RSS Bot Posted August 30, 2009 Share Posted August 30, 2009 Given Al's recent overhaul of the AtariAge website, this seemed like a good time to post the facelift I did for Stellar Overlord. The new look so95.zip (605.91K) Number of downloads: 0 New Features: - Completely redid the font graphics from scratch. Wider is better. - Shrunk the planets in the Galactic Display to make them look more like round planets, and less like footballs. (besides, )- There is a new sound effect for the victory at the end of the game. It's based on an idea posted by thegoldenband. Minor Tweaks: - Games now start at the slowest speed. I noticed that every time I played a game, the first thing I did was slow the game down to get my bearings. - Changed the message at the end of the game. Final Enhancements to Do: - Add destroying all enemy fleets as a condition of winning the game. Currently, all that is required is conquering all worlds. - Change ship production to occur on turn multiples of 10, rather than 10+1. - Rewrite the frame-based computational load distribution system. - Fleets should arrive when their ETA count-down reaches 0, not the turn after. - Add a trig table to replace the simple Manhatton distances used for star distance calculations. - Provide acceleration in level selection, similar to acceleration in ship selection. - Tweak the kernel to center the text display. - Reduce RAM requirement for randomization routine. Should only need 2 or 3 bytes. - Save random buffer when the reset switch is pressed. This will provide much better randomization for subsequent games. - Manual - Add joystick control diagrams. (Partially done.) Known Bugs to Fix: - If you are pressing left when the game should end, the victory conditions are not registered correctly. - Streamline the combining of fleets when attacking a world. Two groups of 120 should combine seamlessly into a fleet of 240 ships that attack simultaneously. - If the game ends with a ship landing, the planet where the ship lands is purple instead of color pulsing. - World conquer or loss sounds should have precedence over ship landing or take off sounds. - Spacing between text lines should be uniform throughout the game. Some spacing is still off. Development Notes: I completely rewrote the sound engine for this game. I was lazy when I wrote the original sound engine, and had all the sound effect counters counting up instead of down. After cleaning this up, and using more lookup tables to define the sound lengths and voices, I was able to shave off 40 bytes of ROM, even with additional code for the new phase effect. I did more editing to the user manual, which is included in the download zip. The user manual has been reformatted with 4.25 inch by 5.5 inch pages, which are similar to the page layout of the original Atari manuals. When viewing the pdf, I recommend using View->Page Layout->Facing. If you have an aversion to using Adobe's Acrobat viewer for viewing pdf, I recommend using the free, unbloated Foxit Reader. With a double-sided printout, I can fit 8 of these small pages on a single 8.5 x 11 sheet of paper. So the final manual should be printable on only 5 sheets of glossy paper, which will keep costs down.http://www.atariage.com/forums/index.php?app=blog&blogid=138&showentry=6397 Link to comment Share on other sites More sharing options...
