InfernalKeith Posted February 25, 2010 Share Posted February 25, 2010 As reviewed in this month's Retrogaming Times Monthly, I'm planning to try to salvage the UK cassette game Atlantis, and bring it from cassette over into the modern, emulator-friendly world. I'm going to document the process for next month's RTM, if only so everyone can see my make-every-mistake-in-the-book-twice problem solving methods. Right now, the loose plan is this: 1. Load the code from tape twice, saving half to a new tape each time. 2. Load those two segments with the disk drives on, then save each to disk. 3. Combine the two in Classic99 via paste. 4. Figure out what variables the program is reading from its separate data file, then write a small program to read those variables from the tape and save them to disk. 5. Rewrite the program code to read the variables from disk instead -- or, instead, just add that data to the program code itself. 6. Run the code through the "BXB" program, which should allow it to run in XB with its BASIC character sets intact. 7. Save the whole mess to disk, run it in emulator. 8. Enjoy the adulation and gratitude of millions. IF I can get the program to load from tape with disk drives attached, I can skip 1-3 and just save the code to disk. Any suggestions or advice on this undertaking are welcome. I am buried in work right now, but I'm going to try to carve out a few hours to do this project over the weekend. Keith Quote Link to comment Share on other sites More sharing options...
Opry99er Posted February 25, 2010 Share Posted February 25, 2010 (edited) You should be able to just rip it to disk. I made a video I put on YouTube about a tape-disk-pc transfer--- maybe there are extenuating circumstances about this particular game program of which I am unaware, but a tape-->emulator transfer is a pretty straight forward process... This game looks cool!! Never seen it before! Edited February 25, 2010 by Opry99er Quote Link to comment Share on other sites More sharing options...
Opry99er Posted February 25, 2010 Share Posted February 25, 2010 In addition, once the program is transferred to disk, you can make the fonts look different too/-- even use a double dragon font or a colecovision one. . It wouldn't change the game, just make it more aesthetically pleasing. Quote Link to comment Share on other sites More sharing options...
InfernalKeith Posted February 25, 2010 Author Share Posted February 25, 2010 I should have mentioned, the reason it loads variables from a tape file is because it takes up every square inch of real estate in RAM. You can't RUN it from BASIC with a disk system connected. I haven't tried to load it with disk connected yet. If I can get it working in XB in Classic99, I'll leave further modifications to others. What do you have against square O's? Quote Link to comment Share on other sites More sharing options...
The Codex Posted February 25, 2010 Share Posted February 25, 2010 Fantastic, I am really looking forward to this one and hope you're able to pull it off. Let me know if I can help in any way, and good luck! Quote Link to comment Share on other sites More sharing options...
+retroclouds Posted February 26, 2010 Share Posted February 26, 2010 Looking forward to this Quote Link to comment Share on other sites More sharing options...
Opry99er Posted February 28, 2010 Share Posted February 28, 2010 Keith---2 suggestions. 1) CF7+? 2) Win99/4a has a CS1 simulator. You could digitize the tape and load it up in Win994a I'm sure you've already thought of all that... But also check out CS1er.com--- good stuff Owen Quote Link to comment Share on other sites More sharing options...
InfernalKeith Posted February 28, 2010 Author Share Posted February 28, 2010 OK, due to aforementioned work duties, this is NOT happening in time for the March issue of RTM. I did my article on Santa Paravia (see other thread) and turned it in, and I'll have to make a go of this next weekend. In the middle of a big work push right now, so everything else is having to wait (including the revisions to Herding Cats that I need to do). Hopefully in the next couple weeks, it'll all fall into place and I'll be a coding and modifying machine. Quote Link to comment Share on other sites More sharing options...
+retroclouds Posted March 27, 2010 Share Posted March 27, 2010 I think that the problem with Atlantis will be that it won't work if there any disk drives (or CF7+) connected to the console. Most likely the game requires all of VDP memory (which it won't get as there are some disk buffers in VDP). Just this morning I came accross an article in the Smart Programmer (february 1984), the trick for actually running the game from disk would be to use the Mini Memory module and some of it commands (SAVE MEMEXP2, OLD MEMEXP2) in combination with CALL LOAD(-31888,63,255) for turning the disk drives off. I have no TI time at all today but will get back tomorrow with the article from the Smart Programmer. Could be that an initial conversion program will be required for writing the BASIC program from >A000 to disk (that would be a one-time thing) and for the data files. Don't have the details on this yet. Would help if the cassette file would be available as WAV for processing with CS1er Quote Link to comment Share on other sites More sharing options...
