changed during rem the course of the game startNewGame rem set player 1's inital x positon player0x = 140 rem set player 1's inital y positon player0y = 45 rem set a default value for the 2 player troggle playervsplayer = 0 rem if the left switch is set to B, paddle 1 controls the rem computers paddle if !switchleftb then playervsplayer = 1 rem set player2's inital x positon player1x = 15 rem set player2's inital y positon player1y = 45 rem set ball's inital x positon ballx = 80 rem set ball's inital y positon bally = 45 rem set the ball's initial x velocity ballxvelocity = 1 rem set the ball's initial x velocity ballyvelocity = 1 rem set the lives counter to 3 lives = 96 rem setup the lives counter rem needs to be setup everytime the lives are SET lives: %00011000 %00011000 %00011000 %00011000 %00011000 %00011000 %00011000 %00011000 end rem reset the score score = 0 rem finished reseting all the game variables changed during rem the course of the game rem go to the game loop goto gameLoop rem start of the game loop gameLoop rem if the user presses the reset switch, start a new game if switchreset then goto startNewGame rem color player 1's paddle COLUP0 = 140 rem color player 2's paddle COLUP1 = 28 rem draw the game screen drawscreen rem read paddle 0, use it to position player 1 across the screen currentpaddle = 0 rem set player1's y position to the paddle control's axis rem plus 8 player0y = paddle + 8 rem make sure player 1 doesn't go off the top screen if player0y < 16 then player0y = 16 rem make sure player 1 doesn't go off the bottom screen if player0y > 79 then player0y = 79 rem if the 2 player mode is activated then paddle 1 controls the rem second paddle if playervsplayer = 1 then gosub player2controls rem otherwise set player 2's y position to the balls y position if playervsplayer = 0 then player1y = bally rem make sure player 2 doesn't go off the top screen if player1y < 16 then player1y = 16 rem make sure player 2 doesn't go off the bottom screen if player1y > 79 then player1y = 79 rem move the ball ballx = ballx + ballxvelocity bally = bally + ballyvelocity rem make sure the ball doesn't go off the top screen if bally < 9 then ballyvelocity = 0 - ballyvelocity rem make sure the ball doesn't go off the bottom screen if bally > 77 then ballyvelocity = 0 - ballyvelocity rem if the ball collides with the player paddle if collision(player0, ball) then gosub playercollision rem if the ball collides with the computer paddle if collision(player1, ball) then gosub playerscores rem if the ball goes past the player paddle if ballx > 160 then gosub playerlostlife rem if the ball goes past the computer paddle if ballx < 1 then gosub playerbonus rem if player has lost all of his lives start a new game if lives < 32 then goto gameover goto gameLoop rem end of the game loop code, restart the game loop rem code for handling collision between player and ball playercollision rem move the ball a bit so it doesn't stick ballx = ballx - 3 rem and reverse its x velocity ballxvelocity = 0 - ballxvelocity return rem end of player collision code rem code for handling when the ball hits the computers paddle rem and the player scores playerscores rem move the ball a bit so it doesn't stick ballx = ballx + 3 rem reverse the balls x velocity ballxvelocity = 0 - ballxvelocity rem increase the score by 10 points score = score + 10 return rem end of player scores code rem code for handling when the ball goes past the computers paddle rem and the player scores bonus points playerbonus rem have the computer serve the ball ballx = player1x + 3 bally = player1y rem reverse the balls x velocity ballxvelocity = 0 - ballxvelocity rem increase the score by 10 points score = score + 10 return rem end of player bonus code rem code for handling when the 2 player troggle is enabled and rem the second paddle controls the computer paddle player2controls rem read paddle 1, use it to position player 2's paddle across the screen currentpaddle = 1 rem set player 2's y position to the paddle 2's control's axis rem plus 8 player1y = paddle + 8 return rem end of player 2 controls code rem code for handling when the player misses the ball and the rem player loses a life playerlostlife rem dencrease the score by 50 points lives = lives - 32 rem have the player serve the ball ballx = player0x - 3 bally = player0y rem reverse the balls x velocity ballxvelocity = 0 - ballxvelocity return rem end of player lost life code rem code for handling when the player has lost all his/her rem lives and its gameover gameover rem if the user presses the reset switch, start a new game if switchreset then goto startNewGame rem color player 1's paddle COLUP0 = 140 rem color player 2's paddle COLUP1 = 28 rem draw the screen drawscreen rem if the user presses the fire button, start a new game if joy0left then goto startNewGame rem otherwise just keep looping goto gameover Could someone please help me? Thanks, Open Source Pong Quote Link to comment Share on other sites More sharing options...
Fort Apocalypse Posted March 20, 2008 Share Posted March 20, 2008 there is a trick to it. you have to set currentpaddle then call drawscreen. drawscreen will then set the paddle variable. Quote Link to comment Share on other sites More sharing options...
Fort Apocalypse Posted March 20, 2008 Share Posted March 20, 2008 there is a trick to it. you have to set currentpaddle then call drawscreen. drawscreen will then set the paddle variable. In addition, you must call Stella with argument: -bc paddles $(FilePath).bin (that is the exact copied and pasted value I have for the "argument" field value in the paddles user tool I created in crimson editor) Quote Link to comment Share on other sites More sharing options...
