Joey Kay Posted September 27, 2002 Share Posted September 27, 2002 Hey gang! I'm once again tackling emulating 8-bit Atari on the PC (I don't know why - for all the time I spend trying to get these emulators to work, it would be easier just to hook my my 130XE...) Anyhow, how the heck does a guy run downloaded ROMS on XFORMER 2000? Cheers! Joey Quote Link to comment Share on other sites More sharing options...
Goochman Posted September 28, 2002 Share Posted September 28, 2002 Had the same problem - there should be a seperate File/Menu option to load .exe or .bins vs disk images That should be it - Use the latest version Atari800Win 3.0+ Quote Link to comment Share on other sites More sharing options...
noteit Posted March 25, 2004 Share Posted March 25, 2004 You have to get that bin file onto a disk image file that has dos on it. The emulator can load the .atr files or xfd type files. There probably is some utility to convert an atari file on a pc to a atr or xfd file with atari dos on it, but I know of none. So, if your file is on an atari disk, instead of a pc, then you can make the atr type files with Ape, and the pro cable. If your file is on a pc, and you have a modem on both the pc and atari, you can just send the file over to the atari, put it on a dos disk, then make your atr file with ape. Your also might do this with a null modem cable between the pc and atari, and both run a terminal program. Try doing a search engine search and use words atari xformer utility. Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted March 25, 2004 Share Posted March 25, 2004 Atari800Win can do that by itself. Just stick it in a hard disk folder that's defined in it's options, and then do a Dos2.5 copy to an .atr within the emulator. COPY FILE FROM, TO? H5:BINARY.BIN,D1:BINARY.BIN Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted March 25, 2004 Share Posted March 25, 2004 any reason for using xformer??? use atari800win4.0plus... it has everything you need...(or are you using xformer because of the xformer cable + original hardware connected to pc????) http://atariarea.histeria.pl/PLus/index_us.htm Quote Link to comment Share on other sites More sharing options...
LYNXGUY Posted April 18, 2004 Share Posted April 18, 2004 I use Xformer 2000 for windows version 8 and I am having zero problems With the Xformer all you do is download the .atr files and have fun playing the games. However everyone has their favorite emulator and mine happens to be Xformer 2000 for windows v.8 Quote Link to comment Share on other sites More sharing options...