The Codex Posted March 27, 2010 Share Posted March 27, 2010 What you say? Not understand. Just want magic from box. Do dance, offer goat, paint face. Box give magic now! Quote Link to comment Share on other sites More sharing options...
InfernalKeith Posted March 28, 2010 Author Share Posted March 28, 2010 I think that the problem with Atlantis will be that it won't work if there any disk drives (or CF7+) connected to the console. Most likely the game requires all of VDP memory (which it won't get as there are some disk buffers in VDP). Just this morning I came accross an article in the Smart Programmer (february 1984), the trick for actually running the game from disk would be to use the Mini Memory module and some of it commands (SAVE MEMEXP2, OLD MEMEXP2) in combination with CALL LOAD(-31888,63,255) for turning the disk drives off. I have no TI time at all today but will get back tomorrow with the article from the Smart Programmer. Could be that an initial conversion program will be required for writing the BASIC program from >A000 to disk (that would be a one-time thing) and for the data files. Don't have the details on this yet. Would help if the cassette file would be available as WAV for processing with CS1er You expect me to know how to do any of that? Do you see any reason for my original, somewhat cumbersome plan not to work? If I OLD CS1, delete some lines, then save it... then OLD CS1 again, delete the other lines, save THAT... then merge the two half-programs and run it through BXB to make it work in Extended BASIC. Suddenly we can access the 32K, problem is solved. Then we find out what the contents of the data file are that the program loads, replace that with hard-coded variables in a subroutine, and we're all set. I'm hoping to get a bunch of this done tomorrow -- big project is over and I may have some TI time before the next wave of work submerges me. Quote Link to comment Share on other sites More sharing options...
+retroclouds Posted March 28, 2010 Share Posted March 28, 2010 You expect me to know how to do any of that? Do you see any reason for my original, somewhat cumbersome plan not to work? If I OLD CS1, delete some lines, then save it... then OLD CS1 again, delete the other lines, save THAT... then merge the two half-programs and run it through BXB to make it work in Extended BASIC. Suddenly we can access the 32K, problem is solved. Then we find out what the contents of the data file are that the program loads, replace that with hard-coded variables in a subroutine, and we're all set. I'm hoping to get a bunch of this done tomorrow -- big project is over and I may have some TI time before the next wave of work submerges me. ok, that's a good plan Think this may work. Guess it mainly depends if the BASIC game uses character set 15 and 16, which aren't available in Extended Basic. I don't know what BXB is. Is it used for dealing with the character set issue ? Good luck Quote Link to comment Share on other sites More sharing options...
