+bob1200xl Posted August 31, 2008 Share Posted August 31, 2008 DOSSYS.zip DUPSYS.zip Here are the DOS and DUP for DOS 2.5 from OSS in tokenized MAC/65 format. Sadly, it is corrupted to a certain extent. Perhaps we can de-tokenize it manually and make it useful. Bob Quote Link to comment Share on other sites More sharing options...
Urchlay Posted August 31, 2008 Share Posted August 31, 2008 Perhaps we can de-tokenize it manually and make it useful. Hmmm, a challenge... A while back I had thought of writing a mac/65 detokenizer, guess it's time to actually start that project now that there's a use for it Quote Link to comment Share on other sites More sharing options...
ijor Posted August 31, 2008 Share Posted August 31, 2008 Many thanks Bob! So DOS 2.5 was developed by OSS? I thought it wasn't. Quote Link to comment Share on other sites More sharing options...
Urchlay Posted August 31, 2008 Share Posted August 31, 2008 Hmmm. It looks like a few bits got toggled here & there... including bits in the directory sectors, so it's not just that the file contents are corrupt, the whole image is. Is the actual floppy messed up, when you try to load the files in Mac/65 on hardware? I mean, it isn't just an imaging error, is it? (Hoping it is, but somehow I doubt it...) I couldn't find any docs on Mac/65's tokenized file format, so I'm figuring it out the hard way... will take a while. Probably will start a new thread for it, document what I find out as I find it out, unless someone replies to this and says "You silly person, the Mac/65 file format is documented at (some URL)". Do you know whether this version of DOS 2.5 was the version that was released? If the disk weren't damaged, and you assembled it, would you get an exact copy of the DOS 2.5 that Atari used to sell? Quote Link to comment Share on other sites More sharing options...
+bob1200xl Posted August 31, 2008 Author Share Posted August 31, 2008 The floppy is OK - the data was sent over SIO like that, evidently. Some of the files LOAD and LIST (poorly) - some LOAD and do not list at all. I wish it was just an image error... You noticed the '3's in the directories? Would be nice if all the bad characters were a matter of bits 6 and/or 7. I seem to remember a listing of the MAC/65 tokens somewhere. I've got a lot of stuff I can't find! This is the DOS 2.5 final code. It should assemble to what was distributed. Bob Hmmm. It looks like a few bits got toggled here & there... including bits in the directory sectors, so it's not just that the file contents are corrupt, the whole image is. Is the actual floppy messed up, when you try to load the files in Mac/65 on hardware? I mean, it isn't just an imaging error, is it? (Hoping it is, but somehow I doubt it...) I couldn't find any docs on Mac/65's tokenized file format, so I'm figuring it out the hard way... will take a while. Probably will start a new thread for it, document what I find out as I find it out, unless someone replies to this and says "You silly person, the Mac/65 file format is documented at (some URL)". Do you know whether this version of DOS 2.5 was the version that was released? If the disk weren't damaged, and you assembled it, would you get an exact copy of the DOS 2.5 that Atari used to sell? Quote Link to comment Share on other sites More sharing options...
ndary Posted September 1, 2008 Share Posted September 1, 2008 Here is the source code for DOS 2.5 that i have... maybe it will help OSS_Dos_2.5_Source.zip Quote Link to comment Share on other sites More sharing options...
+bob1200xl Posted September 2, 2008 Author Share Posted September 2, 2008 Hello, Nir! Yes, your code is OK. (seems to be, anyway...) Didn't you get it from me? Why is yours good and mine isn't? Quite strange... No matter - we have the source! Got anything else, NIr? Thanks, Bob *** try Nir's upload, folks! *** Here is the source code for DOS 2.5 that i have... maybe it will help OSS_Dos_2.5_Source.zip Quote Link to comment Share on other sites More sharing options...
ndary Posted September 2, 2008 Share Posted September 2, 2008 Hi Bob, i cant remember if i got it from your or from mike, anyway the reason it kept well is that i uploaded it to an .ATR file as soon as i got it. i will check what else i got and upload it. Quote Link to comment Share on other sites More sharing options...
Urchlay Posted September 10, 2008 Share Posted September 10, 2008 Has anyone else tried to build this source? I had to fiddle with it a bit... the best way I came up with was to assemble to memory, with an offset (.SET 6 in mac/65), then write a little program to take the in-memory image & turn it into boot sectors, DOS.SYS, and DUP.SYS on a new floppy. If anyone's interested, here's my set of instructions + utility program: build_dos_2.5_1.0.zip Quote Link to comment Share on other sites More sharing options...
ivop Posted October 20, 2012 Share Posted October 20, 2012 Here's a zipfile containing detokenized [1] .m65 files, slightly modified to assemble with atasm 1.07. I adjusted pathnames in FMS.m65, replaced labels starting with ':' and fixed @ORG and @ERROR macros to work with atasm. Assemble with: atasm FMS.m65 It only contains the FMS (DOS.SYS), I do not really care about DUP.SYS. [1] http://www.atariage....ze-mac65-files/ fms.zip Quote Link to comment Share on other sites More sharing options...
+kheller2 Posted October 20, 2012 Share Posted October 20, 2012 (edited) DOS 2.5 didn't come out until 85? Hard to imagine all the time I spent on 2.0s. What a bad few years for DOS 3 users, LOL. "DISK UTILITY PROGRAMS (DUP) VER 3.0 for DOS 2.5 01/10/85" FMS - Dual Density for Atari 1050 drives (2.50) --- Copyright and Author Notice --- Copyright © 1978,1979,1980,1982,1984 Optimized Systems Software, Incorporated. San Jose, California THIS PROGRAM MAY NOT BE REPRODUCED, STORED IN A RETRIEVAL SYSTEM, OR TRANSMITTED IN WHOLE OR IN PART IN ANY FORM, OR BY ANY MEANS, BE IT ELECTRONIC,MECHANICAL, PHOTOCOPYING, RECORDING, OR OTHERWISE WITHOUT THE PRIOR WRITTEN PERMISSION OF OPTIMIZED SYSTEMS SOFTWARE, INC. 1221-B KENTWOOD AVENUE SAN JOSE, CALIFORNIA 95129 (U.S.A.) PHONE: (408) 446-3099 *********************************** Originally designed and coded by Paul Laughton of Shepardson Microsystems, Inc. Modified for Atari 1050 and 130XE by Mark Rose & Bill Wilkinson of O.S.S., Inc. January, 1985 ******** Edited October 20, 2012 by kheller2 Quote Link to comment Share on other sites More sharing options...
ivop Posted October 25, 2012 Share Posted October 25, 2012 I adjusted pathnames in FMS.m65, replaced labels starting with ':' and fixed @ORG and @ERROR macros to work with atasm. In addition to that, I also changed an occurrence of DFDFL1+FILDIR to FILDIR+DFDFL1 because of a bug in atasm. atasm thinks you are addressing page zero (DFDFL1 = 0) and then segfaults during the second pass. Just added this information in case somebody decides to convert DUP.SYS and stumbles upon a similar problem. Quote Link to comment Share on other sites More sharing options...
ivop Posted November 18, 2012 Share Posted November 18, 2012 Oh well, here is DUP.SYS converted to assemble with atasm 1.07 dup.zip 1 Quote Link to comment Share on other sites More sharing options...
luckybuck Posted July 1, 2015 Share Posted July 1, 2015 Have made a recipe here: https://atariwiki.org/wiki/Wiki.jsp?page=Atari%20DOS%202.5%20Source%20Code Quote Link to comment Share on other sites More sharing options...