Primordial Ooze Posted March 20, 2008 Author Share Posted March 20, 2008 I already have a drawscreen inside my main loop, are you saying i need another one inside my player2controls label after i set currentpaddle to 1? Thank you for the advice on the "-bc paddles" command line for Stella. Sincerely, Open Source Pong Quote Link to comment Share on other sites More sharing options...
Fort Apocalypse Posted March 20, 2008 Share Posted March 20, 2008 I already have a drawscreen inside my main loop, are you saying i need another one inside my player2controls label after i set currentpaddle to 1? Thank you for the advice on the "-bc paddles" command line for Stella. Sincerely, Open Source Pong Yes, basically it doesn't set the paddle variable until you call drawscreen, so if you change the currentpaddle and expect it to read the paddle value into "paddle" variable, you have to call drawscreen before the paddle variable will be set. In the Ultimate Indy 500 game (based on 4 paddles) I 1/2 finished (being gracious to myself by saying 1/2 finished ) I had four drawscreens - one after each currentpaddle set. If you have only one paddle, you need only one drawscreen, but you should set currentpaddle before you do the drawscreen, and paddle will be read during that drawscreen. I don't know if you only have a one player game whether you'd need to keep setting currentpaddle, though. But I'm assuming for 2 players, you'll need to set currentpaddle then drawscreen then do something based on paddle value that was read, then set currentpaddle then drawscreen then do something based on paddle value that was read. Quote Link to comment Share on other sites More sharing options...
Primordial Ooze Posted March 20, 2008 Author Share Posted March 20, 2008 Thanks, i added the drawscreen and that did the trick, However i am running into another probem. With the extra drawscreen both paddles flicker. I know its not a "loop is too complicated" problem because 1 my game is only about 2k, 2 when i play single player which removes the extra drawscreen the flicker doesn't happen, 3 if i start a 2 player mode game the flicker happens but, if i switch to a one player game the flicker disappears even though the if statement that leads to that sub is still being called 4, if i remove the extra drawscreen the flicker disappears and 5 i've seen 8k games that i bet have bigger game loops that i have. If someoneone could help me out it would be greatly appreciated. Here is the code: rem Open Source Pong rem an Open Source Pong Remake rem Updated: March 17, 2008 rem Website: http://opensourcepong.freepgs.com goto setup rem setup all the game variables setup rem include for multiplication include div_mul.asm rem include for lives counter include 6lives.asm rem set the rom size set romsize 4k rem set kernel options rem readpaddle - set it so the paddle controlers are read set kernel_options no_blank_lines readpaddle rem set an alias for the ball's x velocity dim ballxvelocity = a rem set an alias for the ball's y velocity dim ballyvelocity = b rem set an alias for troggling the 2 player mode dim playervsplayer = c rem color the background green COLUBK = 198 rem set the color of the playfield to white COLUPF = 14 rem define the playfield playfield: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX ................................ ................................ ................................ ................................ ................................ ................................ ................................ ................................ ................................ XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX end rem define player 1's sprite player0: %00011000 %00011000 %00011000 %00011000 %00011000 %00011000 %00011000 %00011000 end rem define player 2's sprite player1: %00011000 %00011000 %00011000 %00011000 %00011000 %00011000 %00011000 %00011000 end rem set the lives counter layout to compact rem dim lives_compact = 1 rem set the player live counter to blue lifecolor = 140 rem finished seting up the game variables rem start the game loop goto startNewGame rem start a new game and reset everything that was changed during rem the course of the game startNewGame rem set player 1's inital x positon player0x = 140 rem set player 1's inital y positon player0y = 45 rem set a default value for the 2 player troggle playervsplayer = 0 rem if the left switch is set to B, paddle 1 controls the rem computers paddle if !switchleftb then playervsplayer = 1 rem set player2's inital x positon player1x = 15 rem set player2's inital y positon player1y = 45 rem set ball's inital x positon ballx = 80 rem set ball's inital y positon bally = 45 rem set the ball's initial x velocity ballxvelocity = 1 rem set the ball's initial x velocity ballyvelocity = 1 rem set the lives counter to 3 lives = 96 rem setup the lives counter rem needs to be setup everytime the lives are SET lives: %00011000 %00011000 %00011000 %00011000 %00011000 %00011000 %00011000 %00011000 end rem reset the score score = 0 rem finished reseting all the game variables changed during rem the course of the game rem go to the game loop goto gameLoop rem start of the game loop gameLoop rem if the user presses the reset switch, start a new game if switchreset then goto startNewGame rem color player 1's paddle COLUP0 = 140 rem color player 2's paddle COLUP1 = 28 rem read paddle 0, use it to position player 1 across the screen currentpaddle = 0 rem draw the game screen drawscreen rem set player1's y position to the paddle control's axis rem plus 8 player0y = paddle + 8 rem make sure player 1 doesn't go off the top screen if player0y < 16 then player0y = 16 rem make sure player 1 doesn't go off the bottom screen if player0y > 79 then player0y = 79 