+retroclouds Posted March 28, 2010 Share Posted March 28, 2010 (edited) Below is the article I mentioned yesterday. It is extracted from The Smart Programmer February 1984 and deals with Basic programs that are too large to run from disk. A gentleman from Georgia recently asked us how to get a Basic program that is stored on disk and is too large to run with the disk drives attached to run. The problem was such that the program could be loaded into memory from the disk but it contains a large number of numeric and string variables which eat up a lot of memory when the program is running. In Basic the computer does not recognize Expansion Memory as a place to load programs so they must load and run from VDP RAM. Unfortunately the disk buffer space is also in VDP RAM and uses up some of the space that may be necessary to run large Basic programs. Even with the CALL FILES(1) command there is still aprox 500 bytes retained as a disk buffer and this may be just enough to crash the program. The CALL LOAD, which is listed below, will shut off the disk drives but in Basic you must type in NEW to open up the memory space. Naturally whenever you type in NEW your program is cleared out of memory and that was the problem. The solution requires the Mini-Memory module to be plugged in the cartridge port and Expansion Memory to be attached and turned on. With the Mini-Mem in the port there are a few new commands added to the Basic language, even though you have selected TI BASIC. The ones that we are concerned with are SAVE and OLD, MINIMEM, EXPMEM1, EXPMEM2 and out of these we really only need SAVE and OLD EXPMEM2. The procedure for running these large Basic programs from disk is as follows: 1. Power Up, select Basic and type in CALL INIT. This will initialize memory expansion and it will also clear out what ever was stored in the Mini-Mem module. If you want to retain what is in the Mini-Mem just turn off the memory expansion and then turn it back on and that will clear out without erasing the Mini-Mem. 2. Load the program you want to run from your disk. OLD DSK1.xxxxxxx 3. Type in SAVE EXPEM2 and press ENTER. This will copy the program in VDP RAM into the expansion memory. 4. Type in CALL LOAD(-31888,63,255) and press ENTER. This tells the computer not to reserve any room in VDP RAM for the disk buffers. 5. Now type in NEW and press ENTER. You have just opened up the extra memory space in VDP RAM that the disk was reserving. But since Basic does not recognize expansion memory your program is still intact in high exp-memory, addresses hex >A000 through >FFFF. 6. Just type in OLD EXPMEM2 and press ENTER and this will copy the program in the exp-memory back into the VDP RAM program area. A copy of the program is still in the exp-memory and it will remain there until you turn off the exp-memory, save another program into that space or type in CALL INIT. No, you can't MERGE Basic programs. 7. Type in RUN and press ENTER and the program should now run without giving you a MEMORY FULL ERROR. We didn't use SAVE MINIMEM or SAVE EXPMEM1 because neither one of these spaces are large enough to store a large Basic Program, 12K+. The MINIMEM space is 4K of RAM, the EXPMEM1 space is 8K of RAM and the EXPMEM2 is 24K of RAM. Also the EXPMEM1 space will allow you to save a program out there but it doesn't like OLD EXPMEM1 so you can't bring it back. You can use any one of these three names in an OPEN statement for files provided you are not linking to an assembly language subroutine in which case it is best to just use EXPMEM2 in your OPEN statements for files. The best solution, if you have exp-memory, is to rework the programs to allow them to be loaded directly into exp-memory via Extended Basic. You will probably have to rework some of the CALL CHAR's, HCHAR's, VCHAR's and CALL COLOR's to compensate for the lack of characters sets 15 and 16 in Extended Basic. You will however find that they run a little faster and they are easier to edit in Extended Basic. Edited March 28, 2010 by retroclouds Quote Link to comment Share on other sites More sharing options...
InfernalKeith Posted March 28, 2010 Author Share Posted March 28, 2010 You expect me to know how to do any of that? Do you see any reason for my original, somewhat cumbersome plan not to work? If I OLD CS1, delete some lines, then save it... then OLD CS1 again, delete the other lines, save THAT... then merge the two half-programs and run it through BXB to make it work in Extended BASIC. Suddenly we can access the 32K, problem is solved. Then we find out what the contents of the data file are that the program loads, replace that with hard-coded variables in a subroutine, and we're all set. I'm hoping to get a bunch of this done tomorrow -- big project is over and I may have some TI time before the next wave of work submerges me. ok, that's a good plan Think this may work. Guess it mainly depends if the BASIC game uses character set 15 and 16, which aren't available in Extended Basic. I don't know what BXB is. Is it used for dealing with the character set issue ? Good luck The game does use sets 15 and 16. BXB is a program that allows you to run such sprite-free BASIC programs in XB while still using all 16 charsets. I haven't tried it yet, so I'm really hoping it works. I have a sick little one on my hands this weekend, so if she doesn't feel better when she wakes up this morning, my TI plans may be shot. We'll have to see how it goes. :/ Quote Link to comment Share on other sites More sharing options...
sometimes99er Posted March 28, 2010 Share Posted March 28, 2010 (edited) - Edited September 12, 2012 by sometimes99er Quote Link to comment Share on other sites More sharing options...
InfernalKeith Posted March 31, 2010 Author Share Posted March 31, 2010 I missed the deadline for this month's Retrogaming Times Monthly, so if you go there looking for an Atlantis article, you'll be sad. But fear not, I AM working on it, and hope to have some good news shortly. At the very least, I'm gonna have the program rescued from cassette before I leave for vacation, and hopefully I can then finish the rest of the conversion process via Classic99. Quote Link to comment Share on other sites More sharing options...
