Primordial Ooze Posted October 20, 2008 Share Posted October 20, 2008 (edited) This code is being executed even when the first part becomes true. rem if the fire button is pressed rem and a missile hasn't been fired if !joy0fire && missileFired = 0 then skipjoy0fireandmissilenotfired rem set the missle in the same x position as the player missile1x = player0x + 5 rem set the missile in front of the player missile1y = player0y - 3 rem set missileFired to true missileFired = 1 rem if the fire button isn't pressed and a missilehasn't rem been fired the instructions are skipped to here skipjoy0fireandmissilenotfired Edited October 20, 2008 by Open Source Pong Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted October 20, 2008 Share Posted October 20, 2008 The answer is here: http://www.randomterrain.com/atari-2600-me...ommands.html#if You are allowed only one OR (||) for each if-then statement. You can use more than one AND (&&) in a line, but you cannot mix AND (&&) and OR (||). The NOT ( ! ) operator may only be used with statements that do not include a comparison token (such as =, <, >, or <>). Quote Link to comment Share on other sites More sharing options...
Primordial Ooze Posted October 20, 2008 Author Share Posted October 20, 2008 I tried this which should've work and fit all the rules but, it still doesn't work. if !joy0fire || missileFired then skipjoy0fireandmissilenotfired Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted October 20, 2008 Share Posted October 20, 2008 (edited) It's possible that batari had it a bit wrong. Seems you can use AND (&&) with NOT (!), but you can't use OR (||). I'll adjust the text. Edited October 20, 2008 by Random Terrain Quote Link to comment Share on other sites More sharing options...
Primordial Ooze Posted October 20, 2008 Author Share Posted October 20, 2008 So how should i rewrite this bit of code? Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted October 20, 2008 Share Posted October 20, 2008 So how should i rewrite this bit of code? If you're talking about this: if !joy0fire || missileFired then skipjoy0fireandmissilenotfired Then if two things won't work on the same line, seems like the easiest thing to do would be to put them on different lines: if !joy0fire then skipjoy0fireandmissilenotfired if missileFired then skipjoy0fireandmissilenotfired Quote Link to comment Share on other sites More sharing options...
SeaGtGruff Posted October 20, 2008 Share Posted October 20, 2008 So how should i rewrite this bit of code? I think this may do what you were trying to accomplish? dim missileFired = a if joy0fire then joy0fired if missileFired = 0 then skipjoy0fireandmissilenotfired joy0fired missile1x = player0x + 5 missile1y = player0y - 3 missileFired = 1 skipjoy0fireandmissilenotfired Michael Quote Link to comment Share on other sites More sharing options...
Primordial Ooze Posted October 23, 2008 Author Share Posted October 23, 2008 (edited) So how should i rewrite this bit of code? If you're talking about this: if !joy0fire || missileFired then skipjoy0fireandmissilenotfired Then if two things won't work on the same line, seems like the easiest thing to do would be to put them on different lines: if !joy0fire then skipjoy0fireandmissilenotfired if missileFired then skipjoy0fireandmissilenotfired I tried that and it still doesn't work. Here is my code: rem Planetary Wars rem a Rail Shootem up rem Updated: October 11, 2008 rem Website: http://planetarywars.freepgs.com rem includes rem include the 6 lives multikernal include 6lives.asm rem setup all the game variables rem varaible to hold if a missle has been fired dim missileFired = a rem set the rom size set romsize 4k rem set the tv format to NTSC set tv ntsc rem turn on smartbranching set smartbranching on rem kernel options rem enable no blank lines set kernel_options no_blank_lines rem set the color of the background to black COLUBK = 0 rem set the color of the playfield to light green COLUPF = 206 rem set the score field color scorecolor = 128 rem define the playfield playfield: ................................ X............................... XX.............................. XXX............................. XXX............................. XXX............................. XXX............................. XXX............................. XXX............................. XX.............................. X.............................. ................................ end rem enable the "High Definition" playfield hack pfscroll upup : pfscroll upup rem define player 1's sprite player0: %11100000 %11110000 %00001000 %11111111 %11111111 %00001000 %11110000 %11100000 end rem define the enemy sprite player1: %00000000 %00000000 %00011000 %00111100 %01111110 %00111100 %00011000 %00000000 end rem set the lives color to blue lifecolor = 128 rem define player 1's missle height missile1height=1 rem start a new game startNewGame rem reset player's score to 0 score = 0 rem reset the number of lives to 3 lives = 96 rem define the lives counter lives: %00011000 %00111100 %01111110 %01111110 %01111110 %01111110 %01111110 %01111110 end rem set player'1 inital x position player0x = 20 rem set player'1 inital y position player0y = 44 rem set the enemie's initial x position off screen player1x = 150 rem set the enemie's initial y position off screen player1y = 40 rem set the missle off screen missile1x=0 missile1y=0 rem set missle fired to false missileFired = 0 gameLoop rem if the reset switch is pressed, start a new game if switchreset then startNewGame rem set player 1's color to white COLUP0 = 14 rem set the enimie's color to grey COLUP1 = 10 rem if the left joystick is pushed up, move player 1 up if joy0up then player0y = player0y - 1 rem make sure the player doesn't go off the top of the screen if player0y < 9 then player0y = 9 rem if the left joystick is pushed down, move player 1 down if joy0down then player0y = player0y + 1 rem make sure the player doesn't go off the bottom of the screen if player0y > 87 then player0y = 87 rem if the fire button is pressed jump to rem skipjoy0fireormissilenotfired if !joy0fire then skipjoy0fireormissilenotfired rem if a missile has been fired jump to rem skipjoy0fireormissilenotfired if missileFired = 1 then skipjoy0fireormissilenotfired rem set the missle in the same x position as the player missile1x = player0x + 5 rem set the missile in front of the player missile1y = player0y - 3 rem set missileFired to true missileFired = 1 rem if the fire button isn't pressed the instructions rem are skipped to here skipjoy0fireormissilenotfired rem if the missle was fired "annimate" the missle if missileFired = 1 then missile1x = missile1x + 1 rem if the missle goes off screen if missile1x > 158 then skipmissileoffscreen rem hide the missle off screen missile1x = 0 missile1y = 0 rem and set missileFired to false missileFired = 0 rem if the missile isn't off screen rem the instructions are skipped to here skipmissileoffscreen rem animate the enimie player1x = player1x - 1 rem if the asteroid hits the planet the player loses a life and the asteroid rem is destroyed as well otherwise skip the instructions if !collision(player1,playfield) then skipplayer1playfieldcollision rem take 1 life from the player lives = lives - 32 rem place the enimie at the starting location right of the screen player1x = 154 rem set the enimes new y position randomly tryagain01 rem generate a random number r=rand rem if the number is too small or too big regenerate the number if r < 8 || r > 84 then tryagain01 rem set the players y position based on the new random number player1y = r rem if the player doesn't collide with the playfield the instructions rem are skipped to here skipplayer1playfieldcollision rem if the player's missle hit the enemie asteroid destroy rem move the missile off screen and give the player 5 points rem otherwise skip these instructions if !collision(missile1,player1) then skipmissile1player1collision rem move the missile offscreen missile1x = 0 missile1y = 0 rem reset the missile filed variable missileFired = 0 rem place the enimie at the starting location right of the screen player1x = 154 rem set the enimes new y position randomly tryagain02 rem generate a random number r=rand rem if the number is too small or too big regenerate the number if r < 8 || r > 84 then tryagain02 rem set the players y position based on the new random number player1y = r rem and increment the score by 5 points score = score + 5 skipmissile1player1collision rem if the player is out of lives go to the game over screen if lives < 32 then gameOver rem draw the screen drawscreen goto gameLoop rem Game Over Screen gameOver rem hide the missiles missile1x = 0 missile1y = 0 gameOverLoop rem if the reset switch is pressed, start a new game if switchreset then startNewGame rem if the joystick is moved start a new game if joy0up then startNewGame if joy0down then startNewGame if joy0left then startNewGame if joy0rightt then startNewGame rem set player 1's color to white COLUP0 = 14 rem set the enimie's color to grey COLUP1 = 10 rem draw the screen drawscreen goto gameOverLoop Any ideas? Thanks, Open Source Pong Edited October 23, 2008 by Open Source Pong Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted October 23, 2008 Share Posted October 23, 2008 It looks like your whole problem is here: rem if the missle was fired "annimate" the missle if missileFired = 1 then missile1x = missile1x + 1 rem if the missle goes off screen if missile1x > 158 then skipmissileoffscreen Try this: rem Planetary Wars rem a Rail Shootem up rem Updated: October 11, 2008 rem Website: http://planetarywars.freepgs.com rem includes rem include the 6 lives multikernal include 6lives.asm rem setup all the game variables rem varaible to hold if a missle has been fired dim missileFired = a rem set the rom size set romsize 4k rem set the tv format to NTSC set tv ntsc rem turn on smartbranching set smartbranching on rem kernel options rem enable no blank lines set kernel_options no_blank_lines rem set the color of the background to black COLUBK = 0 rem set the color of the playfield to light green COLUPF = 206 rem set the score field color scorecolor = 128 rem define the playfield playfield: ................................ X............................... XX.............................. XXX............................. XXX............................. XXX............................. XXX............................. XXX............................. XXX............................. XX.............................. X.............................. ................................ end rem enable the "High Definition" playfield hack pfscroll upup : pfscroll upup rem define player 1's sprite player0: %11100000 %11110000 %00001000 %11111111 %11111111 %00001000 %11110000 %11100000 end rem define the enemy sprite player1: %00000000 %00000000 %00011000 %00111100 %01111110 %00111100 %00011000 %00000000 end rem set the lives color to blue lifecolor = 128 rem define player 1's missle height missile1height=1 rem start a new game startNewGame rem reset player's score to 0 score = 0 rem reset the number of lives to 3 lives = 96 rem define the lives counter lives: %00011000 %00111100 %01111110 %01111110 %01111110 %01111110 %01111110 %01111110 end rem set player'1 inital x position player0x = 20 rem set player'1 inital y position player0y = 44 rem set the enemie's initial x position off screen player1x = 150 rem set the enemie's initial y position off screen player1y = 40 rem set the missle off screen missile1x=0 missile1y=0 rem set missle fired to false missileFired = 0 gameLoop rem if the reset switch is pressed, start a new game if switchreset then startNewGame rem set player 1's color to white COLUP0 = 14 rem set the enimie's color to grey COLUP1 = 10 rem if the left joystick is pushed up, move player 1 up if joy0up then player0y = player0y - 1 rem make sure the player doesn't go off the top of the screen if player0y < 9 then player0y = 9 rem if the left joystick is pushed down, move player 1 down if joy0down then player0y = player0y + 1 rem make sure the player doesn't go off the bottom of the screen if player0y > 87 then player0y = 87 rem if the fire button is pressed jump to rem skipjoy0fireormissilenotfired if !joy0fire then skipjoy0fireormissilenotfired rem if a missile has been fired jump to rem skipjoy0fireormissilenotfired if missileFired = 1 then skipjoy0fireormissilenotfired rem set the missle in the same x position as the player missile1x = player0x + 5 rem set the missile in front of the player missile1y = player0y - 3 rem set missileFired to true missileFired = 1 rem if the fire button isn't pressed the instructions rem are skipped to here skipjoy0fireormissilenotfired rem if the missle goes off screen if missile1x < 159 then skipmissileoffscreen rem hide the missle off screen missile1x = 0 missile1y = 0 rem and set missileFired to false missileFired = 0 rem if the missile isn't off screen rem the instructions are skipped to here skipmissileoffscreen rem if the missle was fired "annimate" the missle if missileFired = 1 then missile1x = missile1x + 1 rem animate the enimie player1x = player1x - 1 rem if the asteroid hits the planet the player loses a life and the asteroid rem is destroyed as well otherwise skip the instructions if !collision(player1,playfield) then skipplayer1playfieldcollision rem take 1 life from the player lives = lives - 32 rem place the enimie at the starting location right of the screen player1x = 154 rem set the enimes new y position randomly tryagain01 rem generate a random number r=rand rem if the number is too small or too big regenerate the number if r < 8 || r > 84 then tryagain01 rem set the players y position based on the new random number player1y = r rem if the player doesn't collide with the playfield the instructions rem are skipped to here skipplayer1playfieldcollision rem if the player's missle hit the enemie asteroid destroy rem move the missile off screen and give the player 5 points rem otherwise skip these instructions if !collision(missile1,player1) then skipmissile1player1collision rem move the missile offscreen missile1x = 0 missile1y = 0 rem reset the missile filed variable missileFired = 0 rem place the enimie at the starting location right of the screen player1x = 154 rem set the enimes new y position randomly tryagain02 rem generate a random number r=rand rem if the number is too small or too big regenerate the number if r < 8 || r > 84 then tryagain02 rem set the players y position based on the new random number player1y = r rem and increment the score by 5 points score = score + 5 skipmissile1player1collision rem if the player is out of lives go to the game over screen if lives < 32 then gameOver rem draw the screen drawscreen goto gameLoop rem Game Over Screen gameOver rem hide the missiles missile1x = 0 missile1y = 0 gameOverLoop rem if the reset switch is pressed, start a new game if switchreset then startNewGame rem if the joystick is moved start a new game if joy0up then startNewGame if joy0down then startNewGame if joy0left then startNewGame if joy0rightt then startNewGame rem set player 1's color to white COLUP0 = 14 rem set the enimie's color to grey COLUP1 = 10 rem draw the screen drawscreen goto gameOverLoop planetary_wars_2008y_10m_22d_2315t.bas Quote Link to comment Share on other sites More sharing options...
