Tupin Posted June 17, 2009 Share Posted June 17, 2009 Okay, just wondering, I've heard that only a few versions of the 7800 work with the Supercharger. Now, my 7800 has no expansion port, works with Kool-Aid Man, was made in Taiwan, and has the following on the bottom of the system: 72R4BR A1 83 5213237 The 83 part is stamped on, not printed like the rest of it. A 7800 of this type is not listed in that 7800 Test Table on here, so I'm not sure about it. Help? Quote Link to comment Share on other sites More sharing options...
SoundGammon Posted June 18, 2009 Share Posted June 18, 2009 Try Activision's Robot Tank. If that works then more than likely the Supercharger will work too! Quote Link to comment Share on other sites More sharing options...
Tupin Posted June 18, 2009 Author Share Posted June 18, 2009 Thanks, looks like I have an excuse to make a trip out to the game store this weekend. Quote Link to comment Share on other sites More sharing options...
mos6507 Posted June 18, 2009 Share Posted June 18, 2009 Even if it doesn't work there is a hardware mod you can do to fix that. Quote Link to comment Share on other sites More sharing options...
Video Posted June 20, 2009 Share Posted June 20, 2009 The reason it "don't work" I believe is the cart is to big to fit in the slot, that was my problem, when I took the shell off the console it worked...Though I think the tabs are part of the circuit, and that may stick out to far to fit in some of them too... Quote Link to comment Share on other sites More sharing options...
Tupin Posted June 20, 2009 Author Share Posted June 20, 2009 I think it's just the shell, and you can sand it down. Activision carts just barely fit, so I think I need to expand the port anyway. Quote Link to comment Share on other sites More sharing options...
+batari Posted June 20, 2009 Share Posted June 20, 2009 The reason it "don't work" I believe is the cart is to big to fit in the slot, that was my problem, when I took the shell off the console it worked...Though I think the tabs are part of the circuit, and that may stick out to far to fit in some of them too... That may be, but a fitment issue would be obvious. The actual reason it doesn't work is because the Supercharger counts address changes to know when to do a RAM write, and some 7800s have an extra circuit that sets A12=0 for a brief period every cycle to "fix" a programming error in 2600 Dark Chambers. The Supercharger sees this as an address change. The Activision games (Robot Tank, Decathlon) also have issues with this address change (I think it's because their hotspots are in the stack area, which would be erroneously accessed by the "fix.") Quote Link to comment Share on other sites More sharing options...
Tupin Posted June 20, 2009 Author Share Posted June 20, 2009 Yes, Robot Tank works! Now, to find a Supercharger. And a cassette tape player... Quote Link to comment Share on other sites More sharing options...
potatohead Posted June 20, 2009 Share Posted June 20, 2009 You can use a computer, CD, or most any portable media player, if you want to. Quote Link to comment Share on other sites More sharing options...
+Mitch Posted June 21, 2009 Share Posted June 21, 2009 The reason it "don't work" I believe is the cart is to big to fit in the slot, that was my problem, when I took the shell off the console it worked...Though I think the tabs are part of the circuit, and that may stick out to far to fit in some of them too... That may be, but a fitment issue would be obvious. The actual reason it doesn't work is because the Supercharger counts address changes to know when to do a RAM write, and some 7800s have an extra circuit that sets A12=0 for a brief period every cycle to "fix" a programming error in 2600 Dark Chambers. The Supercharger sees this as an address change. The Activision games (Robot Tank, Decathlon) also have issues with this address change (I think it's because their hotspots are in the stack area, which would be erroneously accessed by the "fix.") Actually, the Supercharger is affected by both issues. The electronic one and the physical one. Mitch Quote Link to comment Share on other sites More sharing options...
shadow460 Posted June 21, 2009 Share Posted June 21, 2009 I think it's just the shell, and you can sand it down. Activision carts just barely fit, so I think I need to expand the port anyway. All you have to do is cut the sleeve around the port. It can be donw without even opening the console. If you want to go deeper, you can open the console, cut the sleeve, and drill out the screw posts on it so that TigerVision games fit also. Quote Link to comment Share on other sites More sharing options...
+batari Posted June 21, 2009 Share Posted June 21, 2009 The reason it "don't work" I believe is the cart is to big to fit in the slot, that was my problem, when I took the shell off the console it worked...Though I think the tabs are part of the circuit, and that may stick out to far to fit in some of them too... That may be, but a fitment issue would be obvious. The actual reason it doesn't work is because the Supercharger counts address changes to know when to do a RAM write, and some 7800s have an extra circuit that sets A12=0 for a brief period every cycle to "fix" a programming error in 2600 Dark Chambers. The Supercharger sees this as an address change. The Activision games (Robot Tank, Decathlon) also have issues with this address change (I think it's because their hotspots are in the stack area, which would be erroneously accessed by the "fix.") Actually, the Supercharger is affected by both issues. The electronic one and the physical one. Mitch I wasn't disputing a fitment issue, just that Video claimed it was the only issue. Fitment is the least of the issues and doesn't affect just Robot Tank - it affects many if not all Activision titles. Quote Link to comment Share on other sites More sharing options...
potatohead Posted June 21, 2009 Share Posted June 21, 2009 Is there a list of affected Activision games? Quote Link to comment Share on other sites More sharing options...