The Codex Posted March 31, 2010 Share Posted March 31, 2010 That a bad-news-good-news kind of thing mate, sorry about the former but glad to hear about the latter. Here's wishing you good luck in your continued conservation/restoration efforts! Quote Link to comment Share on other sites More sharing options...
InfernalKeith Posted April 29, 2010 Author Share Posted April 29, 2010 BUMP! I'm now, RIGHT NOW, in real time, as we speak, sitting down to work on Atlantis. I plan to post here as my efforts progress (or not). Wish me luck! Step one: load game in BASIC, delete first half, save to CS1, load game again, delete second half, save to CS1. Then load each half, save to CF7, and move to Classic99. After that, if I'm not already driven to drink, I'll break for lunch and move onward. Quote Link to comment Share on other sites More sharing options...
InfernalKeith Posted April 29, 2010 Author Share Posted April 29, 2010 OK, one early success. The game loaded successfully with the CF7 installed, and saved to DSK1 without incident. No lengthy deleting process necessary. It wouldn't have run properly, but I at least got it onto the CF7. Next step - to download the "BXB" software which is supposed to make it work in Extended BASIC, and then print out the listing so I can extract the data from side two of the cassette and build it into the program listing itself, as opposed to being in an external file. I may finish this sometime this year after all! Quote Link to comment Share on other sites More sharing options...
InfernalKeith Posted April 29, 2010 Author Share Posted April 29, 2010 1 REM 1 2 DIM X1(,Y1(,E$(,X9(3),TY(3),TX(3),S1(2),AD(2),SF(2) 3 DEF YT=ASC(SEG$(CF$,F+3,1)) 4 DEF YS=VAL(SEG$(CF$,F+4,3)) 5 DEF YR(Q)=VAL(SEG$(T$,Q,2)) 6 DEF YQ(Q)=VAL(SEG$(L6$,Q,1)) 7 DEF YP=((1-0+1)*RND)+0 8 DEF YO(Q)=ASC(SEG$(L6$,Q,1)) 9 DEF CA(Q)=ASC(SEG$(SE$,SY+Q,1))-60 10 DEF MO$(Q)=CHR$(Q+60) 11 DEF DG(Q)=SEG$(I$,M+Q,1)=SEG$(UI$,F,1) 12 DEF QW(Q)=ASC(SEG$(ER$,WF+Q,1))-60 13 DEF YU(Q)=ASC(SEG$(CF$,F+Q,1))-60 14 SA(0)=118 15 SA(2)=113 16 AD(0)=1 17 FH=1 18 SF(0)=115 19 SF(2)=113 20 CALL CLEAR 21 K$="QP A" 22 GH=1005 23 OPEN #1:"CS1",SEQUENTIAL,INTERNAL,INPUT,FIXED 190 24 CALL CLEAR 25 CALL SCREEN(2) 26 CALL COLOR(1,2,2) 27 FOR F=1 TO 3 28 INPUT #1:J$ 29 PRINT J$: : 30 NEXT F 31 CALL CHAR(42,"00FF00FF00FF00FF") 