Inky Posted November 8, 2008 Share Posted November 8, 2008 I downloaded the latest MAMEUI32 (.128u2) and for whatever reason I cannot get the new cheat system enabled. I know they revamped the thing, but I cant for the life of me figure out how to get the .zip the xml files are in to be recognized. Any ideas? Quote Link to comment Share on other sites More sharing options...
Tafoid Posted November 9, 2008 Share Posted November 9, 2008 I downloaded the latest MAMEUI32 (.128u2) and for whatever reason I cannot get the new cheat system enabled. I know they revamped the thing, but I cant for the life of me figure out how to get the .zip the xml files are in to be recognized. Any ideas? Anything MAME 0.127 or later requires a new XML style cheat format. The old "cheat.dat" file can be used for any version prior. You can get the latest cheat XML archive from Pugsy's Cheat Forum - in particular, this link: http://cheat.retrogames.com/forums/viewtopic.php?t=3110 Just take the CHEAT.ZIP file out of the downloaded archive and place it in the root of your MAME install - in the same folder as MAME.EXE. Like before, the -cheat command-line trigger will allow you to have the CHEAT item come up in your TAB menu while emulation is running. Quote Link to comment Share on other sites More sharing options...
Inky Posted November 9, 2008 Author Share Posted November 9, 2008 I dunno what happened, but I had to uninstall mame, then reinstall it (same version) and now it works. Quote Link to comment Share on other sites More sharing options...
toolerman Posted November 14, 2008 Share Posted November 14, 2008 I dunno what happened, but I had to uninstall mame, then reinstall it (same version) and now it works. I am experiencing the same issue, on both 127 and 128 (the 32 bit UI versions, downloaded from http://mameui.classicgaming.gamespy.com/. I retried 126, and the cheats are still there. When you say "Uninstall", how did you do it - just delete the MAMEUI32.exe, or also go into the registry to delete keys? I tried just deleting the .exe and reinstalling, but had the same problem. When using 127 or 128, I confirmed that the "Options", "Directories...", "cheats" directory is the location where the cheat.zip is located. However, when I select "Options", "Cheat file...", no window pops up to select the location - unlike when I select "history file..." or "info file...". Any help/assistance would be appreciated... Quote Link to comment Share on other sites More sharing options...
Inky Posted November 14, 2008 Author Share Posted November 14, 2008 I installed MAME into a fresh directory then moved the roms folder and the new cheat zip from the old to the new, and it worked (Oh an I deleted the old directory afterwards) Quote Link to comment Share on other sites More sharing options...
