Mclaneinc Posted August 26, 2009 Share Posted August 26, 2009 Try repeatedly pressing Left Alt+9 or Left Alt+0. As you know, artifact colours are different between different Atari models. Currently it is emulated by having a variable parameter called "burst phase", which can be changed using the above keys. I've actually cheated a little and set the "burst phase" differently for each screenshot. Also, see DOC/USAGE, section "SDL keyboard, joystick and other controllers", for other key combinations. Thanks, will read the docs in a min.. Just one question, do we know if this burst phase setting actually gives the right colours? Quote Link to comment Share on other sites More sharing options...
Mclaneinc Posted August 26, 2009 Share Posted August 26, 2009 Another related question, do the gr.15 hacks show the correct colour that the artifacted gr.8 screen did? Quote Link to comment Share on other sites More sharing options...
thorfdbg Posted August 26, 2009 Share Posted August 26, 2009 Another related question, do the gr.15 hacks show the correct colour that the artifacted gr.8 screen did? It surely doesn't. The reason is that with artifacting, both the bit patterns 0000011000000 0000110000000 appear as a solid white line with some color blurring around it, whereas in Antic E only the latter would be white with no color artifacts, and the former would be only color without white. So long, Thomas Quote Link to comment Share on other sites More sharing options...
thorfdbg Posted August 26, 2009 Share Posted August 26, 2009 Just one question, do we know if this burst phase setting actually gives the right colours? It creates "one correct interpretation" of the signal. In reality, it depends on the TV pretty much, and on the cable in between. So long, Thomas Quote Link to comment Share on other sites More sharing options...
Kr0tki Posted August 26, 2009 Share Posted August 26, 2009 (edited) Just one question, do we know if this burst phase setting actually gives the right colours? We'll never know until someone determines the difference between phase of the colorburst signal and phase of the clock that generates pixels in GTIA, in different Atari models. Either by manually measuring them, or by examining the schematics. It creates "one correct interpretation" of the signal. In reality, it depends on the TV pretty much, and on the cable in between. Are you implying that features of a cable or a TV can influence the colours of artifacts, and at the same time don't influence colours generated traditionally? I would say that colours of artifacts are only dependent on the Atari's motherboard version. Edited August 26, 2009 by Kr0tki Quote Link to comment Share on other sites More sharing options...
SeaGtGruff Posted August 26, 2009 Share Posted August 26, 2009 It creates "one correct interpretation" of the signal. In reality, it depends on the TV pretty much, and on the cable in between. Are you implying that features of a cable or a TV can influence the colours of artifacts, and at the same time don't influence colours generated traditionally? I would say that colours of artifacts are only dependent on the Atari's motherboard version. I can't answer for him about what he was implying, but I know that all TVs are not the same when it comes to colors-- although there's probably a lot more consistency these days than there used to be in "the old days." And I've heard that the quality of the picture on an Atari 8-bit can be affected by the type of cable (and I suppose how good the cable is). These things would surely affect "colours generated traditionally" as well, but they might not be as "sensitive" to the differences (or rather, the differences might not be quite as readily apparent) as with artifacted colors. Michael Quote Link to comment Share on other sites More sharing options...
atariksi Posted August 26, 2009 Share Posted August 26, 2009 Colors also seem to be affected by the GTIA chip in the machine. I swapped a GTIA chip from A5200 with one from A800 and colors were way off and I had to adjust the potentiometer in the A5200 to get the colors close to the A800 ones. Quote Link to comment Share on other sites More sharing options...
Kr0tki Posted August 27, 2009 Share Posted August 27, 2009 (edited) These things would surely affect "colours generated traditionally" as well, but they might not be as "sensitive" to the differences (or rather, the differences might not be quite as readily apparent) as with artifacted colors. But, the TV signal that leaves the composite video port of the Atari, already has the artifacts encoded in the form that is physically indisinguishable from a normal colour signal; the artifacts actually become a normal colour signal. Therefore I don't know how a cable or a TV would recognise the difference. Colors also seem to be affected by the GTIA chip in the machine. I swapped a GTIA chip from A5200 with one from A800 and colors were way off and I had to adjust the potentiometer in the A5200 to get the colors close to the A800 ones. Are you speaking about the artifacting colours? Also, does the potentiometer affect all colours, or only those not generated by artifacting? Edited August 27, 2009 by Kr0tki Quote Link to comment Share on other sites More sharing options...
Paul Westphal Posted April 29, 2014 Share Posted April 29, 2014 My buddy put s-video mod in my 130xe, and it made a huuuge difference. Quote Link to comment Share on other sites More sharing options...
Frankie Posted May 3, 2014 Share Posted May 3, 2014 (edited) Except when you use svideo you lose artifacting. Edited May 3, 2014 by Frankie Quote Link to comment Share on other sites More sharing options...
Bryan Posted May 3, 2014 Share Posted May 3, 2014 Yep, artifacting relies on the TV/monitor not being able to cleanly separate color and luminance signals. S-video solves that problem and shows you the checkered/banding luminance patterns being used to trigger the colors. Quote Link to comment Share on other sites More sharing options...
576XE Posted May 3, 2014 Share Posted May 3, 2014 I remember that KJMann said that his mods kills all artifacting. Quote Link to comment Share on other sites More sharing options...
Kjmann Posted May 3, 2014 Share Posted May 3, 2014 (edited) I remember that KJMann said that his mods kills all artifacting. That's correct. when one of my old video mods are used in S-Video mode, The artifacting is lost. I'm almost done with a new video upgrade that is a board that plugs directly into the GTIA socket. It uses the Fairchild FMS6400 Video Driver IC. if all goes well, it should produce a clean S-Video Signal as well as a Clean Composite Signal and be easy to install. I've found if I use a Resistor and diode to bleed a little bit of the chroma signal into the Luma Signal, using a switch to turn this on and off, I can get the artifacting effect while using S-Video. Hey Flashjazzcat, Are you interested in testing one of these? Edited May 3, 2014 by Kjmann 1 Quote Link to comment Share on other sites More sharing options...
Tempest Posted May 3, 2014 Share Posted May 3, 2014 I had that s-video artifacting mod on my 800. It worked pretty well actually. Unfortunately I had to remove it when I did my Incognito upgrade. I should do something like that again. Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted May 3, 2014 Share Posted May 3, 2014 Hey Flashjazzcat, Are you interested in testing one of these? You know it. I was always very impressed by the picture quality from the s-video boards you used to produce, and I still have a couple. I'm interested to see how far quality can be pushed with a Y/C signal. Quote Link to comment Share on other sites More sharing options...
576XE Posted May 3, 2014 Share Posted May 3, 2014 You never beleive this but I found New CRT Sony PVM 14L2 in ... Lenin's Mausoleum!!! I'm afraid it's some kind of joke... But i have a link: http://www.avito.ru/moskva/audio_i_video/videomonitor_sony_pvm-14l2_199868289 Next link Город Москва показать на карте (under a picture) leads to ... Red Square -> Lenin's Mausoleum!!! 2500 rubs is near 75 bucks Quote Link to comment Share on other sites More sharing options...
Kjmann Posted May 3, 2014 Share Posted May 3, 2014 You know it. I was always very impressed by the picture quality from the s-video boards you used to produce, and I still have a couple. I'm interested to see how far quality can be pushed with a Y/C signal. Ok. As soon as i get them all put together, i will send you one. PM me your address to ship it to =) 2 Quote Link to comment Share on other sites More sharing options...