32 CALL SCREEN(5) 33 CALL COLOR(1,5,5) 34 INPUT #1:ES$ 35 INPUT #1:SE$ 36 INPUT #1:RR$ 37 EE$=ES$&SE$ 38 FOR F=1 TO 8 39 INPUT #1:E$(F) 40 NEXT F 41 FOR F=0 TO 3 42 INPUT #1:TX(F),TY(F) 43 NEXT F 44 FOR F=0 TO 8 45 INPUT #1:X1(F),Y1(F) 46 NEXT F 47 FOR F=1 TO 34 48 INPUT #1:C$ 49 CALL CHAR(VAL(SEG$(C$,1,3)),SEG$(C$,4,LEN(C$)-3)) 50 NEXT F 51 INPUT #1:HL$ 52 INPUT #1:I$ 53 CLOSE #1 54 J$="" 55 CALL CLEAR 56 SF(0)=2 57 SF(2)=0 58 SN=0 59 TL=1 60 IO=18 61 IF SC<HI THEN 64 62 HI=SC 63 HG=0 64 TY$=STR$(HI) 65 SC=0 66 VV=1 67 C$=HL$ 68 X=12 69 Y=15 70 SE$=EE$ 71 ER$=RR$ 72 B=3 73 A1=3 74 JK=99 75 W1=98 76 CB=0 77 LK$="" 78 L=13 79 T$="13102!LFZT" 80 IZ=1 81 GOSUB 446 82 T$="15103!KPZTUJDL" 83 GOSUB 446 84 T$="1809QSFTT!2!PS!3" 85 GOSUB 446 86 CALL KEY(0,K,S) 87 IF(K<>49)*(K<>50)THEN 86 ELSE 88 88 KY=K-48 89 FE=17 90 CALL CLEAR 91 CALL SCREEN(5) 92 FOR F=1 TO 16 93 CALL COLOR(F,5,5) 94 NEXT F 95 IZ=1 96 RESTORE 428 97 READ CF$ 98 GOSUB 450 99 READ CF$ 100 JK=L 101 W1=L 102 YL=56 103 GOSUB 450 104 RESTORE 427 105 GOSUB 440 106 RESTORE 426 107 CALL HCHAR(24,12,129,17) 108 CALL SCREEN(2) 109 FOR F=1 TO 8 110 READ C4,C5,C6 111 CALL COLOR(C4,C5,C6) 112 NEXT F 113 P=2 114 P1=11 115 GOSUB 436 116 IZ=0 117 IF W1=JK THEN 119 118 L=INT((28-13+1)*RND)+13 119 KK=28 120 GOSUB 413 121 EL=VAL(SEG$(STR$(L),1,1)) 122 EL2=VAL(SEG$(STR$(L),2,1)) 123 A2=1 124 FOR F=0 TO EL2 125 EL5=ASC(SEG$(E$(EL),A2,1))-60 126 A2=A2+EL5 127 NEXT F 128 L2$=SEG$(E$(EL),A2-EL5,EL5) 129 L6$=SEG$(L2$,6,(ASC(SEG$(L2$,1,1))-60)-5) 130 L9=LEN(L6$) 131 IF L<48 THEN 152 132 U=96 133 GOSUB 457 134 L9=VAL(SEG$(L6$,1,1)) 135 FOR F=1 TO L9*4 STEP 4 136 FOR J=0 TO 3 137 X9(J)=YO(F+(J+1))-80 138 NEXT J 139 RANDOMIZE YQ(LEN(L6$)) 140 IF X9(0)<0 THEN 148 141 FOR I=X9(0)TO X9(3) 142 CALL HCHAR(I,X9(1)+YP,32,X9(2)-YP) 143 NEXT I 144 NEXT F 145 CALL COLOR(1,8,5) 146 CALL COLOR(9,14,5) 147 GOTO 167 148 FOR I=ABS(X9(1))TO ABS(X9(2)) 149 CALL VCHAR(ABS(X9(0))+YP,I,32,ABS(X9(3))-YP) 150 NEXT I 151 GOTO 144 152 U=32 153 GOSUB 457 154 FOR F=1 TO L9 155 ON YQ(F)GOSUB 378,391,393,403,405,403,405,411 156 NEXT F 157 IF(L<>46)*(L>=44)*(L<=47)THEN 158 ELSE 145 158 RESTORE 435 159 FOR F=1 TO EL2-3 160 READ RC,RB 161 NEXT F 162 RANDOMIZE 5 163 FOR F=10 TO 19 164 CALL HCHAR(F,RC+YP,32,RB-YP) 165 NEXT F 166 GOTO 145 167 CALL HCHAR(2+(TL*2),28,58) 168 CALL