Primordial Ooze Posted October 28, 2008 Share Posted October 28, 2008 I was told that the atari 2600 couldn't handle alot of instructions. My code is as follows: rem 2600 De Amigo rem a Samba De Amimo clone for the 2600 rem Updated: October 11, 2008 rem Website: http://planetarydefense.freepgs.com rem includes rem 6 lives kernal rem include 6lives.asm rem setup all the game variables rem variable to hold note direction dim notedirection = a rem set the rom size set romsize 4k rem set the tv format to NTSC set tv ntsc rem turn on smartbranching set smartbranching on rem kernel options rem enable no blank lines set kernel_options no_blank_lines rem set the color of the background to white COLUBK = 0 rem set the playfield color to black COLUPF = 14 rem set the score field color scorecolor = 128 rem set the color of the miss counter lifecolor = 66 rem define the playfield playfield: ................................ ................................ ................X............... ................................ ................................ ................................ ........X..............X........ ................................ ................................ ................X............... ................................ ................................ end rem enable the "High Definition" playfield hack pfscroll upup : pfscroll upup rem define first note sprite player0: %00111100 %00111100 %00111100 %00111100 %00111100 %00111100 %00111100 %00111100 end rem define second note sprite player1: %00000000 %00000000 %00111100 %00111100 %00111100 %00111100 %00000000 %00000000 end rem start a new game startNewGame rem start the player with 0 strikes lives = 0 rem define the miss counter lives: %00000000 %01000010 %00100100 %00011000 %00011000 %00100100 %01000010 %00000000 end rem reset player's score to 0 score = 0 rem set first note's inital x position off screen player0x = 79 rem set first note's inital y position off screen player0y = 51 rem set second note's initial x position off screen player1x = 0 rem set the enemie's initial y position off screen player1y = 0 rem set the note's initial direction to 0 (none) notedirection = 1 gameLoop rem if the reset switch is pressed, start a new game if switchreset then startNewGame rem set first note's color to white COLUP0 = 14 rem set second note's color to white COLUP1 = 14 rem move the note cue based on the notes direction rem if notedirection is 1(up) move the note cue up if notedirection = 1 then player0y = player0y - 1 rem if notedirection is 2(down) move the note cue down if notedirection = 2 then player0y = player0y + 1 rem if notedirection is 3(left) move the note cue left if notedirection = 3 then player0x = player0x - 1 rem if notedirection is 4(left) move the note cue right if notedirection = 4 then player0x = player0x + 1 rem if the notedirection is up(1) rem on the joystick while it is colliding with the playfield rem give the user 5 points if !collision(player0, playfield) then skipplayerscoresup if !joy0up then skipplayerscoresup if notedirection <> 1 then skipplayerscoresup rem player gains 1 point score = score + 1 rem move the arrow back to the center player0x = 79 player0y = 51 rem if the player doesn't score on the up arrow then the rem instructions are skipped to here skipplayerscoresup rem if the player misses the up note then give the rem player a miss if player0y > 16 then skipmissup rem if the player misses the up note then give the rem player a miss lives = lives + 32 rem move the arrow back to the center player0x = 79 player0y = 51 skipmissup rem if the notedirection is down(2) and the joystick is rem down while it is colliding with the playfield rem give the user 5 points if !collision(player0, playfield) then skipplayerscoresdown if !joy0down then skipplayerscoresdown if notedirection <> 2 then skipplayerscoresdown rem player gains 1 point score = score + 1 rem move the arrow back to the center player0x = 79 player0y = 51 rem if the player doesn't score on the down arrow then the rem instructions are skipped to here skipplayerscoresdown rem if the player misses the down note then give the rem player a miss if player0y < 78 then skipmissdown rem if the player misses the down note then give the rem player a miss lives = lives + 32 rem move the arrow back to the center player0x = 79 player0y = 51 skipmissdown rem if the notedirection is left(3) and the joystick is rem left while it is colliding with the playfield rem give the user 5 points if !collision(player0, playfield) then skipplayerscoresleft if !joy0left then skipplayerscoresleft if notedirection <> 3 then skipplayerscoresleft rem player gains 1 point score = score + 1 rem move the arrow back to the center player0x = 79 player0y = 51 rem if the player doesn't score on the left arrow then the rem instructions are skipped to here skipplayerscoresleft rem if the player misses the left note then give the rem player a miss if player0x > 44 then skipmissleft rem if the player misses the left note then give the rem player a miss lives = lives + 32 rem move the arrow back to the center player0x = 79 player0y = 51 skipmissleft rem if the notedirection is