Sean39 Posted June 11, 2008 Share Posted June 11, 2008 I have the Atari 130XE Computer...How do I get to memo pad on that computer?????????? Thanks Sean39 Quote Link to comment Share on other sites More sharing options...
puppetmark Posted June 11, 2008 Share Posted June 11, 2008 (edited) I have the Atari 130XE Computer...How do I get to memo pad on that computer?????????? Thanks Sean39 There is no memopad on the 130XE. Edited June 11, 2008 by puppetmark Quote Link to comment Share on other sites More sharing options...
puppetmark Posted June 11, 2008 Share Posted June 11, 2008 (edited) oops. Double post. Sorry Edited June 11, 2008 by puppetmark Quote Link to comment Share on other sites More sharing options...
Shawn Jefferson Posted June 11, 2008 Share Posted June 11, 2008 You could boot the Translator disk on your 130XE, holding down Option, and then when Translator boots, remove the disk, turn off the drive and press SELECT. Quote Link to comment Share on other sites More sharing options...
1050 Posted June 11, 2008 Share Posted June 11, 2008 The Memo Pad was replaced by the Self Test code so typing BYE in BASIC or using X=USR(58481) line might get you into the Self Test. From Type 2 AtariDOSes you can usually do (M) Run at Address E471 and get either the Memo Pad or the Self Test depending on which OS you are running. SpartaDOS would then use the RUN E471 command. I've always used E480 but apparently that is a slightly different entry point into the Self Test code, ya learn something every day around here. Page 222, XL version of Mapping the Atari, just to give credit where due. Quote Link to comment Share on other sites More sharing options...