HCHAR(2+(EL*2),28,105) 169 FOR SY=1 TO LEN(SE$)STEP 5 170 IF CA(1)=L THEN 174 171 NEXT SY 172 ST=5 173 GOTO 194 174 MV=CA(0) 175 XF=CA(2) 176 YF=CA(3) 177 HJ=CA(4) 178 LI=CA(1) 179 SH=SA(MV+1) 180 RESTORE 431 181 FOR F=1 TO HJ 182 READ CR$ 183 NEXT F 184 FOR F=0 TO 9 185 CALL CHAR(113+F,CR$) 186 READ CR$ 187 NEXT F 188 RT=INT((16-3+1)*RND)+3 189 ST=1 190 CALL HCHAR(YF,XF,SH) 191 CALL HCHAR(YF,XF+1,SH+1) 192 CALL COLOR(11,RT,5) 193 CALL COLOR(12,RT,5) 194 FOR WF=1 TO LEN(ER$)STEP 4 195 IF QW(0)=L THEN 198 196 NEXT WF 197 GOTO 200 198 CALL HCHAR(QW(1),QW(2),QW(3)) 199 CALL COLOR(2,16,5) 200 RO=0 201 IZ=0 202 IF(CB=1874)*(UI=56)THEN 335 203 XK=X 204 A9=A1 205 CALL GCHAR(X,Y,TK) 206 IF TK<>96 THEN 218 207 ON A9 GOTO 218,208,208,213,218,213,208,208 208 X=X+1 209 IF X<19 THEN 205 210 X=XK 211 A9=4 212 GOTO 205 213 X=X-1 214 IF X>3 THEN 205 215 X=XK 216 A9=2 217 GOTO 205 218 IF(T>0)*(T<8)THEN 256 ELSE 255 219 X=X-X1(A1) 220 Y=Y-Y1(A1) 221 ON POS("`+>@?=(*,!",CHR$(S),1)+1 GOTO 222,353,353,223,223,223,223,315,325,339,325 222 IF(S>113)*(S<122)THEN 353 ELSE 263 223 LO=ASC(SEG$(SEG$(L2$,2,4),(S-60),1))-60 224 IF(LO=L)+(L=0)THEN 263 225 CALL HCHAR(X,Y,32) 226 TL=EL 227 UY$=SEG$(SE$,1,SY-1) 228 UT$=SEG$(SE$,SY+5,LEN(SE$)-SY+5) 229 UI=LO 230 RESTORE 425 231 FOR F=1 TO 10 STEP 2 232 READ DK,FK 233 CALL COLOR(DK,FK,5) 234 NEXT F 235 IF TY(S-61)=0 THEN 237 236 Y=TY(S-61) 237 IF TX(S-61)=0 THEN 239 238 X=TX(S-61) 239 IF(AB=0)*(ST=5)THEN 248 240 IF AB=0 THEN 246 241 LI=ASC(SEG$(SEG$(L2$,2,4),(GC-60),1))-60 242 IF TY(GC-61)=0 THEN 244 243 XF=TY(GC-61) 244 IF TX(GC-61)=0 THEN 246 245 YF=TX(GC-61) 246 SE$=UY$&MO$(MV)&MO$(LI)&MO$(XF)&MO$(YF)&MO$(HJ)&UT$ 247 AB=0 248 IF RO=0 THEN 253 249 WE$=SEG$(ER$,1,WF-1) 250 WW$=SEG$(ER$,WF,3)&CHR$(RO) 251 WR$=SEG$(ER$,WF+4,LEN(ER$)-WF+4) 252 ER$=WE$&WW$&WR$ 253 L=LO 254 IF UI<50 THEN 121 ELSE 421 255 FOR T=1 TO 8 256 FOR F=1 TO B 257 IF B=3 THEN 263 258 X=X+X1(A1) 259 Y=Y+Y1(A1) 260 CALL GCHAR(X,Y,S) 261 IF S<>32 THEN 219 262 CALL HCHAR(X+(X1(A1)*-1),Y+(Y1(A1)*-1),32) 263 CALL HCHAR(X,Y,143+(A1*2)-1) 264 ON KY GOTO 295,298 265 CALL HCHAR(X,Y,143+(A1*2)) 266 NEXT F 267 ON ST GOTO 268,305,310,302,278,272 268 CALL GCHAR(YF,XF+MV+AD(MV+1)+MV,S8) 269 IF(S8<>32)THEN 300 270 ST=6 271 GOTO 278 272 XF=XF+MV 273 CALL HCHAR(YF,XF+(MV*-1),32,2) 274 CALL HCHAR(YF,XF,SH+SN) 275 CALL HCHAR(YF,XF+1,SH+SN+1) 