ataridoctor Posted September 15, 2009 Share Posted September 15, 2009 Does anyone have any wico y cables they can part with. i got 4 wico at5200 controllers with out cables and would rather not make adapters/ Any help is appreciated Quote Link to comment Share on other sites More sharing options...
Prodos8 Posted September 17, 2009 Share Posted September 17, 2009 (edited) Does anyone have any wico y cables they can part with. i got 4 wico at5200 controllers with out cables and would rather not make adapters/ Any help is appreciated If you have a spare 5200 controller cable I could possibly build you one or, maybe even a wico keypad knock-off that you could use your wicos with. I only have one original cable that I'm keeping and I'm still looking for an original wico keypad for myself. ETA: Personally, I'm not a fan of the Wico stick, but I love the little y-cable to use with my masterplay clone. Edited September 17, 2009 by Prodos8 Quote Link to comment Share on other sites More sharing options...
bohoki Posted September 17, 2009 Share Posted September 17, 2009 (edited) Does anyone have any wico y cables they can part with. i got 4 wico at5200 controllers with out cables and would rather not make adapters/ Any help is appreciated If you have a spare 5200 controller cable I could possibly build you one or, maybe even a wico keypad knock-off that you could use your wicos with. I only have one original cable that I'm keeping and I'm still looking for an original wico keypad for myself. ETA: Personally, I'm not a fan of the Wico stick, but I love the little y-cable to use with my masterplay clone. yes i too have an extra cable for when i run into a wico stick its not so bad having to make an adapter though i made */this one/ sure its ugly but hey it works the trick is you have to cut off the metal shield from the 15 pin connectors then i use the soldering iron to seal the 2 plug pieces together then use hot glue to keep from disturbing the soldering job on the wiring Edited September 17, 2009 by bohoki Quote Link to comment Share on other sites More sharing options...
Prodos8 Posted September 18, 2009 Share Posted September 18, 2009 yes i too have an extra cable for when i run into a wico stick its not so bad having to make an adapter though i made */this one/ sure its ugly but hey it works the trick is you have to cut off the metal shield from the 15 pin connectors then i use the soldering iron to seal the 2 plug pieces together then use hot glue to keep from disturbing the soldering job on the wiring Yeah, that's a bit fugly, but hey if it works it works. You could make a wico keyboard knock off by modifying a working controller (yeah I know they're hard to find) by adding a 9-pin male connection for the wico stick and disconnecting the wires from the internal stick. The result would match the system perfectly. Quote Link to comment Share on other sites More sharing options...
ataridoctor Posted September 21, 2009 Author Share Posted September 21, 2009 Hey guys these y cables are hard to come by. I'll probably get a small project box and make some. i have about 10 new controller cables. Thanks Paul Quote Link to comment Share on other sites More sharing options...
ataridoctor Posted September 21, 2009 Author Share Posted September 21, 2009 The wico stick seems better on alot of games than the comp pros. On river raid the plane doesnt go straight but it can be trimmed with the wico Quote Link to comment Share on other sites More sharing options...
