carmel_andrews Posted April 21, 2008 Share Posted April 21, 2008 I have an issue with this version of the emu and win xp x64 it many relates to 2 sound issues, firstly you can't select 8bit resolution using direct sound (sound options) it comes up with an error...I don't know if it's just the emu, my sound card (or drivers) or win xp x64 The other issue regarding ths sound is that after a few uses of the emu, you start getting some 'crackle' over the sound channels, the only way i've found to curing this is to reinstall the sound card drivers (don't remove them first) then removing the atari800win folder from the windows registry editor and reinstalling the emu...that seems to cure it for a while I've also noticed a 'bug' regarding the 'disable basic' option, it mainly relates to the loading of binary executables (exe/com/xex etc), sometimes once you've loaded an exe etc (with basic disabled), if the press the reset and it coldstarts...sometimes it will jump to the basic cartridge, not the self test (which is the default for basic disabled option) Also, i notice that on restarting the emu, it only seems to remember the last ATR file you tried to load...surely it should be able to remember the last of any type of file you tried to load upon restarting, what's so special about ATR's..it shouldn't be too much hassle to get the emu to remember the last binary exec. or cart/cas image you tried to load upon restarting the emu Quote Link to comment Share on other sites More sharing options...
miker Posted April 22, 2008 Share Posted April 22, 2008 Well... the last stable release of PLus is still 4.0. 4.1 is (although based on newer Atari800 core, 2.0.2 IIRC) only fast recompilation, and yes, it lack some features. You can try to ask Jaskier about new stable version but he seems to be very busy lately... Or wait to the new Atari800 release, which may have all the PLus' features built-in. Quote Link to comment Share on other sites More sharing options...
Shannon Posted April 22, 2008 Share Posted April 22, 2008 Alot of those issues you mentioned I noticed in Atarixlbox when I upgraded the core to 2.0. PLus 4.0 uses an older core which does not have those little "quirks". As for the sound problem, I dunno what to say. Quote Link to comment Share on other sites More sharing options...
pseudografx Posted April 22, 2008 Share Posted April 22, 2008 Btw. I have noticed another issue with v4.0 - when decreasing the speed of emulation to eg. 20%, my computer's CPU becomes fully loaded (like if the emulation was actually running at maximum speed). Does jaskier know about this bug? Quote Link to comment Share on other sites More sharing options...
