+Random Terrain Posted October 24, 2008 Share Posted October 24, 2008 Your inbox is full, so I'll ask you here. I wanted to double check and be absolutely sure I'm doing the correct thing. The zip file in the post below has an std_kernel.asm file from 12/28/2007: http://www.atariage.com/forums/index.php?s...p;#entry1490744 The zip file in the post below has an std_kernel.asm file from 12/20/2007: http://www.atariage.com/forums/index.php?s...t&p=1430601 When you get a chance, can you take a look at them and see which one should really be used? It's been a while, but I think I remember that the version with the earlier date actually worked better. I'm probably wrong, though. Just want to remove all doubt. Thanks. Quote Link to comment Share on other sites More sharing options...
SeaGtGruff Posted October 24, 2008 Share Posted October 24, 2008 The zip file in the post below has an std_kernel.asm file from 12/28/2007: http://www.atariage.com/forums/index.php?s...p;#entry1490744 The zip file in the post below has an std_kernel.asm file from 12/20/2007: http://www.atariage.com/forums/index.php?s...t&p=1430601 When you get a chance, can you take a look at them and see which one should really be used? It's been a while, but I think I remember that the version with the earlier date actually worked better. I'm probably wrong, though. Just want to remove all doubt. I'm not sure which one is better to use, but the 12/20/2007 file (from batari's post) has references to "kernelmacro" in it, whereas the 12/28/2007 file (from my post) does not-- and there are a few other differences, as well. I checked in my includes folder, and I've been using the 12/28/2007 file for nearly a year without any problems. I guess it depends on if you're going to use "kernelmacro" or not? Michael Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted October 24, 2008 Author Share Posted October 24, 2008 Thanks. Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted November 2, 2008 Author Share Posted November 2, 2008 When you get a chance, please look at this post: http://www.atariage.com/forums/index.php?s...t&p=1612952 Thanks. Quote Link to comment Share on other sites More sharing options...
