Lord Helmet Posted March 31, 2008 Share Posted March 31, 2008 Went to play my 5200 Saturday night...clicked it on and...nothing I'm not sure if it is the unit though. I think it might be the switchbox (my 5200 is a 4 port). The last time I played it I thoght I smelled melting plastic, and the switchbox was a little warm. I suppose I should open it up and check it out. Anyone have a spare 4-port switchbox? Any ideas on how I could test the unit to see whether or not the problem is with the 5200 itself? Quote Link to comment Share on other sites More sharing options...
Jess Ragan Posted April 1, 2008 Share Posted April 1, 2008 The obvious answer is "get a new switchbox." Another possibility is replacing the four port 5200 with a two port system. It doesn't need a switchbox, and a few of the two port systems actually will play Mountain King and Pitfall!. It's a crapshoot, but even if the system you buy can't play those two games, at least you won't have to screw around with that idiotic switchbox! Quote Link to comment Share on other sites More sharing options...
Lord Helmet Posted April 1, 2008 Author Share Posted April 1, 2008 I think I'm gonna post in the wanted forum about a new switchbox. Quote Link to comment Share on other sites More sharing options...
+-^CrossBow^- Posted April 1, 2008 Share Posted April 1, 2008 It is also worth noting that I believe CPUwiz or someone else some time back posted procedures on how to convert the 4port model to not require the use of the switchbox. It would seem to me that would be the best course to take here. I actually do have a spare 4-port switchbox, but it goes with me to my grave. Unless of course my primary switchbox ever dies again, in which case I would have to use my spare as my new primary. I can't remember exactly what happened to my original, but I know it was doing the same as yours, nothing. Turned out that in its earlier life when I wasn't the owner, someone had likely plugged an 800 power supply into the switchbox and it blew up a few things inside it. However, I was able to purchase the chip and transistor that were blown apart and it has been working fine ever since. Point is, it could very well be repairable. If not, do a search for the conversion and see if that doesn't seem a better option. Quote Link to comment Share on other sites More sharing options...
NickelPlate Posted April 1, 2008 Share Posted April 1, 2008 Does your switchbox click when you press the 5200 power button? Does the LED on the 5200 light up? Use a meter to check the output from the power supply and the switchbox power jack. Best Electronics has 4 port switch boxes listed on their site for $19. If that's the problem, I would just get one of those and be done with it. Good luck, NP Quote Link to comment Share on other sites More sharing options...
+remowilliams Posted April 1, 2008 Share Posted April 1, 2008 It is also worth noting that I believe CPUwiz or someone else some time back posted procedures on how to convert the 4port model to not require the use of the switchbox. It would seem to me that would be the best course to take here. Yeah, the great power mod. Highly recommended, especially for those who have A/V mods for the system. Quote Link to comment Share on other sites More sharing options...
Bruce Tomlin Posted April 3, 2008 Share Posted April 3, 2008 I have spare switchboxes, but currently no transportation to get it to the post office. Quote Link to comment Share on other sites More sharing options...
Prodos8 Posted April 5, 2008 Share Posted April 5, 2008 There are instructions in the 5200 faq for building your own switchbox for around $10 in parts from RS. Looks like a fun little project, but personally I'd just do the power mod and ditch the switch box. Quote Link to comment Share on other sites More sharing options...
shadow460 Posted April 5, 2008 Share Posted April 5, 2008 I shorted the RF plug by accident on my last 4 port switchbox. I've never used one since. If you don't want to mess with the mod, why not drop the 5200 off and I'll power mod it for you? Quote Link to comment Share on other sites More sharing options...
phonedork Posted April 9, 2008 Share Posted April 9, 2008 If you want to get rid of the pesky switchbox all together then go here.... http://www.oldschoolgamer.ca/information.aspx?SID=19 They can s-video mod it and assemble a seperate AC power device where you can use a regular power supply for the four port Atari. I did this and it is great. No more switch box where RF and power are mixed. Being a RF engineer for T-mobile I will tell you that you dont mix power with RF unless you want noise. Quote Link to comment Share on other sites More sharing options...
Lord Helmet Posted April 9, 2008 Author Share Posted April 9, 2008 Honestly, I haven't had any time to mess with my 5200 at all. Life gets in the way sometimes Quote Link to comment Share on other sites More sharing options...