276 ST=1 277 SN=SF(SN) 278 NEXT T 279 IO=IO-1 280 CALL HCHAR(23,IO+12,92) 281 IF IO=0 THEN 365 ELSE 255 282 IF S<>32 THEN 219 283 A1=A1-1 284 IF A1>0 THEN 266 285 A1=8 286 GOTO 266 287 A1=A1+1 288 IF A1<9 THEN 266 289 A1=1 290 GOTO 266 291 B=3 292 GOTO 265 293 B=2 294 GOTO 265 295 CALL KEY(3,K,S) 296 IF S=0 THEN 265 297 ON POS(K$,CHR$(K),1)+1 GOTO 265,283,287,291,293 298 CALL JOYST(1,XJ,YJ) 299 ON POS("04@<",CHR$((((XJ*2)+(YJ))++48),1)+1 GOTO 265,283,293,287,291 300 ON POS("`>@?=",CHR$(S8),1)+1 GOTO 301,302,310,310,310,310 301 IF((S8>144)*(S8<159))THEN 357 302 MV=MV*-1 303 ST=2 304 GOTO 255 305 CALL HCHAR(YF,XF+SGN(1-(MV*-1)),SH+AD((MV*-1)+1)) 306 CALL HCHAR(YF,XF+SGN((MV*-1)+1),SH+4) 307 ST=1 308 SH=SA(MV+1) 309 GOTO 255 310 GC=S8 311 AB=1 312 CALL HCHAR(YF,XF,32,2) 313 ST=5 314 GOTO 255 315 RO=101 316 B=3 317 SC=SC+100 318 CALL HCHAR(QW(1),QW(2),41) 319 HG=HG+1 320 CALL SOUND(10,4000,0) 321 KK=16 322 TY$=STR$(SC) 323 GOSUB 413 324 IF(T>0)*(T<8)THEN 256 ELSE 255 325 B=3 326 FOR F=IO TO 17 327 CALL SOUND(-100,-7,0) 328 CALL HCHAR(23,11+F,104) 329 NEXT F 330 IO=17 331 IF S=33 THEN 255 332 CALL HCHAR(QW(1),QW(2),43) 333 RO=103 334 GOTO 255 335 T$="0810"&C$ 336 GOSUB 446 337 C$=HL$ 338 GOTO 56 339 CALL SOUND(30,1000,0) 340 CALL HCHAR(QW(1),QW(2),32) 341 RO=92 342 SC=SC+200 343 HG=HG+1 344 GOTO 321 345 FE=FE-1 346 CALL HCHAR(24,13+FE-1,60) 347 FOR F=FE/2 TO 1 STEP-1 348 CALL SOUND(2,1500,5) 349 NEXT F 350 IF FE=0 THEN 352 351 B=3 352 RETURN 353 GOSUB 345 354 IF FE=0 THEN 360 355 IF(S=96)+(S=43)THEN 255 356 IF ST<>2 THEN 302 357 GOSUB 345 358 IF FE=0 THEN 360 359 IF ST<>2 THEN 302 ELSE 255 360 CALL SOUND(4000,1500,5) 361 T$="1007OP=MJGF=EFUFDUFE" 362 IZ=1 363 GOSUB 446 364 GOTO 56 365 T$="1010TVGGPDBUJPO" 366 IZ=1 367 GOSUB 446 368 GOTO 56 369 GOSUB 371 370 RETURN 371 AC$="" 372 FOR F=1 TO 11 373 AC$=AC$&CHR$(ASC(SEG$(C$,F,1))+(UI*VV)) 374 NEXT F 375 C$=AC$ 376 VV=VV*-1 377 RETURN 378 FOR I=2 TO 8 379 CALL HCHAR(I,4,33,23) 380 NEXT I 381 RETURN 382 RANDOMIZE YQ(F+1) 383 H1=0 384 FOR I=H5 TO 30-H5 STEP SGN((30-H5)-H5) 385 H=YP+H1 386 CALL VCHAR(20-H,I,96,H) 387 H1=H1+(YO(F+2)/100) 388 NEXT I 389 F=F+2 390 RETURN 391 H5=4 392 GOTO 382 393 H5=26 394 GOTO 382 395 RANDOMIZE YQ(F+1) 396 H1=YO(F+2)-60 397 FOR I=H5 TO 15 STEP SGN(15-H5) 398 H=((H1-(H1/2)+1)*RND)+(H1/2) 399 ON YQ(F)GOSUB 