A2600 Posted October 30, 2002 Share Posted October 30, 2002 A monitor w/ video and audio rca jacks be used with an Atari 800?? Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted October 30, 2002 Share Posted October 30, 2002 Yes...you could also hook it to a VCR/TV's a/v input jacks (there is some debate over which would be a cleaner signal...but it should be much better than the standard arial cable). I believe that you need a 5-pin DIN cable (a Sega Genesis a/v cable should work). Quote Link to comment Share on other sites More sharing options...
Shawn Jefferson Posted October 30, 2002 Share Posted October 30, 2002 A monitor w/ video and audio rca jacks be used with an Atari 800?? Like you've already heard, it can, via the monitor port and a cable. These 5-pin DIN to RCA cables can be found almost anywhere. But you could order one from Best Electronics, or win one on eBay. I found one at the local thrift store for $0.25 CAD. A nicer option with the 800, would be the monitor cable to a S-Video cable if your TV supports it. Bob Woolley advised recently on csa8 to put a 100 ohm resister on the LUMA line, though I've never had any problems with my TV without it. Quote Link to comment Share on other sites More sharing options...
