jc78_2005 Posted February 23, 2009 Share Posted February 23, 2009 can someone advise me on which chip is the bios chip? markings, placement etc. ive a dead 4 port and im planning on getting a 2 port and want to go with the 4 port bios .thanx for any help Quote Link to comment Share on other sites More sharing options...
bohoki Posted February 23, 2009 Share Posted February 23, 2009 i'm not too much on books smarts or learnin but if i were a bettin man i would have to say it is probably the one that has a sticker on it Quote Link to comment Share on other sites More sharing options...
jc78_2005 Posted February 23, 2009 Author Share Posted February 23, 2009 i'm not too much on books smarts or learnin but if i were a bettin man i would have to say it is probably the one that has a sticker on it haha thanks for the reply, unfortunatly none of the chips on my donor board have a sticker. maybe i can deduce the options when i get the 2 port granted that one has a sticker. Quote Link to comment Share on other sites More sharing options...
MrRetroGamer Posted February 23, 2009 Share Posted February 23, 2009 From a very old thread: First, you have to disassemble the 5200. There are screws on the bottom holding it together (six or seven I think). After you get the screws out turn it back right side up and the top should lift off.Next, you will need to remove the RF shielding. Use a pair of needle pliers and bend up the tabs holding the top portion of the shielding. Once they are all straight, it should lift off. Next comes the actual chip removal. You will need to find the bios chip, it is labeled CO19156 on the 4 port and CO19156A on the 2 port. If I remember correctly, it should be located near the center of the board. Assuming you don't have a chip puller, you will need a small flat bladed screwdriver. Carefully insert the blade of the screwdriver under one end of the chip between the chip and the socket and pry it up a little. Now repeat in the other end of the chip. After a few times of repeating this, the chip should pop out of the socket. Check all of the legs of the chip and make sure none of them are bent. If any are bent carefully straighten them. Quote Link to comment Share on other sites More sharing options...
jc78_2005 Posted February 23, 2009 Author Share Posted February 23, 2009 hey thanx soo much! that was jsut what i was looking for!! greatly appreciated! Quote Link to comment Share on other sites More sharing options...
+Mitch Posted February 23, 2009 Share Posted February 23, 2009 From a very old thread: First, you have to disassemble the 5200. There are screws on the bottom holding it together (six or seven I think). After you get the screws out turn it back right side up and the top should lift off.Next, you will need to remove the RF shielding. Use a pair of needle pliers and bend up the tabs holding the top portion of the shielding. Once they are all straight, it should lift off. Next comes the actual chip removal. You will need to find the bios chip, it is labeled CO19156 on the 4 port and CO19156A on the 2 port. If I remember correctly, it should be located near the center of the board. Assuming you don't have a chip puller, you will need a small flat bladed screwdriver. Carefully insert the blade of the screwdriver under one end of the chip between the chip and the socket and pry it up a little. Now repeat in the other end of the chip. After a few times of repeating this, the chip should pop out of the socket. Check all of the legs of the chip and make sure none of them are bent. If any are bent carefully straighten them. Wow, that's sounds so familiar, almost like someone pulled those thoughts out of my head. Mitch Quote Link to comment Share on other sites More sharing options...
MrRetroGamer Posted February 24, 2009 Share Posted February 24, 2009 Wow, that's sounds so familiar, almost like someone pulled those thoughts out of my head. Mitch I should have just linked to the old thread from 2002, and I should give credit (to Mitch) where credit is due! http://www.atariage.com/forums/index.php?s...ost&p=99348 Quote Link to comment Share on other sites More sharing options...
jc78_2005 Posted February 24, 2009 Author Share Posted February 24, 2009 Wow, that's sounds so familiar, almost like someone pulled those thoughts out of my head. Mitch I should have just linked to the old thread from 2002, and I should give credit (to Mitch) where credit is due! http://www.atariage.com/forums/index.php?s...ost&p=99348 well a HUGE! thanx to both of you. thank you mitch for the know how. and thank you mrreto for pointing out mitch's know how! Quote Link to comment Share on other sites More sharing options...