+batari Posted June 21, 2009 Share Posted June 21, 2009 Is there a list of affected Activision games? It is the FE games in particular that have electrical issues - Robot Tank, Decathlon and at least some copies of Space Shuttle use FE bankswitching that doesn't work with some 7800s. As far as fitment issues, I don't know. Quote Link to comment Share on other sites More sharing options...
Video Posted June 22, 2009 Share Posted June 22, 2009 Hmm...Didn't know there was a software issue, Mine worked fine, once I got it in the slot, just never do cause I gt a 2600 anyways, and was worried I might break something. Quote Link to comment Share on other sites More sharing options...
tripletopper Posted July 10, 2009 Share Posted July 10, 2009 You can use a computer, CD, or most any portable media player, if you want to. I'm no sure about Minidisc. I tried it with a Bally Astrocade, and the recording of the analog squelches in Bally Basic doesn't work well. Is it something wrrong with MiniDisc, or Bally Basic. Will I have a similar problem with Supercharger? Quote Link to comment Share on other sites More sharing options...
shadow460 Posted July 10, 2009 Share Posted July 10, 2009 Mini Disc recorders compress the music files. I don't think you'll have a problem with the SuperCharger since it can load the games from mp3 files. Quote Link to comment Share on other sites More sharing options...
racer raul Posted July 10, 2009 Share Posted July 10, 2009 you saying the supercharger can read roms in mp3 file format? At watt rate? Quote Link to comment Share on other sites More sharing options...
mos6507 Posted July 10, 2009 Share Posted July 10, 2009 It would have to be a high quality MP3. I would never store them in that format. It's like storing them on cassettes with dropouts. Maybe it will work but it kind of defeats the purpose of going digital. Quote Link to comment Share on other sites More sharing options...
nonner242 Posted July 11, 2009 Share Posted July 11, 2009 My supercharger fits fine in my 7800 and Yes it has a 1gig MP3 player connected to it. All work just perfect, the best part is that my 7800 is modded with the S-Video and looks superb on my LCD. Grab you modded NES controllers and have the best of all worlds. Quote Link to comment Share on other sites More sharing options...
tremoloman2006 Posted July 11, 2009 Share Posted July 11, 2009 (edited) I use audiograbber 1.83 (free) with the latest version of Lame (free) and encode at "New", "VBR", "Highest Quality". It works for my Supercharger and my TI-99/4A cassette games flawlessly. I just plug in the audio cable to my MP3 player on my keychain and I'm gaming in seconds. Edited July 11, 2009 by tremoloman2006 Quote Link to comment Share on other sites More sharing options...
sinistermoon Posted July 21, 2009 Share Posted July 21, 2009 My supercharger fits fine in my 7800 and Yes it has a 1gig MP3 player connected to it.All work just perfect, the best part is that my 7800 is modded with the S-Video and looks superb on my LCD. Grab you modded NES controllers and have the best of all worlds. You're a lucky man! I really want a Supercharger. But they always go for more money then I have at the time. And I still need to mod a NES controller to work on my Atari 7800. I think that would be even better then the Euro 7800 controllers due to not having so much space between the buttons. And that would be way awesome to have S-video! Quote Link to comment Share on other sites More sharing options...
nonner242 Posted July 21, 2009 Share Posted July 21, 2009 My supercharger fits fine in my 7800 and Yes it has a 1gig MP3 player connected to it.All work just perfect, the best part is that my 7800 is modded with the S-Video and looks superb on my LCD. Grab you modded NES controllers and have the best of all worlds. You're a lucky man! I really want a Supercharger. But they always go for more money then I have at the time. And I still need to mod a NES controller to work on my Atari 7800. I think that would be even better then the Euro 7800 controllers due to not having so much space between the buttons. And that would be way awesome to have S-video! Lucky now!...but over 10 years of pulling out hair has mad me very Evil and bald. Quote Link to comment Share on other sites More sharing options...
sinistermoon Posted July 21, 2009 Share Posted July 21, 2009 My supercharger fits fine in my 7800 and Yes it has a 1gig MP3 player connected to it.All work just perfect, the best part is that my 7800 is modded with the S-Video and looks superb on my LCD. Grab you modded NES controllers and have the best of all worlds. You're a lucky man! I really want a Supercharger. But they always go for more money then I have at the time. And I still need to mod a NES controller to work on my Atari 7800. I think that would be even better then the Euro 7800 controllers due to not having so much space between the buttons. And that would be way awesome to have S-video! Lucky now!...but over 10 years of pulling out hair has mad me very Evil and bald. HAHA yeah I know what you mean. I have only been looking for one for a short amount of time(like a year)but in that time the only place that I can ever find any is eBay and it has been very frustrating trying to get one. Quote Link to comment Share on other sites More sharing options...
