kemmer Posted December 24, 2009 Share Posted December 24, 2009 Does anyone know of a replacement for the 5200 power supply? It seems like I remember that one of the 8 bit machines used the same PS. anyone know for sure? Quote Link to comment Share on other sites More sharing options...
brojamfootball Posted December 24, 2009 Share Posted December 24, 2009 Does anyone know of a replacement for the 5200 power supply? It seems like I remember that one of the 8 bit machines used the same PS. anyone know for sure? I think the 5200 is the only machine that uses that plug. I've heard you can mod other power supplies using the plug from a cordless phone battery and it will fit, however it won't have the little fin on it that guards against plugging it in with the wrong polarity. Quote Link to comment Share on other sites More sharing options...
+Mitch Posted December 24, 2009 Share Posted December 24, 2009 Does anyone know of a replacement for the 5200 power supply? It seems like I remember that one of the 8 bit machines used the same PS. anyone know for sure? I think the 5200 is the only machine that uses that plug. I've heard you can mod other power supplies using the plug from a cordless phone battery and it will fit, however it won't have the little fin on it that guards against plugging it in with the wrong polarity. You are thinking of the 7800. And no you don't want to use a power supply from the Atari 8bit computers, it will fry your 5200. Mitch Quote Link to comment Share on other sites More sharing options...
Bruce Tomlin Posted December 24, 2009 Share Posted December 24, 2009 The 5200 and the first version of the Sega Genesis use the same plug with opposite polarity. And although some 5200 power supplies are 12V 1A, enough of them are 9V 1A that there's no reason not to use the Sega power supply. If you go this way, it would really be best if you could mod the 5200 to include a bridge rectifier so as to be independent of polarity. Of course even better would be to find a modern switching power supply brick. They're much lighter, much more reliable, and it shouldn't be hard to find one in the 9V-12V 1A range. Quote Link to comment Share on other sites More sharing options...
brojamfootball Posted December 25, 2009 Share Posted December 25, 2009 Does anyone know of a replacement for the 5200 power supply? It seems like I remember that one of the 8 bit machines used the same PS. anyone know for sure? I think the 5200 is the only machine that uses that plug. I've heard you can mod other power supplies using the plug from a cordless phone battery and it will fit, however it won't have the little fin on it that guards against plugging it in with the wrong polarity. You are thinking of the 7800. And no you don't want to use a power supply from the Atari 8bit computers, it will fry your 5200. Mitch Oooh, yeah. Sorry, somehow got my brain turned sideways there. Quote Link to comment Share on other sites More sharing options...
cybercylon Posted December 25, 2009 Share Posted December 25, 2009 The NES power supply is pretty close to the specs for the 5200 one correct? Quote Link to comment Share on other sites More sharing options...
+Mitch Posted December 25, 2009 Share Posted December 25, 2009 The NES power supply is pretty close to the specs for the 5200 one correct? Only if you want to fry your 5200. The NES power supply outputs AC, the 5200 uses DC. Mitch Quote Link to comment Share on other sites More sharing options...
kemmer Posted December 31, 2009 Author Share Posted December 31, 2009 The 5200 and the first version of the Sega Genesis use the same plug with opposite polarity. And although some 5200 power supplies are 12V 1A, enough of them are 9V 1A that there's no reason not to use the Sega power supply. If you go this way, it would really be best if you could mod the 5200 to include a bridge rectifier so as to be independent of polarity. Of course even better would be to find a modern switching power supply brick. They're much lighter, much more reliable, and it shouldn't be hard to find one in the 9V-12V 1A range. couldn't I just cut the cord and switch the wires? Quote Link to comment Share on other sites More sharing options...
Cobra Kai Posted January 2, 2010 Share Posted January 2, 2010 Just buy an original PSU on ebay, there's always 4 or 5 new ones on there. Don't substitute just get an original, thats what I did. Quote Link to comment Share on other sites More sharing options...
