Aegis Posted June 14, 2009 Share Posted June 14, 2009 (edited) When I installed the the 9.5 catalyst drivers in windows 7 64bit it didn't install that file. I had to copy it manually. Maybe the 9.5 version of the drivers I installed didn't install that file. ATi may have changed it for the newer drivers for suppoet for the Riddick game? Unlikely they'd leave out OpenGL to support a single game - that's a sure-fire way to cause a s**t storm with your customers (particularly the ones that use OpenGL apps). Did you install beta drivers or the final WHQL ones? Also, some virus-checkers like to hijack files as they're being installed - maybe that's what happened? The reason I'm running Win 7 now is 'cause BitDefender quarantined a load of Vista SP2 files and completely hosed my PC - tsk. The virus-checkers are getting worse than the viruses (virii?) Edited June 14, 2009 by Aegis Quote Link to comment Share on other sites More sharing options...
Rom Hunter Posted June 16, 2009 Share Posted June 16, 2009 Ok, updated my drivers. Stephena, these TV effects are the coolest things ever. It's exactly like I remember it from back in the eighties, playing the games on my old color TV set. Perfect! Quote Link to comment Share on other sites More sharing options...
Rom Hunter Posted June 17, 2009 Share Posted June 17, 2009 Stephena, I have two questions: When I press escape during gameplay, I get kicked out of the emulator completely. Can this be fixed? Why are there small vertical graphics visible at the far right side of the game screen? Can these be removed somehow? Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted June 17, 2009 Share Posted June 17, 2009 When I press escape during gameplay, I get kicked out of the emulator completely.Can this be fixed? See Options, UI settings, Enter Launcher after exiting ROM (check) Why are there small vertical graphics visible at the far right side of the game screen?Can these be removed somehow? Do you have a screenshot? Quote Link to comment Share on other sites More sharing options...
Rom Hunter Posted June 17, 2009 Share Posted June 17, 2009 See Options, UI settings, Enter Launcher after exiting ROM (check)Fixed. Thanks! Do you have a screenshot? Quote Link to comment Share on other sites More sharing options...
Rom Hunter Posted June 17, 2009 Share Posted June 17, 2009 (edited) Any idea, Thomas? I highly doubt these graphics belong there. Here's another example: Edited June 17, 2009 by Rom Hunter Quote Link to comment Share on other sites More sharing options...
Aegis Posted June 17, 2009 Share Posted June 17, 2009 Why are there small vertical graphics visible at the far right side of the game screen? I noticed these - they seem to be the result of color bleed blurring off-screen (overscan?) graphics - turn 'TV Color Bleed' off and they disappear... Quote Link to comment Share on other sites More sharing options...
Keatah Posted June 18, 2009 Share Posted June 18, 2009 Can this somehow be made to work with older opengl drivers, such as 1.3 or something? I don't have 2.0 on the system I use for emulation. Quote Link to comment Share on other sites More sharing options...
Rom Hunter Posted June 18, 2009 Share Posted June 18, 2009 Why are there small vertical graphics visible at the far right side of the game screen? I noticed these - they seem to be the result of color bleed blurring off-screen (overscan?) graphics - turn 'TV Color Bleed' off and they disappear... Ok, I see. Well, I have to deal with these graphics then, because I really like the color bleed. Quote Link to comment Share on other sites More sharing options...
Aegis Posted June 18, 2009 Share Posted June 18, 2009 (edited) Ok, I see. Well, I have to deal with these graphics then, because I really like the color bleed. Funnily enough, something similar (although probably less noticeable) would happen on a real CRT - if bright pixels are drawn in the overscan area (which is usually partially obscured by the TV's bezel) they'd make the neighboring pixels glow too. *Edit* Scratch that - I think it's a bug - turn TV color bleed off then back on again - the fuzzy lines should disappear Edited June 18, 2009 by Aegis Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted June 18, 2009 Share Posted June 18, 2009 *Edit* Scratch that - I think it's a bug - turn TV color bleed off then back on again - the fuzzy lines should disappear Maybe some missing initialization. Quote Link to comment Share on other sites More sharing options...
