harpo Posted February 3, 2009 Share Posted February 3, 2009 I have a file named "MYDOS 4.5 Docs.ATR" that came with my APE software. I have never used MYDOS before so I would like to view some documentation of the syntax and features of this DOS. How do I do that with this file? Is it meant to be viewed with a word processor such as AtariWriter? Is there any way to view it and print it out using Windows notepad or Word? Thanks, John S Quote Link to comment Share on other sites More sharing options...
MEtalGuy66 Posted February 3, 2009 Share Posted February 3, 2009 (edited) I have a file named "MYDOS 4.5 Docs.ATR" that came with my APE software. I have never used MYDOS before so I would like to view some documentation of the syntax and features of this DOS. How do I do that with this file? Is it meant to be viewed with a word processor such as AtariWriter? Is there any way to view it and print it out using Windows notepad or Word?Thanks, John S Just boot the DOS of your choice (as D1:)... Mount MYDOS 4.5 Docs.ATR as D2:, and run the word processor or text-editor/viewer of your choice, and load whatever text files the .ATR image contains... if you just want to look at it, you can copy the file to the E: device and it will be displayed on the screen.. Use cntrl-1 to pause it as it scrolls by.... In the following examples, replace DOCFILE.TXT with the filename of the file you want to view. in spartados: COPY D2:DOCFILE.TXT E: in Mydos: 1. Press C 2. When it asks for "source,destination" type "D2:DOCFILE.TXT, E:" If you want to print it to a printer, replace E: with P: in the examples above. Edited February 3, 2009 by MEtalGuy66 Quote Link to comment Share on other sites More sharing options...
harpo Posted February 3, 2009 Author Share Posted February 3, 2009 I have a file named "MYDOS 4.5 Docs.ATR" that came with my APE software. I have never used MYDOS before so I would like to view some documentation of the syntax and features of this DOS. How do I do that with this file? Is it meant to be viewed with a word processor such as AtariWriter? Is there any way to view it and print it out using Windows notepad or Word?Thanks, John S Just boot the DOS of your choice (as D1:)... Mount MYDOS 4.5 Docs.ATR as D2:, and run the word processor or text-editor/viewer of your choice, and load whatever text files the .ATR image contains... if you just want to look at it, you can copy the file to the E: device and it will be displayed on the screen.. Use cntrl-1 to pause it as it scrolls by.... In the following examples, replace DOCFILE.TXT with the filename of the file you want to view. in spartados: COPY D2:DOCFILE.TXT E: in Mydos: 1. Press C 2. When it asks for "source,destination" type "D2:DOCFILE.TXT, E:" If you want to print it to a printer, replace E: with P: in the examples above. Thanks for the information. I didn't think it would be that easy Quote Link to comment Share on other sites More sharing options...
1050 Posted February 6, 2009 Share Posted February 6, 2009 I went to Ken Sider's site and downloaded his AtrUtil95 1.13 program and placed it in the Windows folder. I then made a shortcut to it and placed that in the Send To folder. So now I right click on any .atr file and select AtrUtil from the the Send To list and the program launches with the atr contents on display. You can then view the contents of single highlighted files which employs an Atascii converter for your viewing pleasure. I believe you can also cut and paste into notepad from there directly and you can also extract and/or insert any type files from/into the atr one at a time. AtrUtil doesn't do SpartaDOS disks contents however. So there is a PC only solution with limits. Quote Link to comment Share on other sites More sharing options...
dinosaur Posted February 19, 2009 Share Posted February 19, 2009 I went to Ken Sider's site and downloaded his AtrUtil95 1.13 program and placed it in the Windows folder. I then made a shortcut to it and placed that in the Send To folder. So now I right click on any .atr file and select AtrUtil from the the Send To list and the program launches with the atr contents on display. You can then view the contents of single highlighted files which employs an Atascii converter for your viewing pleasure. I believe you can also cut and paste into notepad from there directly and you can also extract and/or insert any type files from/into the atr one at a time. AtrUtil doesn't do SpartaDOS disks contents however. So there is a PC only solution with limits. This was a GREAT idea! Works on most Dos 2 or 2.5 .atr images. Thanks! Quote Link to comment Share on other sites More sharing options...
