Assem Posted February 22, 2009 Share Posted February 22, 2009 Does anyone have any idea where the Atari800WinPlus emulator creates the memdump.dat file? This is the file created when you dump the contents of the Atari memory using the monitor windows WRITE command. I searched my whole hard drive but cannot find it. Maybe it doesn't get created on the PCs filesystem???? Any help much appreciated. Quote Link to comment Share on other sites More sharing options...
FULS Posted February 22, 2009 Share Posted February 22, 2009 Does anyone have any idea where the Atari800WinPlus emulator creates the memdump.dat file? This is the file created when you dump the contents of the Atari memory using the monitor windows WRITE command. I searched my whole hard drive but cannot find it. Maybe it doesn't get created on the PCs filesystem???? Any help much appreciated. Hi, Mine is located in the " C:\Program Files\Atari800WinPLus " Directory. Hope this helps. Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted February 22, 2009 Share Posted February 22, 2009 isn't it created where you have loaded the file from? does not matter if file or atr? Quote Link to comment Share on other sites More sharing options...
Assem Posted February 22, 2009 Author Share Posted February 22, 2009 (edited) Thanks for the responses. I initially looked in those directories but because it was not there I searched the whole computer and cannot find it. I also specified an optional filename and looked for that but no luck. I am using the emulator under Vista (fyi: I hate it!), so I am beginning to think it might be something to do with that (I even ran the emulator as the administrator). I will try it on my XP machine once I put it back together. Cheers Edited February 22, 2009 by Assem Quote Link to comment Share on other sites More sharing options...
Assem Posted February 22, 2009 Author Share Posted February 22, 2009 I just worked it out. I actually right click on the Atari800WinPlus.exe and say 'Run as Administrator'. Then when I go to the monitor and issue a WRITE it creates the memory dump file. When I don't run as admin, the WRITE command does not produce an error, but the memory dump file fails to be created. Thanks for the responses. Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted February 22, 2009 Share Posted February 22, 2009 good to know. Quote Link to comment Share on other sites More sharing options...
