Spazmonkey Posted September 19, 2009 Share Posted September 19, 2009 As my title states, I just replaced the mje210 and 7805, and the baby works like a charm. Only problem is, the RF coming out is really weird. There's a lot of audio interference, and just a bit on the video, it's snowy exactly.... just unclear. I tried messing with the potentiometers on the board, the one long post one, and the two flat ones, but it didn't seem to do anything. So if anyone has any idea's, I'm all ears. Quote Link to comment Share on other sites More sharing options...
GroovyBee Posted September 19, 2009 Share Posted September 19, 2009 Did the video and sound work OK prior to the fault that caused you to replace the components in the 9v to 5v supply path? Quote Link to comment Share on other sites More sharing options...
+Mitch Posted September 19, 2009 Share Posted September 19, 2009 As my title states, I just replaced the mje210 and 7805, and the baby works like a charm. Only problem is, the RF coming out is really weird. There's a lot of audio interference, and just a bit on the video, it's snowy exactly.... just unclear. I tried messing with the potentiometers on the board, the one long post one, and the two flat ones, but it didn't seem to do anything. So if anyone has any idea's, I'm all ears. It's sounds like your RF modulator is slightly off. You need a plastic RF alignment tool and you align it by adjusting the control inside the hole on the side of the modulator. It's also possible that your RF connector on the 7800 is loose. If your RF cable that plugs into the 7800 doesn't connect solidly that could be the issue. Mitch Quote Link to comment Share on other sites More sharing options...
Spazmonkey Posted September 19, 2009 Author Share Posted September 19, 2009 As my title states, I just replaced the mje210 and 7805, and the baby works like a charm. Only problem is, the RF coming out is really weird. There's a lot of audio interference, and just a bit on the video, it's snowy exactly.... just unclear. I tried messing with the potentiometers on the board, the one long post one, and the two flat ones, but it didn't seem to do anything. So if anyone has any idea's, I'm all ears. It's sounds like your RF modulator is slightly off. You need a plastic RF alignment tool and you align it by adjusting the control inside the hole on the side of the modulator. It's also possible that your RF connector on the 7800 is loose. If your RF cable that plugs into the 7800 doesn't connect solidly that could be the issue. Mitch Cool, I will play around with that. It was sitting on my back burner for a few months, but I didn't touch it at all, so I'm surprised it got un-calibrated. Quote Link to comment Share on other sites More sharing options...
Spazmonkey Posted September 20, 2009 Author Share Posted September 20, 2009 (edited) As my title states, I just replaced the mje210 and 7805, and the baby works like a charm. Only problem is, the RF coming out is really weird. There's a lot of audio interference, and just a bit on the video, it's snowy exactly.... just unclear. I tried messing with the potentiometers on the board, the one long post one, and the two flat ones, but it didn't seem to do anything. So if anyone has any idea's, I'm all ears. It's sounds like your RF modulator is slightly off. You need a plastic RF alignment tool and you align it by adjusting the control inside the hole on the side of the modulator. It's also possible that your RF connector on the 7800 is loose. If your RF cable that plugs into the 7800 doesn't connect solidly that could be the issue. Mitch I re-flowed the joints, and tried tweaking the pot, but it didn't aleviate the problem. In fact, I had to re-adjust more to undo what the adjusting did, if that makes sense. It looks like I'll just s-video mod it, and be done with it. Cool, I will play around with that. It was sitting on my back burner for a few months, but I didn't touch it at all, so I'm surprised it got un-calibrated. Edited September 20, 2009 by Spazmonkey Quote Link to comment Share on other sites More sharing options...