gary1068 Posted June 18, 2009 Share Posted June 18, 2009 I have a ATI 2xHD4850 in crossfire mode. By default the newer catalyst drivers DO NOT install the OpenGL drivers. Uh, that's incorrect - the latest Catalyst drivers (currently 9.5 - 9.6 are out this month) install OpenGL support just fine - my Radeon HD 4870X2 is showing up OpenGL 2.1 without having to add any .dlls as you can see in CCC below. Note that the OpenGL version shown here doesn't relate to what Stella reports (2.1) - I guess it's ATI/AMD's own internal versioning..? *Edit* Just double checked and atioglxx.dll is where it should be in C:\Windows\SysWOW64 (Windows 7 x64) so the Catalyst installer for 9.5 definitely installs it correctly... When I installed the the 9.5 catalyst drivers in windows 7 64bit it didn't install that file. I had to copy it manually. Maybe the 9.5 version of the drivers I installed didn't install that file. ATi may have changed it for the newer drivers for suppoet for the Riddick game? um edweird how so you have windows 7? it is NOT due for release untill the fall of this year or for the fall of next year (2010)! Quote Link to comment Share on other sites More sharing options...
gary1068 Posted June 18, 2009 Share Posted June 18, 2009 (edited) love the new Stella Edited June 18, 2009 by gary1068 Quote Link to comment Share on other sites More sharing options...
Omegamatrix Posted June 18, 2009 Share Posted June 18, 2009 um edweird how so you have windows 7?it is NOT due for release untill the fall of this year or for the fall of next year (2010)! :!: You can download beta trial versions from Microsoft. Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted June 18, 2009 Share Posted June 18, 2009 Ok, I got my new video card today. After installing the latest available driver, the TV effects worked instantly. Very impressive! Not sure if I will leave them enabled, probably only on a medium or low level. BTW: I noticed that when I use commandline parameters for left and right controller to start Stella, I have NO chance to change them inside Stella. Is that intentional? Quote Link to comment Share on other sites More sharing options...
+stephena Posted June 18, 2009 Author Share Posted June 18, 2009 The various issues with the TV effects are because this is the first time the code has been extensively tested by a wide group of people on diverse hardware. I'm going to direct the Georgia Tech Atari Team (the ones responsible for this code) to these posts, so they can get feedback and bug reports on the issue. Unfortunately, all of my time is taken up with other parts of Stella, so I won't be able to help too much on the TV stuff. Look for many more improvements when the next group finishes, probably sometime around late August or so. Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted June 19, 2009 Share Posted June 19, 2009 Got it working and it's nice to have the features, but Color TV Texture set to normal or staggered seems too harsh. It's like looking through a dark screen door. None of my TVs looked that bad or that dark. TV color bleed makes it look better, but the game slows down to a crawl, even on low. The sound also slows down. Quote Link to comment Share on other sites More sharing options...
Rom Hunter Posted June 19, 2009 Share Posted June 19, 2009 Got it working and it's nice to have the features, but Color TV Texture set to normal or staggered seems too harsh. It's like looking through a dark screen door. None of my TVs looked that bad or that dark.Mine most certainly did. It's this one: http://www.atarimania.com/2600/dumps/play.php?ID=8223 Stephena, Is it possible to feature the TV effects for the online version? Do you have anything to do with the online version of Stella? Quote Link to comment Share on other sites More sharing options...
+stephena Posted June 19, 2009 Author Share Posted June 19, 2009 Got it working and it's nice to have the features, but Color TV Texture set to normal or staggered seems too harsh. It's like looking through a dark screen door. None of my TVs looked that bad or that dark.Mine most certainly did. It's this one: http://www.atarimania.com/2600/dumps/play.php?ID=8223 Stephena, Is it possible to feature the TV effects for the online version? Do you have anything to do with the online version of Stella? I'm not really involved with JStella (the online Java version), as I have enough to handle with keeping mainline Stella working on all three major platforms at the same time (Linux/OSX/Windows). As well, I don't know how Java works with OpenGL, or if it even does at all. These effects are strictly OpenGL2.0-only, and as such, I don't know if they can ever be used in Java. In any event, I don't yet have the experience in the OpenGL TV effects code, or the time itself to look into JStella Quote Link to comment Share on other sites More sharing options...
+stephena Posted June 19, 2009 Author Share Posted June 19, 2009 Stella 2.8.1 was just released, which addresses some of the issues mentioned in this thread. Please move all responses to the new thread. Quote Link to comment Share on other sites More sharing options...
