simbalion Posted December 5, 2008 Share Posted December 5, 2008 (edited) I got all three of my Atari systems out for some nice winter retro gaming, including my beloved 5200 and its trackball controller. I was playing some Centipede and noticed a game ruining problem with the controller when playing. Going left is no problem, but if one tries to go right or up and to the right, the trackball crashes around inside the case instead of rolling smoothly. I opened the controller up to make sure there was no dirt on the rollers. They were fine, but the little bearings were a bit dry. (Really nice design!) I put a drop of Zoom Spout oil on each bearing and that helped there. The trackball is still too loose in the case and the rollers don't look worn. Was there something besides the fit of the case that helped to keep the ball more in place? Edited December 5, 2008 by simbalion Quote Link to comment Share on other sites More sharing options...
Prodos8 Posted December 5, 2008 Share Posted December 5, 2008 Gravity (and you pushing down) is all that holds the ball in place. It would have been better if they'd gone with a larger (heavier) ball though. Just make sure the rollers and ball are clean and the bearings are lubed for best results. Quote Link to comment Share on other sites More sharing options...
phuzzed Posted December 5, 2008 Share Posted December 5, 2008 Mine too is loose. Like ProDos, I feel like Atari could have used a slightly bigger and heavier ball. Quote Link to comment Share on other sites More sharing options...
cyberfluxor Posted December 5, 2008 Share Posted December 5, 2008 For best results keep your trak-ball controller on a solid surface (like a table top) and bear down a little more when thrusting in a direction. It doesn't work great when sitting in your lap and slinging the ball around. I have a few arcade trackballs around the house, wonder if there's a way to modify the controller to use them as I doubt the standard parts can handle a full weighted arcade ball. Quote Link to comment Share on other sites More sharing options...
BigO Posted December 5, 2008 Share Posted December 5, 2008 (edited) For best results keep your trak-ball controller on a solid surface (like a table top) and bear down a little more when thrusting in a direction. It doesn't work great when sitting in your lap and slinging the ball around. I have a few arcade trackballs around the house, wonder if there's a way to modify the controller to use them as I doubt the standard parts can handle a full weighted arcade ball. The parts in there aren't what I'd call light-duty. They're full ball-bearing with all axles and driven shafts being steel or brass. I don't know how that compares to an arcade quality unit, but I think the 5200 parts would be fairly difficult to mechanically damage. Edited December 5, 2008 by BigO Quote Link to comment Share on other sites More sharing options...
Texasmame Posted December 5, 2008 Share Posted December 5, 2008 For best results keep your trak-ball controller on a solid surface (like a table top) and bear down a little more when thrusting in a direction. It doesn't work great when sitting in your lap and slinging the ball around. I have a few arcade trackballs around the house, wonder if there's a way to modify the controller to use them as I doubt the standard parts can handle a full weighted arcade ball. The parts in there aren't what I'd call light-duty. They're full ball-bearing with all axles and driven shafts being steel or brass. I don't know how that compares to an arcade quality unit, but I think the 5200 parts would be fairly difficult to mechanically damage. Ditto. I remember the first time I opened one up - arcade quality all the way. I wonder if that guy's shafts are getting worn down. I'd be shocked since the only place you usually see that is on arcade games (especially the full-size Missile Command ball) due to the long, hard usage. Enough innuendo in that last paragraph for everyone? Quote Link to comment Share on other sites More sharing options...
bohoki Posted December 5, 2008 Share Posted December 5, 2008 the balls really should have been more captive meaning bearings holding it down into the unit because some games require violent acti0on and the ball kind of hops up and clatters against the top (same with the 2600 ball) but economics comes into play with consumer items and we get products that barely work and are affordable to use a missile command or centipede arcade ball would have driven the cost of the the item to near $300 but it would have been cool to have arcade buttons and spiffy atari cone buttons glowing start pause reset with green yellow red leds Quote Link to comment Share on other sites More sharing options...
Prodos8 Posted December 5, 2008 Share Posted December 5, 2008 It would probably be possible to rig up some spring loaded bearings on the top of the case to keep the ball from riding up on the rollers. I've also noticed the ball on mine isn't perfectly round, which probably would contribute to it riding up on the rollers. I believe its a 2.25 inch ball and I've thought about purchasing a replacement for it from time to time. Quote Link to comment Share on other sites More sharing options...
simbalion Posted December 7, 2008 Author Share Posted December 7, 2008 Thanks for the advice. I was just wondering if there had been some sort of padding that helped is all. Even NOS stuff with that 1980's foam always seems to lose that padding from age. I know cars from the 80's will blow foam all over you from the air conditioner. Quote Link to comment Share on other sites More sharing options...
ninermaniac Posted December 7, 2008 Share Posted December 7, 2008 long, hard usage. He said long hard usage. he he hehehe. Quote Link to comment Share on other sites More sharing options...
TornadoTJ Posted January 6, 2009 Share Posted January 6, 2009 I've had to rebuild mine twice over the last 15 years of use (I got it used). Mine usually ends up being the bearings are dry, as stated before. Other than that, it works great. If I didn't have it, I probably wouldn't even have a 5200. Quote Link to comment Share on other sites More sharing options...
BIGHMW Posted January 10, 2009 Share Posted January 10, 2009 (edited) I have owned two 5200 trak-ball controllers (two meaning for two-player games) since I first got my system back in 1983, and while I might have had issues with them back then, as far as them "riding up" toward the base, there is also another issue I am sure all fellow Atarians have had to put up with occasionally on our CX53 trak-ball controllers. The only other issue I have had is with those "bubble-click" style fire buttons not responding properly, in other words, sometimes when holding one down for repetitive fire (like in Centipede and Millipede) it sometimes doesn't work, and the same thing happens in games like Missile Command, where getting the shot off when needed is critical, the "click" the bubble contacts make sometimes does not always result in a shot being fired, and that could be the difference between getting that bonus city every 10,000 points, or "The End". While I am stuck with having to use either the 5200 TB or stock controllers for Missile Command, Super Breakout or Gorf, which run in analog, I can always use my CX82 (2600/7800) trak-ball with games like Centipede, Millipede, and Crystal Castles, which run on digital signals (or center/neutral position for zero movement on the stock 5200 controller), along with the Redemption 5200 2600 adapter and Wico 5200 keypad so I can avoid having to put up with the numerous issues the 5200 trak-ball has. Edited January 10, 2009 by BIGHMW Quote Link to comment Share on other sites More sharing options...
