orkear34 Posted October 21, 2002 Share Posted October 21, 2002 where do i get all the files so i can program in c ? is there anything else i need to know? i dont know anything about programing the lynx and want to get started on learning . ((Anti-Collision Devices In response to popular demand, hardware collision is disableable in many ways. The original method of declaring a sprite to be of type 'non-collideable'. Set the 'don't collide' bit in the sprite collision number 'SPRCOLL'- of the SCB. Set the 'don't collide' bit in the system control byte 'SPRSYS')) this is part of a doc i found on programing the lynx. do i need to learn both c and this info? or just c++? thanks.... Quote Link to comment Share on other sites More sharing options...
Matthias Posted October 21, 2002 Share Posted October 21, 2002 where do i get all the files so i can program in c ? You can load the latest version of the C-compiler CC65 from Bastian Schick's website http://www.geocities.com/SiliconValley/Byte/4242/. Alternatively you'll find a ZIP-archive (might be not up to date) on my website: http://home.t-online.de/home/Matthias.Domin/cc65.zip is there anything else i need to know? i dont know anything about programing the lynx and want to get started on learning . Yes. on Bastian's site you'll find the (almost) complete Atari development manual. ((Anti-Collision Devices In response to popular demand, hardware collision is disableable in many ways. The original method of declaring a sprite to be of type 'non-collideable'. Set the 'don't collide' bit in the sprite collision number 'SPRCOLL'- of the SCB. Set the 'don't collide' bit in the system control byte 'SPRSYS')) this is part of a doc i found on programing the lynx. On my Lynx-page are some small demos written in C showing some of the Lynx-capabilities. do i need to learn both c and this info? After you'll have understood the infos about the Lynx-hardware you can use whatever programming language you want (and which is available). But knowing 6502 assembler will help you a lot. or just c++? thanks.... Who has told you that there would be a C++ compiler? Regards Matthias Quote Link to comment Share on other sites More sharing options...
