bigguy4ever Posted January 23, 2010 Share Posted January 23, 2010 I got my 1`st 7800 today from ebay,,, All the 7800 games work, But not any 2600 games I feed it... Any advice Please... Thanks for your time.... Quote Link to comment Share on other sites More sharing options...
GroovyBee Posted January 23, 2010 Share Posted January 23, 2010 Any advice Please... Have you cleaned the contacts on the carts that don't work? Quote Link to comment Share on other sites More sharing options...
bigguy4ever Posted January 24, 2010 Author Share Posted January 24, 2010 Any advice Please... Have you cleaned the contacts on the carts that don't work? Yes I did, I sometime heat the sound of the game, but no picture...just black screen... Thanks Quote Link to comment Share on other sites More sharing options...
GroovyBee Posted January 24, 2010 Share Posted January 24, 2010 Do you get sound on all the 2600 games? Are you happy to take the unit apart and adjust a pot inside the console? If so, try adjusting R58 which affects the 2600 TIA colour on an NTSC machine. Quote Link to comment Share on other sites More sharing options...
bigguy4ever Posted January 24, 2010 Author Share Posted January 24, 2010 Do you get sound on all the 2600 games? Are you happy to take the unit apart and adjust a pot inside the console? If so, try adjusting R58 which affects the 2600 TIA colour on an NTSC machine. [/quot now i get nothing with 2600 games... I dont get it ??? Quote Link to comment Share on other sites More sharing options...
GroovyBee Posted January 24, 2010 Share Posted January 24, 2010 What did you clean the cart contacts with? Quote Link to comment Share on other sites More sharing options...
bigguy4ever Posted January 24, 2010 Author Share Posted January 24, 2010 What did you clean the cart contacts with? I used windex, I just got it in the mail yesterday... It was givig me a hard time with the 7800 games that came with it. Now the 7800 works one shot no problem.. All the 2600 games show nothing.. Yesterday I got sond and hear it working, but no picture. Thanks Quote Link to comment Share on other sites More sharing options...
GroovyBee Posted January 24, 2010 Share Posted January 24, 2010 I used windex, Erm... Its normal to use isopropyl alcohol. You want to clean them with a substance that doesn't leave any residue. Search the forum for cart cleaning tips if you aren't sure how to do it. Quote Link to comment Share on other sites More sharing options...
bigguy4ever Posted January 24, 2010 Author Share Posted January 24, 2010 I used windex, Erm... Its normal to use isopropyl alcohol. You want to clean them with a substance that doesn't leave any residue. Search the forum for cart cleaning tips if you aren't sure how to do it. I try thanks Quote Link to comment Share on other sites More sharing options...
bigguy4ever Posted January 24, 2010 Author Share Posted January 24, 2010 I used windex, Erm... Its normal to use isopropyl alcohol. You want to clean them with a substance that doesn't leave any residue. Search the forum for cart cleaning tips if you aren't sure how to do it. I try thanks Just try rubing alcohal and noting.. But my 7800 games are perfect one shot.... It has to be a trick to get it to work with 2600 games... Thanks Quote Link to comment Share on other sites More sharing options...
GroovyBee Posted January 24, 2010 Share Posted January 24, 2010 Just try rubing alcohal and noting.. But my 7800 games are perfect one shot.... It has to be a trick to get it to work with 2600 games... There is no trick. The console can detect the difference between 2600 and 7800 carts. How many 2600 carts have you tried? Quote Link to comment Share on other sites More sharing options...
bigguy4ever Posted January 25, 2010 Author Share Posted January 25, 2010 Just try rubing alcohal and noting.. But my 7800 games are perfect one shot.... It has to be a trick to get it to work with 2600 games... There is no trick. The console can detect the difference between 2600 and 7800 carts. How many 2600 carts have you tried? I had tryed 8 2600 carts, and nothing Quote Link to comment Share on other sites More sharing options...
RevEng Posted January 25, 2010 Share Posted January 25, 2010 It sounds like you have worse problems than clean contacts then. Since messing with the color adjustment pot made it go black, you might try cleaning/adjusting it. IMO it sounds like either the TIA chip has gone mostly bad (still providing audio but no video) or one of the other components between it and the modulator. Quote Link to comment Share on other sites More sharing options...
Shawn Posted January 25, 2010 Share Posted January 25, 2010 This isn't an uncommon issue. It sounds like pins 1,2 and 15,16 on the edge connector are grounding themselves out on pins 18,19 and 31, 32. Look into the edge connector and I think you will see what I mean. Use some precision screwdrivers or a darning needle to seperate them more back towards the plastic of the outside of the connector. You will find this should fix your problem. Quote Link to comment Share on other sites More sharing options...
bigguy4ever Posted January 26, 2010 Author Share Posted January 26, 2010 Thanks to all helpful hint to getting my 7800 in playing 2600 games.... Dear Shawn Sr., What is the oder of the pins numbers... Left to right or up and down,, I check if there was anything stuck in there, like the guy you helped before... But everything looks in order.. Are we allowed to post pic on this forum, I wanted to take a pic of the my pins and see if all is in order... I have the 7800 without the expan slot and newer model with the newner pins... THANKS TO ALL AGIAN Quote Link to comment Share on other sites More sharing options...
GroovyBee Posted January 26, 2010 Share Posted January 26, 2010 Are we allowed to post pic on this forum, I wanted to take a pic of the my pins and see if all is in order... Just make sure its either a *.jpg, *.gif or *.png and you'll be able to see the image inline. Quote Link to comment Share on other sites More sharing options...
Shawn Posted January 26, 2010 Share Posted January 26, 2010 Dear Shawn Sr., What is the oder of the pins numbers... Left to right or up and down,, Looking down at the cart port: Quote Link to comment Share on other sites More sharing options...
bigguy4ever Posted January 27, 2010 Author Share Posted January 27, 2010 Dear Shawn Sr., What is the oder of the pins numbers... Left to right or up and down,, Looking down at the cart port: Check, and did the like you told me.... Still nothing but only 7800 games worked.. Took apart the system to check, and found side of unit have a cracked pice that came apart.. Re glued together and put all back together... Took pictures of the pins, to show all pins have clear space between them... May not be clear enough.. Thanks agian Quote Link to comment Share on other sites More sharing options...
Shawn Posted January 27, 2010 Share Posted January 27, 2010 Yes you have proper clearance from those pics. I dunno what the issue could be exacty at this point. Quote Link to comment Share on other sites More sharing options...
bigguy4ever Posted January 28, 2010 Author Share Posted January 28, 2010 Yes you have proper clearance from those pics. I dunno what the issue could be exacty at this point. Thanks again for all the help...I guess I got to go shopping for another 7800, and keep this for backup to play only 78000 games.... Thank care to all Quote Link to comment Share on other sites More sharing options...
atari_envy Posted January 29, 2010 Share Posted January 29, 2010 Yes you have proper clearance from those pics. I dunno what the issue could be exacty at this point. Thanks again for all the help...I guess I got to go shopping for another 7800, and keep this for backup to play only 78000 games.... Thank care to all Why not just buy a 2600? If you get a light or heavy sixer, (IMHO) the picture is a little brighter than the 7800, some carts fit better into the 2600 slot, and some 2600 games don't run at all on the 7800. You could play 7800 games on the 7800 and 2600 games on the 2600, that is what I do. Plus there are 2600 games that use the Black and White switch for functions as well as difficulty switches which are inconvenient to access on the 7800. For example, playing Starmaster on the 7800 is a pain. Quote Link to comment Share on other sites More sharing options...
