ApolloBoy Posted June 19, 2008 Share Posted June 19, 2008 I took apart my Vanguard cart to clean it, and now I can't seem to get it back together. Every time I think I have it, the spring pops out and then I'm back at square one. How do you guys do it? Quote Link to comment Share on other sites More sharing options...
+Allan Posted June 19, 2008 Share Posted June 19, 2008 I took apart my Vanguard cart to clean it, and now I can't seem to get it back together. Every time I think I have it, the spring pops out and then I'm back at square one. How do you guys do it? OK. Take the label part of the shell with the label half facing down and put the two end pieces in the right positions on the end. Then take the two rounded ends of the spring and put them in the long slot of the smaller plastic end piecees and the other end of the the spring (the circle part) over the stub that comes out of the center of the label part of the shell.(The shell half with the label). Then take the cartridge circuit board and put the connector end into the bottom of the cartidge with the chip facing down. When you are doing this line up the hole with stub and push the top part of the circuit board under the plastic lip on the cartridge shell. Then put the top/back part of the shell on. I know this is very worded but it's hard to describe. Pictures would be better. If you are still lost I will post some pics. Allan Quote Link to comment Share on other sites More sharing options...
ApolloBoy Posted June 19, 2008 Author Share Posted June 19, 2008 Is there a specific way of putting the spring back on? I'm putting it back together correctly yet the spring still pops out. Quote Link to comment Share on other sites More sharing options...
+Allan Posted June 20, 2008 Share Posted June 20, 2008 (edited) Is there a specific way of putting the spring back on? I'm putting it back together correctly yet the spring still pops out. Is it popping out after you put the circuit board in or before? If you put the two-part end in first and then the circle end in and then put the board in, it should stay in place as long as you keep the cartridge horizontal. Then once you put the back part of the cartridge shell on and snap it in, the spring won't move. Allan Edited June 20, 2008 by Allan Quote Link to comment Share on other sites More sharing options...
+Allan Posted June 20, 2008 Share Posted June 20, 2008 The rest. Allan Quote Link to comment Share on other sites More sharing options...
ApolloBoy Posted June 20, 2008 Author Share Posted June 20, 2008 Ah, I see where it goes now. Thanks, now I have it reassembled! Now it's time to go clean my other 5200 games... Quote Link to comment Share on other sites More sharing options...
