Retrofan Posted August 4, 2008 Share Posted August 4, 2008 I have some 8K Telegames carts and want to know, if I can use them for 16K/32K games, too (similar to the AtariAge PCBs)? For 8K games they work perfectly. Perhaps someone knows what to do with the PCBs to use them for bigger eproms. Second question: For 8K roms I have to switch the 4K banks A-B to B-A. Which is the correct order of the banks for a 16K Eprom? B-A-D-C or D-C-B-A? Here are photos of the PCB: Upside with chips (without eprom) Upside without chips: Downside: Quote Link to comment Share on other sites More sharing options...
+batari Posted August 6, 2008 Share Posted August 6, 2008 The simple answer is no - I had the same question a while back and reverse-engineered the boards. The jumpers at the top are for supporting larger chips, but NOT larger games. That is, the jumpers will allow you to use a 16k or 32k chip on the board but still only 8k of space on the chip will be supported. I have used this feature myself as I have a zillion 32k EPROMs but very few 8k. For the more complex answer, if you don't mind deadbugging another chip on there and adding a cap, you might be able to get 16k, or possibly 32k out of it. The good news is that (IIRC) the 74138 is wired such that you should be able to get proper address decoding for 16k-32k, but you still need a latch for 16k or two for 32k. Another 7400 might work. It is not going to look pretty, however. Quote Link to comment Share on other sites More sharing options...
Retrofan Posted August 8, 2008 Author Share Posted August 8, 2008 Thank you for your answer. Then I will use the carts for 8K games and buy some 16/32K PCBs for the bigger games. Quote Link to comment Share on other sites More sharing options...
WagnerBrasil Posted December 25, 2018 Share Posted December 25, 2018 Good afternoon, please you have the rom that copied from eprom, you can send it to me, thank you, thank you. Quote Link to comment Share on other sites More sharing options...
Retrofan Posted December 28, 2018 Author Share Posted December 28, 2018 I didn't copy it. But that was a simple 8K ROM from the Telegames library (maybe Bump'n'Jump or Quest-for-Quintana-Roo). You can find them here Quote Link to comment Share on other sites More sharing options...