right(4) and the joystick is rem rightt while it is colliding with the playfield rem give the user 5 points if !collision(player0, playfield) then skipplayerscoresright if !joy0right then skipplayerscoresright if notedirection <> 4 then skipplayerscoresright rem player gains 1 point score = score + 1 rem move the arrow back to the center player0x = 79 player0y = 51 rem if the player doesn't score on the right arrow then the rem instructions are skipped to here skipplayerscoresright rem if the player misses the rightt note then give the rem player a miss if player0x < 109 then skipmissright rem if the player misses the right note then give the rem player a miss lives = lives + 32 rem move the arrow back to the center player0x = 79 player0y = 51 skipmissright rem if the player misses 3 times it's game over if lives > 64 then gameOver rem draw the screen drawscreen goto gameLoop rem Game Over Screen gameOver gameOverLoop rem if the reset switch is pressed, start a new game if switchreset then startNewGame rem if the joystick fire button is pressed start a new game if joy0fire then startNewGame rem set first note's color to white COLUP0 = 14 rem set second note's color to white COLUP1 = 14 rem draw the screen drawscreen goto gameOverLoop if i repeat this code and modify it for the right joystick rem if the notedirection is up(1) rem on the joystick while it is colliding with the playfield rem give the user 5 points if !collision(player0, playfield) then skipplayerscoresup if !joy0up then skipplayerscoresup if notedirection <> 1 then skipplayerscoresup rem player gains 1 point score = score + 1 rem move the arrow back to the center player0x = 79 player0y = 51 rem if the player doesn't score on the up arrow then the rem instructions are skipped to here skipplayerscoresup rem if the player misses the up note then give the rem player a miss if player0y > 16 then skipmissup rem if the player misses the up note then give the rem player a miss lives = lives + 32 rem move the arrow back to the center player0x = 79 player0y = 51 skipmissup rem if the notedirection is down(2) and the joystick is rem down while it is colliding with the playfield rem give the user 5 points if !collision(player0, playfield) then skipplayerscoresdown if !joy0down then skipplayerscoresdown if notedirection <> 2 then skipplayerscoresdown rem player gains 1 point score = score + 1 rem move the arrow back to the center player0x = 79 player0y = 51 rem if the player doesn't score on the down arrow then the rem instructions are skipped to here skipplayerscoresdown rem if the player misses the down note then give the rem player a miss if player0y < 78 then skipmissdown rem if the player misses the down note then give the rem player a miss lives = lives + 32 rem move the arrow back to the center player0x = 79 player0y = 51 skipmissdown rem if the notedirection is left(3) and the joystick is rem left while it is colliding with the playfield rem give the user 5 points if !collision(player0, playfield) then skipplayerscoresleft if !joy0left then skipplayerscoresleft if notedirection <> 3 then skipplayerscoresleft rem player gains 1 point score = score + 1 rem move the arrow back to the center player0x = 79 player0y = 51 rem if the player doesn't score on the left arrow then the rem instructions are skipped to here skipplayerscoresleft rem if the player misses the left note then give the rem player a miss if player0x > 44 then skipmissleft rem if the player misses the left note then give the rem player a miss lives = lives + 32 rem move the arrow back to the center player0x = 79 player0y = 51 skipmissleft rem if the notedirection is right(4) and the joystick is rem rightt while it is colliding with the playfield rem give the user 5 points if !collision(player0, playfield) then skipplayerscoresright if !joy0right then skipplayerscoresright if notedirection <> 4 then skipplayerscoresright rem player gains 1 point score = score + 1 rem move the arrow back to the center player0x = 79 player0y = 51 rem if the player doesn't score on the right arrow then the rem instructions are skipped to here skipplayerscoresright rem if the player misses the rightt note then give the rem player a miss if player0x < 109 then skipmissright rem if the player misses the right note then give the rem player a miss lives = lives + 32 rem move the arrow back to the center player0x = 79 player0y = 51 skipmissright Will it be too much for the atari to handle or would it be ok? If i can add this code, how much "breathing space" would i have? Sincerely, Open Source Pong Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted October 28, 2008 Share Posted October 28, 2008 If you're talking about space for your code and you use Visual batari Basic, the Information Pane tells you how much space is left after compiling. If you run out of room, you can use bankswitching. If you're talking about using too many cycles, the info under Timing on the following page tells you how you can use Stella to make sure you're not using too many cycles: http://www.randomterrain.com/atari-2600-me...nds.html#timing Quote Link to comment Share on other sites More sharing options...
