dinosaur Posted April 9, 2008 Share Posted April 9, 2008 Hello! I have several XF551 drives and dug them out to check them out and discovered I can't find the docs. Can someone please explain the drive selctor switches? Thanks! Quote Link to comment Share on other sites More sharing options...
tcropper Posted April 10, 2008 Share Posted April 10, 2008 Hello! I have several XF551 drives and dug them out to check them out and discovered I can't find the docs. Can someone please explain the drive selctor switches? Thanks! Saw this under your profile, let me know on the printer when you can! I can tell you about the 1050 drive selector switch on a 1050 drive, but not the XF551. There was a manual archive somewhere on the internet...might do a search on www.atari.org I think it is or atariage.org Interested in an 8-bit newsletter created and printed on Atari 1200XL and the printer I am about to get from you? Let me know! It's free, just need a SASE. Thanks! - Toby Quote Link to comment Share on other sites More sharing options...
+bob1200xl Posted April 10, 2008 Share Posted April 10, 2008 Hello! I have several XF551 drives and dug them out to check them out and discovered I can't find the docs. Can someone please explain the drive selctor switches? Thanks! Looking at the back of the drive, right side, there are two, small white switch levers. Both down is D1: both up is D4: left up - right down is D3: left down right up is D2:. Follows a binary 00, 01, 10, 11 pattern. Bob 2 Quote Link to comment Share on other sites More sharing options...