rem if the 2 player mode is activated then paddle 1 controls the rem second paddle if playervsplayer = 1 then gosub player2controls rem otherwise set player 2's y position to the balls y position if playervsplayer = 0 then player1y = bally rem make sure player 2 doesn't go off the top screen if player1y < 16 then player1y = 16 rem make sure player 2 doesn't go off the bottom screen if player1y > 79 then player1y = 79 rem move the ball ballx = ballx + ballxvelocity bally = bally + ballyvelocity rem make sure the ball doesn't go off the top screen if bally < 9 then ballyvelocity = 0 - ballyvelocity rem make sure the ball doesn't go off the bottom screen if bally > 77 then ballyvelocity = 0 - ballyvelocity rem if the ball collides with the player paddle if collision(player0, ball) then gosub playercollision rem if the ball collides with the computer paddle if collision(player1, ball) then gosub playerscores rem if the ball goes past the player paddle if ballx > 160 then gosub playerlostlife rem if the ball goes past the computer paddle if ballx < 1 then gosub playerbonus rem if player has lost all of his lives start a new game if lives < 32 then goto gameover goto gameLoop rem end of the game loop code, restart the game loop rem code for handling collision between player and ball playercollision rem move the ball a bit so it doesn't stick ballx = ballx - 3 rem and reverse its x velocity ballxvelocity = 0 - ballxvelocity return rem end of player collision code rem code for handling when the ball hits the computers paddle rem and the player scores playerscores rem move the ball a bit so it doesn't stick ballx = ballx + 3 rem reverse the balls x velocity ballxvelocity = 0 - ballxvelocity rem increase the score by 10 points score = score + 10 return rem end of player scores code rem code for handling when the ball goes past the computers paddle rem and the player scores bonus points playerbonus rem have the computer serve the ball ballx = player1x + 3 bally = player1y rem reverse the balls x velocity ballxvelocity = 0 - ballxvelocity rem increase the score by 10 points score = score + 10 return rem end of player bonus code rem code for handling when the 2 player troggle is enabled and rem the second paddle controls the computer paddle player2controls rem read paddle 1, use it to position player 2's paddle across the screen currentpaddle = 1 rem draw the game screen drawscreen rem set player 2's y position to the paddle 2's control's axis rem plus 8 player1y = paddle + 8 return rem end of player 2 controls code rem code for handling when the player misses the ball and the rem player loses a life playerlostlife rem dencrease the score by 50 points lives = lives - 32 rem have the player serve the ball ballx = player0x - 3 bally = player0y rem reverse the balls x velocity ballxvelocity = 0 - ballxvelocity return rem end of player lost life code rem code for handling when the player has lost all his/her rem lives and its gameover gameover rem if the user presses the reset switch, start a new game if switchreset then goto startNewGame rem color player 1's paddle COLUP0 = 140 rem color player 2's paddle COLUP1 = 28 rem draw the screen drawscreen rem if the user presses the fire button, start a new game if joy0left then goto startNewGame rem otherwise just keep looping goto gameover Sincerely, Open Source Pong Quote Link to comment Share on other sites More sharing options...
Fort Apocalypse Posted March 21, 2008 Share Posted March 21, 2008 Hmm... I'm not getting any flickering. You may want to try the latest bB kernel from the bB bugs thread in the bB forum. It plays great! You may want to make it 2-player optional and use the player scores minikernel. (search for that thread and you'll find it- works great.) Note: there is one bug, which is when the ball gets stuck going back and forth in basically a straight line at the very bottom of the screen. I think it is either validly going straight across or is getting stuck somehow in playfield collision stuff. It is probably fairly hard to reproduce. Quote Link to comment Share on other sites More sharing options...
Primordial Ooze Posted March 21, 2008 Author Share Posted March 21, 2008 It happen when in a two player game, the paddles go from color to grey. The two player mode is optional and is activated by setting the left difficult switch to A. To reproduce the bug you reported just have your paddle rest on the top or bottom of the screen and lose a ball. Its colliding with the top and bottom border causing the ball to callide rapidly to change velocity. It will be fix most likely in the next update, but thanks for reporting it anyways. Sincerely, Open Source Pong Quote Link to comment Share on other sites More sharing options...
Fort Apocalypse Posted March 21, 2008 Share Posted March 21, 2008 It happen when in a two player game, the paddles go from color to grey. The two player mode is optional and is activated by setting the left difficult switch to A. To reproduce the bug you reported just have your paddle rest on the top or bottom of the screen and lose a ball. Its colliding with the top and bottom border causing the ball to callide rapidly to change velocity. It will be fix most likely in the next update, but thanks for reporting it anyways. Sincerely, Open Source Pong You have to set COLUP0 and COLUP1 before every drawscreen. See "Ephemeral Variables and Registers (short-lived)" in http://www.randomterrain.com/atari-2600-me....html#ephvarreg I think that might help you. Quote Link to comment Share on other sites More sharing options...
Primordial Ooze Posted March 21, 2008 Author Share Posted March 21, 2008 Ok, Thank You i will go read it right now. Sincerely, Open Source Pong Quote Link to comment Share on other sites More sharing options...
