StanJr Posted September 15, 2002 Share Posted September 15, 2002 HOLY POOP! I CANNOT wait until this makes its way to a cart! I missed out on all of those neat Thrust releases, but I'm DEFINITELY on board for this puppy! Thomas is a genius! Quote Link to comment Share on other sites More sharing options...
ubersaurus Posted September 15, 2002 Share Posted September 15, 2002 Thomas is the master! Anyone notice the Odessey 2 influence on the dots around the tank...reminds me of UFO. I'd attest it to Robot City being a port of an Odyssey 2 proto game that was completed but not released. Quote Link to comment Share on other sites More sharing options...
Dan Iacovelli Posted September 15, 2002 Share Posted September 15, 2002 this game is cool. kind of reminds me wizard of wor with the maze and game play. I had to use Z26 to the run the current version it doesn't work all the way with pcaewin. Dan Iacovelli Quote Link to comment Share on other sites More sharing options...
Rob Mitchell Posted September 16, 2002 Share Posted September 16, 2002 Thomas: I'll load this latest version up on the Cuttle Cart tomorrow .. Rob Mitchell, Atlanta, GA Quote Link to comment Share on other sites More sharing options...
AtariKari Posted September 16, 2002 Share Posted September 16, 2002 Just fired this up on the CC myself. This is great stuff! The field effect around the enemies is awesome, and the AI should prove to be a welcome challenge. The only negative I see is that the player "leads" a little bit beyond where you are trying to go, ie. turning a corner and then ducking back to avoid a shot is tough, maybe b/c the chopper is harder to weild and larger than Pac Man. Robot is a super diversion from Malgai and Mrs. Pacman; looking forward to see how it develops! On a side note: I just bought an Intellicart, and it looks like they only have 5 or so left:http://edisplay.com/intellicart/. FYI. Quote Link to comment Share on other sites More sharing options...
Big Player Posted September 16, 2002 Share Posted September 16, 2002 One thing happened while playing, I'm not sure if you could call it a bug. I froze one of the tanks in the upper-right corner, right where a new helicopter appears. I got killed and then, the program was stuck in an endless loop. A new helicopter appeared on top of the tank and then would instantly die, again and again. I hit reset to get out of it. I guess another way around it is to make sure not to freeze any tanks in the upper-right corner. Or don't get killed if you do. Quote Link to comment Share on other sites More sharing options...
NE146 Posted September 16, 2002 Share Posted September 16, 2002 Thomas there are a couple of threads in the 'programming' sections which might help you to learn about programming for the 2600. If you do have such ambitions, good luck! But let me warn you that programming for the 2600 is very difficult. Might I suggest you try learning Basic first to get a handle on programming concepts... Quote Link to comment Share on other sites More sharing options...
StanJr Posted September 16, 2002 Share Posted September 16, 2002 NE146, yer just being a little stinker tonight ain't ya? Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted September 16, 2002 Share Posted September 16, 2002 One thing happened while playing, I'm not sure if you could call it a bug. I froze one of the tanks in the upper-right corner, right where a new helicopter appears. I got killed and then, the program was stuck in an endless loop. A new helicopter appeared on top of the tank and then would instantly die, again and again. I hit reset to get out of it. I guess another way around it is to make sure not to freeze any tanks in the upper-right corner. Or don't get killed if you do. Yes, that's a bug, you shouldn't loose all your lifes then. And because you are not the first who mentioned it, I better fix it until the next version. Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted September 16, 2002 Share Posted September 16, 2002 Thomas there are a couple of threads in the 'programming' sections which might help you to learn about programming for the 2600. If you do have such ambitions, good luck! But let me warn you that programming for the 2600 is very difficult. Might I suggest you try learning Basic first to get a handle on programming concepts... Many, many thanks for the tip. I'll check the forum immediately! Quote Link to comment Share on other sites More sharing options...
Cybergoth Posted September 16, 2002 Share Posted September 16, 2002 Hi Thomas! If the game is still Greetings, Manuel Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted September 16, 2002 Share Posted September 16, 2002 If the game is still <2K you can probably submit it in the mini game contest as well. It will not count for the contest, but they'll have an extra page displaying the games that didn't get small enough. Now it has grown to about 3K, so way to large for the contest. Quote Link to comment Share on other sites More sharing options...
MegaManFan Posted September 16, 2002 Share Posted September 16, 2002 Now it has grown to about 3K, so way to large for the contest. Fooey, who cares about the contest? Finish the game, slap it on a cart, and sell it to us! That's all that matters. Quote Link to comment Share on other sites More sharing options...
Big Player Posted September 17, 2002 Share Posted September 17, 2002 One thing happened while playing, I'm not sure if you could call it a bug. I froze one of the tanks in the upper-right corner, right where a new helicopter appears. I got killed and then, the program was stuck in an endless loop. A new helicopter appeared on top of the tank and then would instantly die, again and again. I hit reset to get out of it. I guess another way around it is to make sure not to freeze any tanks in the upper-right corner. Or don't get killed if you do. Yes, that's a bug, you shouldn't loose all your lifes then. And because you are not the first who mentioned it, I better fix it until the next version. Good to hear it's actually a bug--since I last found the non-existent "computer going alone" bug in Euchre. Quote Link to comment Share on other sites More sharing options...
ATARI TROLL Posted July 22, 2004 Share Posted July 22, 2004 Thomas any updates to this game or is it finished as is?? Quote Link to comment Share on other sites More sharing options...
neotokeo2001 Posted December 2, 2004 Share Posted December 2, 2004 Any updates on this game or is it a Dead Project?? Cool game. I hope it gets finished. Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted December 2, 2004 Share Posted December 2, 2004 Any updates on this game or is it a Dead Project?? Not dead, just temporarily burried. Quote Link to comment Share on other sites More sharing options...
StanJr Posted December 2, 2004 Share Posted December 2, 2004 well, get yer shovel! demanding fans want great games, what can I say? Quote Link to comment Share on other sites More sharing options...
Godzilla Posted December 3, 2004 Share Posted December 3, 2004 im really looking forward to this, hopefully I will have some time to try it one day... Quote Link to comment Share on other sites More sharing options...
sandmountainslim Posted January 16, 2005 Share Posted January 16, 2005 Is this project still in the works? I hope so would really like to buy this one, whatcha say Thomas? Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted January 16, 2005 Share Posted January 16, 2005 Is this project still in the works? I hope so would really like to buy this one, whatcha say Thomas? See above (still valid) Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted October 14, 2007 Share Posted October 14, 2007 still valid? Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted October 14, 2007 Share Posted October 14, 2007 still valid? Sure. Quote Link to comment Share on other sites More sharing options...
jboypacman Posted October 14, 2007 Share Posted October 14, 2007 I have been looking forward to seeing this being released as a cart so i we get to see it in this form sometime soon(Could make for great X-Mas gift from Mrs.Jboypacman). Quote Link to comment Share on other sites More sharing options...
r_type2600 Posted October 14, 2007 Share Posted October 14, 2007 still valid? Sure. Care starting a "Robot City 8/16K" thread in the homebrews forum? Just a few ideas so far, but those threads tend to gain their own momentum ... Cheers, Eric Quote Link to comment Share on other sites More sharing options...
