Gorf Posted November 18, 2008 Share Posted November 18, 2008 (edited) http://www.atariage.com/forums/index.php?s...=0#entry1622981 Edited November 18, 2008 by Gorf Quote Link to comment Share on other sites More sharing options...
Underball Posted November 18, 2008 Share Posted November 18, 2008 can this be used on existing .bin or .a78 rom files? Quote Link to comment Share on other sites More sharing options...
Gorf Posted November 18, 2008 Author Share Posted November 18, 2008 can this be used on existing .bin or .a78 rom files? If you are asking me if this is a graphics ripper, no and it will never be. It is for designing original, from scratch character and sprite maps. It will then output the info in asm text form for an 'include' into your code. The character maps default a $c000 and the sprites at $a000 but you can simply edit the first 'org' to where ever you might want to put the map. It will allow you to export sprites and characters made with this app so you can share sprites and characters from other maps via the sprite import command. It will also let you export and import color palette data from one sprite/character map to another. I cant and wont ever allow the loading of exsisting roms for ripping. Quote Link to comment Share on other sites More sharing options...
gambler172 Posted November 18, 2008 Share Posted November 18, 2008 Hi Gorf Tried it on Windows XP.The program loads,i can move the white dot.But nothing more.I cannot load the example and i cannot draw any sprite.Maybe Windows XP does not work?Or how can i make a sprite? greetings Walter Quote Link to comment Share on other sites More sharing options...
Gorf Posted November 18, 2008 Author Share Posted November 18, 2008 Hi GorfTried it on Windows XP.The program loads,i can move the white dot.But nothing more.I cannot load the example and i cannot draw any sprite.Maybe Windows XP does not work?Or how can i make a sprite? greetings Walter Use the L key to load. S key to save...I will be posting a working version as soon as I figure out why MFC42.DLL is being a pain in the ass. See the included 'CharMapper78.txt' file for more. Quote Link to comment Share on other sites More sharing options...
gambler172 Posted November 19, 2008 Share Posted November 19, 2008 Hi GorfTried it on Windows XP.The program loads,i can move the white dot.But nothing more.I cannot load the example and i cannot draw any sprite.Maybe Windows XP does not work?Or how can i make a sprite? greetings Walter Use the L key to load. S key to save...I will be posting a working version as soon as I figure out why MFC42.DLL is being a pain in the ass. See the included 'CharMapper78.txt' file for more. Hi Gorf Yes,this works.I can load the example now. greetings Walter Quote Link to comment Share on other sites More sharing options...
Gorf Posted November 20, 2008 Author Share Posted November 20, 2008 Hi GorfTried it on Windows XP.The program loads,i can move the white dot.But nothing more.I cannot load the example and i cannot draw any sprite.Maybe Windows XP does not work?Or how can i make a sprite? greetings Walter Use the L key to load. S key to save...I will be posting a working version as soon as I figure out why MFC42.DLL is being a pain in the ass. See the included 'CharMapper78.txt' file for more. Hi Gorf Yes,this works.I can load the example now. greetings Walter I posted a debug build version in the 7800 programming section that seems to be working. You will need to download tht MS run- time DLL's and install them however. Quote Link to comment Share on other sites More sharing options...
