candle Posted July 9, 2009 Share Posted July 9, 2009 Joe, look at the block diagrams in pdf You found, and functional description it is written, that chip loads character row (when LD/SH signal is high) to shift out during shift phase (when LD/SH is low) now compare this to 74LS165 chip it has SH/LD signal (pin #2 of crt8021), Clock singal (pin #3), A-H inputs (A0 to A7 - pin #4 to 11), and Output H (pin #1) its very simple chip that can be synthetised inside of small cpld device like xc9536 or xc9572 it can be fun if You would like to spend some time reverse engineering this chip Quote Link to comment Share on other sites More sharing options...
joeventura Posted July 9, 2009 Author Share Posted July 9, 2009 hahaha well your idea of fun and mine...... Quote Link to comment Share on other sites More sharing options...
candle Posted July 9, 2009 Share Posted July 9, 2009 not that funny... just providing the way out for me You may toss whole thing right into the dumpster Quote Link to comment Share on other sites More sharing options...
joeventura Posted July 9, 2009 Author Share Posted July 9, 2009 Didn't mean any offense, just not the way I would fix it. Quote Link to comment Share on other sites More sharing options...
candle Posted July 9, 2009 Share Posted July 9, 2009 understood Quote Link to comment Share on other sites More sharing options...
sl0re Posted April 9, 2023 Share Posted April 9, 2023 On 7/6/2009 at 12:16 PM, joeventura said: I will check. Just to clarify the pics you are looking at are from two different BIT3 cards, one that does not have the problem and one that does. I will swap the Char ROM chips first and see if that helps. The data being input is on the same atari 800 from BASIC cart so its not what is being sent to the card or the computer as they are consistent unless you are implying that the two cards interact with the same Atari 800 differently? Thanks for posting your troubleshooting. I have one with the same symptom. Now I have something to try. Quote Link to comment Share on other sites More sharing options...
