Lord-Chaos Posted August 27, 2002 Share Posted August 27, 2002 Hi, I need technical information for repairing defective Lynx units : -schematics -maybe infos on well-known (age-related) problems I have lots of not-working units and I hope I can repair some of them. Thimo Quote Link to comment Share on other sites More sharing options...
Videology Posted August 28, 2002 Share Posted August 28, 2002 The best thing I can offer to you is to get yourself a working unit or two and make a test bed so you can do some side by side testing... Also this will help you as well. You can find some schematics here … http://www.atariage.com/Lynx/archives/sche...tics/index.html And the FAQ has a lot of good technical tidbits for you to chew on. Also check out the list of links listed at the end of the FAQ http://www.atariage.com/Lynx/faq/index.html Note that most of the info you will find is for the original Lynx I model. You will need to transfer what you learn for it and transfer the info over. There are a few technical differences between the two. Quote Link to comment Share on other sites More sharing options...
+karri Posted August 28, 2002 Share Posted August 28, 2002 I don't have any more solutions, but one common mistake seems to be that if the power-plug is put into the earphone socket then the sound circuits break and the sound becomes very faint. It would be ice to know which part gets bad. -- Karri Quote Link to comment Share on other sites More sharing options...
Lord-Chaos Posted August 31, 2002 Author Share Posted August 31, 2002 I don't have any more solutions, but one common mistake seems to be that if the power-plug is put into the earphone socket then the sound circuits break and the sound becomes very faint. It would be ice to know which part gets bad. -- Karri It´s worse when someone puts it in the Comlynx-port.This can happen,if you use no original power-supply. I think this happened to some of the units,because there are only 2 with sound problems. Thimo Quote Link to comment Share on other sites More sharing options...
