+Random Terrain Posted April 12, 2008 Share Posted April 12, 2008 I've done some strange things on other computers while playing around that caused the graphics to be screwed up and I used it as an effect. Is there a way to screw up the playfield pixels so they no longer look like smooth blocks (each playfield pixel would look like it is made up of scrambled crap)? Thanks. Quote Link to comment Share on other sites More sharing options...
+batari Posted April 12, 2008 Share Posted April 12, 2008 I've done some strange things on other computers while playing around that caused the graphics to be screwed up and I used it as an effect. Is there a way to screw up the playfield pixels so they no longer look like smooth blocks (each playfield pixel would look like it is made up of scrambled crap)? Thanks. Anything that causes the kernel to take an extra cycle would have that effect. There are several ways to do this, but probably the easiest is to define a player object, position it onscreen then change its pointer to something that will cause an extra cycle in the kernel, for example: player0pointer=255. bB's kernel is somewhat tolerant of such things, as they normally won't cause extra scanlines in the frame unless the distortion is really bad. Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted April 12, 2008 Author Share Posted April 12, 2008 Anything that causes the kernel to take an extra cycle would have that effect. There are several ways to do this, but probably the easiest is to define a player object, position it onscreen then change its pointer to something that will cause an extra cycle in the kernel, for example: player0pointer=255. bB's kernel is somewhat tolerant of such things, as they normally won't cause extra scanlines in the frame unless the distortion is really bad. Thanks. That seems to be working, but is there a way to do it without wasting a sprite? I'd love to mangle those playfield pixels and keep my sprites. Quote Link to comment Share on other sites More sharing options...
+batari Posted April 12, 2008 Share Posted April 12, 2008 Anything that causes the kernel to take an extra cycle would have that effect. There are several ways to do this, but probably the easiest is to define a player object, position it onscreen then change its pointer to something that will cause an extra cycle in the kernel, for example: player0pointer=255. bB's kernel is somewhat tolerant of such things, as they normally won't cause extra scanlines in the frame unless the distortion is really bad. Thanks. That seems to be working, but is there a way to do it without wasting a sprite? I'd love to mangle those playfield pixels and keep my sprites. The only way I can think of is to use the pfcolors kernel option and set pfcolortable=255 or a smaller value if you don't want to distort the whole playfield. The only problem I see with this method is the actual playfield colors will be hard to predict, and are likely to be all zero (black) so a non-black background may be needed to see the playfield. Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted April 12, 2008 Author Share Posted April 12, 2008 The only way I can think of is to use the pfcolors kernel option and set pfcolortable=255 or a smaller value if you don't want to distort the whole playfield. The only problem I see with this method is the actual playfield colors will be hard to predict, and are likely to be all zero (black) so a non-black background may be needed to see the playfield. Thanks. I'll see what kind of a mess I can make with that. Quote Link to comment Share on other sites More sharing options...
