Fletch Posted May 5, 2008 Share Posted May 5, 2008 I purchased a silly amount of stuff from a seller on Craigslist today. One of the items was an 800 that had a board I did not recognize, Atari /132 stamped into the plastic on the bottom, and what appears to be possibly a built in SIO2PC. The board says Anderson Peripherals on it and may just be a third party ram board of some kind. The case was a wreck so its currently enjoying a bath in the dishwasher so I didn't get a picture of the stamping. There is a 9 pin male soldered into the serial I/O which I assume may be a SIO2PC. Anybody have any insight? I'll try to check it out tomorrow after I get a chance to reassemble it. Thanks! Fletch Quote Link to comment Share on other sites More sharing options...
Rybags Posted May 5, 2008 Share Posted May 5, 2008 The common modern form of APE uses a single 1489 IC, so check that. A bit hard to tell on that pic, but the connections to the SIO port should be Data In/Out, Command, GND and +5V (pins 3,5,7,4 or 6, and 10) Quote Link to comment Share on other sites More sharing options...
Fletch Posted May 5, 2008 Author Share Posted May 5, 2008 The common modern form of APE uses a single 1489 IC, so check that. A bit hard to tell on that pic, but the connections to the SIO port should be Data In/Out, Command, GND and +5V (pins 3,5,7,4 or 6, and 10) It indeed does say 1489P on it. So I'm guessing my assumption was correct. Thanks for the help! Fletch Quote Link to comment Share on other sites More sharing options...
