+batari Posted December 1, 2009 Share Posted December 1, 2009 The of the very first production Harmony carts will be in the hands of users shortly, so this is time for a new BIOS release. Production Harmony carts come with 1.03 BIOS installed. This BIOS also works with any preproduction or prototype Harmony carts. Changes include: * Fix for directory truncation bug * 7800 pause button to stop colour cycling * PAL 7800 console fix (those with the built-in Asteroids game will fail to detect Harmony and run Asteroids) * AUTORUN file support * Support for production Harmony carts * File extension forcing now works * Improved paddle handling in main menu If you are using a production Harmony cart, you must use this BIOS (or any newer BIOS as they are released.) Do not install any older BIOS on a production Harmony cart as it won't work properly. hbios103c.zip 1 Quote Link to comment Share on other sites More sharing options...
Buzbard Posted December 2, 2009 Share Posted December 2, 2009 Thanks batari! I wonder if it would be possible to get a Harmony sub forum going here so we can find updates and info in one consistent place? Quote Link to comment Share on other sites More sharing options...
+save2600 Posted December 2, 2009 Share Posted December 2, 2009 Having a static source would be a good idea, but the new topics that pop up like this are good enough for regular users. BTW: 1.03 works great with my 7800. Thanks once again for the support! Quote Link to comment Share on other sites More sharing options...
gambler172 Posted December 5, 2009 Share Posted December 5, 2009 Hi Batari You wrote.... * PAL 7800 console fix (those with the built-in Asteroids game will fail to detect Harmony and run Asteroids) I wonder,is there any Pal 7800 System without ASTEROIDS built in? I have many 7800 systems,but no Pal system without ASTEROIDS.So the new BIOS does not work?????? greetings Walter Quote Link to comment Share on other sites More sharing options...
cd-w Posted December 5, 2009 Share Posted December 5, 2009 Hi Batari You wrote.... * PAL 7800 console fix (those with the built-in Asteroids game will fail to detect Harmony and run Asteroids) I wonder,is there any Pal 7800 System without ASTEROIDS built in? I have many 7800 systems,but no Pal system without ASTEROIDS.So the new BIOS does not work?????? greetings Walter It means that this issue is fixed with the 1.03 bios. This was a problem with earlier bios versions. The harmony now works fine with pal 7800 consoles. Chris Quote Link to comment Share on other sites More sharing options...
gambler172 Posted December 6, 2009 Share Posted December 6, 2009 Hi Batari You wrote.... * PAL 7800 console fix (those with the built-in Asteroids game will fail to detect Harmony and run Asteroids) I wonder,is there any Pal 7800 System without ASTEROIDS built in? I have many 7800 systems,but no Pal system without ASTEROIDS.So the new BIOS does not work?????? greetings Walter It means that this issue is fixed with the 1.03 bios. This was a problem with earlier bios versions. The harmony now works fine with pal 7800 consoles. Chris Hi Chris No,it does not work with mine..... How can i update my Harmony cart?I need a special description.... greetings Walter Quote Link to comment Share on other sites More sharing options...
gambler172 Posted December 6, 2009 Share Posted December 6, 2009 Hi Guys I found a manual and i tried to update my Harmony.First i connected my Harmony with the PC.The SD cars was seperate connected too.I downloaded the Eloader to my Harmony. And i copied the new Bios to my SD card.I tried both versions,Pal 50 and 60. None worked on my Pal system.When i start my Pal console,ASTEROIDS appears. Who can help? greetings walter Quote Link to comment Share on other sites More sharing options...
+batari Posted December 6, 2009 Author Share Posted December 6, 2009 Hi Batari You wrote.... * PAL 7800 console fix (those with the built-in Asteroids game will fail to detect Harmony and run Asteroids) I wonder,is there any Pal 7800 System without ASTEROIDS built in? I have many 7800 systems,but no Pal system without ASTEROIDS.So the new BIOS does not work?????? greetings Walter It means that this issue is fixed with the 1.03 bios. This was a problem with earlier bios versions. The harmony now works fine with pal 7800 consoles. Chris Hi Chris No,it does not work with mine..... How can i update my Harmony cart?I need a special description.... greetings Walter Here is the current manual, formatted for online viewing. Read the section on firmware updating. Harmony_Quickstart_Guide_full.pdf Quote Link to comment Share on other sites More sharing options...
cd-w Posted December 6, 2009 Share Posted December 6, 2009 Hi Guys I found a manual and i tried to update my Harmony.First i connected my Harmony with the PC.The SD cars was seperate connected too.I downloaded the Eloader to my Harmony. And i copied the new Bios to my SD card.I tried both versions,Pal 50 and 60. None worked on my Pal system.When i start my Pal console,ASTEROIDS appears. Who can help? greetings walter Can you let me know: Which version of the Harmony do you have (prototype or production)? Is the BIOS update successful, or does it fail even to update the BIOS? Did the card work before you did the bios update? Thanks, Chris Quote Link to comment Share on other sites More sharing options...
