Primordial Ooze Posted November 2, 2008 Share Posted November 2, 2008 (edited) What would be the best way to determine if a variable is a multiple of 50: 50, 100, 150, 200, 250 I planned on using code like so: if a = 50 || a = 100 || a = 150 || a = 200 || a = 250 then bla However i don't know if batari basic can handle such a large if statement or if the if statement would take too many cycles. Then i considered this: if a % 2 = 1 then bla However i know the atari 2600 isn't very good with muliplication or division. Any ideas? Sincerely, Open Source Pong Edited November 2, 2008 by Open Source Pong Quote Link to comment Share on other sites More sharing options...
SeaGtGruff Posted November 2, 2008 Share Posted November 2, 2008 What would be the best way to determine if a variable is a multiple of 50:50, 100, 150, 200, 250 I planned on using code like so: if a = 50 || a = 100 || a = 150 || a = 200 || a = 250 then bla However i don't know if batari basic can handle such a large if statement or if the if statement would take too many cycles. Then i considered this: if a % 2 = 1 then bla However i know the atari 2600 isn't very good with muliplication or division. Any ideas? Sincerely, Open Source Pong You can't put that many ors in a single if. The way I usually do something like that is to divide by 50 (or whatever), then multiply the answer by 50 to see if I get the same number: include div_mul.asm a = 55 b = 50 * (a / 50) if a = b then goto a_is_multiple_of_50 rem * on a computer you would have to use the integer function rem * b = 50 * int(a / 50) rem * but batari Basic already returns integers Michael Quote Link to comment Share on other sites More sharing options...
Primordial Ooze Posted November 2, 2008 Author Share Posted November 2, 2008 (edited) Doesn't quite work like i expected, my combo variable starts at 0 and then increments by 1 for each consecutively correct input until the player misses at which point it resets to 0. So: rem divide the total combo by 50 then divide it by rem 50 and see if it is a multiple of 50 temp1 = 50 * (combo / 50) rem if it is a multiple of 50 and the player doesn't rem have 7 lives already then give the player an rem extra bar if combo = temp1 && lives < 224 then lives = lives + 32 Will multiply 0 by 50 and then try to divide it by 0 which will cause the game to give the player full lives when it first starts and after the player misses and the combo is reset to 0. Any ideas? Sincerely, Open Source Pong Edited November 2, 2008 by Open Source Pong Quote Link to comment Share on other sites More sharing options...
ZylonBane Posted November 2, 2008 Share Posted November 2, 2008 Multiplication and division are extremely slow on the 6507. It would be helpful to know *why* you need to know if something is a multiple of 50, so that a less general-purpose solution can be devised. For example, if your values will never be higher than 250, and ROM space isn't critical, five comparison operations would be the fastest approach. if a = 50 then gosub bla if a = 150 then gosub bla etc... Quote Link to comment Share on other sites More sharing options...
+batari Posted November 2, 2008 Share Posted November 2, 2008 For something like this, you only have 5 numbers to check, so I'd just use this seemingly unimaginative code: if a=50 then bla if a=100 then bla if a=150 then bla if a=200 then bla if a=250 then bla If you place "bla" fairly close to these statements, it will take 30 bytes and anywhere from 8-37 cycles. If "bla" is far away from these statements, you're looking at 45 bytes and 11-40 cycles. Quote Link to comment Share on other sites More sharing options...
supercat Posted November 2, 2008 Share Posted November 2, 2008 For something like this, you only have 5 numbers to check, so I'd just use this seemingly unimaginative code: if a=50 then bla if a=100 then bla if a=150 then bla if a=200 then bla if a=250 then bla If you place "bla" fairly close to these statements, it will take 30 bytes and anywhere from 8-37 cycles. If "bla" is far away from these statements, you're looking at 45 bytes and 11-40 cycles. Alternatively, something like: lp: if a>=50 then a=a-50:goto lp ' If a is zero, then we're happy In assembly language, such an approach can result in fast and compact code: sec lda _a lp: sbc #50 bcs lp adc #50 ; Acc will equal zero (and Z flag will be set) if A was a multiple of 50. ; Carry will be set regardless. Worst-case time will be 36 cycles (5*5 for the branch repeats, plus 11). Nine bytes. Not sure how bB will do. Probably not that good, but not too totally horrible. Maybe something like: lp: lda _a cmp #50 bcc done lda _a sec sbc #50 sta _a jmp lp done: lda _a ; Zero if was a multiple of 50 Eighteen bytes if there are no optimizations. I think 19 cycles per loop, plus 11, for a total of 106. Not nearly as good as the worst-case time for the assembly-code approach, but not totally horrible. Quote Link to comment Share on other sites More sharing options...
+batari Posted November 2, 2008 Share Posted November 2, 2008 (edited) I tried Supercat's code in bB: lp if a>=50 then a=a-50:goto lp if !a then bla I get 20 bytes, but 12-112 cycles. So what to use depends on if you prefer space over cycles. Edited November 2, 2008 by batari Quote Link to comment Share on other sites More sharing options...
Primordial Ooze Posted November 2, 2008 Author Share Posted November 2, 2008 (edited) Small Problem: rem if the player has a 50, 100, rem 150, 200, or 250 combo streak rem then give him a life if combo = 50 && lives < 228 then lives = lives + 32 if combo = 100 && lives < 228 then lives = lives + 32 if combo = 150 && lives < 228 then lives = lives + 32 if combo = 200 && lives < 228 then lives = lives + 32 if combo = 250 && lives < 228 then lives = lives + 32 Does what i want with one hitch. It maxes the player's lives at 7 instead of just giving him just one. Any ideas why? Sincerely, Open Source Pong Edited November 3, 2008 by Open Source Pong Quote Link to comment Share on other sites More sharing options...
ZylonBane Posted November 3, 2008 Share Posted November 3, 2008 A-HA! So that's what you're doing. In that case, why not just: if combo = nextbonus then nextbonus = nextbonus + 50: bla Where nextbonus is initialized to 50 when the game starts. Or, if the combo count isn't actually displayed or used anywhere else: if combo = 50 then combo = 0: bla Quote Link to comment Share on other sites More sharing options...