2,2,2,407,407,409,409 400 NEXT I 401 F=F+2 402 RETURN 403 H5=4 404 GOTO 395 405 H5=26 406 GOTO 395 407 CALL VCHAR(20-H,I,96,H) 408 RETURN 409 CALL VCHAR(2,I,96,H) 410 RETURN 411 CALL VCHAR(2,26,96,18) 412 RETURN 413 TP=KK-LEN(TY$) 414 IF HG<>26 THEN 417 415 ER$=RR$ 416 HG=0 417 FOR F=1 TO LEN(TY$) 418 CALL HCHAR(21,TP+F,ASC(SEG$(TY$,F,1))) 419 NEXT F 420 RETURN 421 CB=CB+UI 422 IF CB>1900 THEN 121 423 GOSUB 369 424 GOTO 121 425 DATA 2,5,11,5,12,5,9,5,1,5 426 DATA 16,2,5,15,2,5,1,8,5,3,2,11,4,2,11,10,11,5,2,16,5,13,7,11 427 DATA 9,"2104TDPSF=111111","2119IJ=111111","2304PYZHFO","0528E","0828F","1128Q","1428U","1728I","2404FOFSHZ" 428 DATA "*==@073*=W@150+==@033+P=@165+Q@<026+R@<026+S@<026+T@<026*>X<018*>Y<018" 429 DATA "+SHh017*?X:016+=@=024+P@>024*=W?020" 430 DATA 19,0,2,0,0,4,0,25 431 DATA "80C0E7DF8702","80C0FEFFF8","00000187DFE7C380","0080C0FEF7FC","84CEF5FFF1110E","01037FEF3F" 432 DATA "0103E7FBE14","0000017FEF3F","0080C0E1FBE7C301","2173AFDF8F885020","F00EE31C01E21C" 433 DATA "1C3AE7E73A1C","000700001F00030C","00C62FBD5D1D2FC6","3C7EE7C3C3E77E3C" 434 DATA "385CE7E65D38","00F30CC03C837807","0063B4BBBCB8B463","00E000C0300020C0","3C66C38981C3673C" 435 DATA 8,4,13,4,0,0,13,6 436 FOR F=5 TO 8 437 CALL COLOR(F,P,P1) 438 NEXT F 439 RETURN 440 READ A 441 FOR F=1 TO A 442 READ T$ 443 GOSUB 446 444 NEXT F 445 RETURN 446 FOR I=5 TO LEN(T$) 447 CALL HCHAR(YR(1),YR(3)+I-4,ASC(SEG$(T$,I,1))-IZ) 448 NEXT I 449 RETURN 450 FOR F=1 TO LEN(CF$)STEP 7 451 IF SEG$(CF$,F,1)="*" THEN 454 452 CALL HCHAR(YU(1),YU(2),YT,YS) 453 GOTO 455 454 CALL VCHAR(YU(1),YU(2),YT,YS) 455 NEXT F 456 RETURN 457 FOR F=2 TO 19 458 CALL HCHAR(F,4,U,23) 459 NEXT F 460 RETURN 1 Quote Link to comment Share on other sites More sharing options...
The Codex Posted April 29, 2010 Share Posted April 29, 2010 Superb! Well done so far man. That's not the whole program there, is it? If so, I'm even more impressed with what the programmers did. Quote Link to comment Share on other sites More sharing options...
InfernalKeith Posted April 29, 2010 Author Share Posted April 29, 2010 That would be it! I look forward to delving into its guts a bit more once it's running in XB, it looks like insanely well thought out and ruthlessly efficient code. I can't wait for you guys to see this game in action, even in agonizing BASIC speeds it's impressive as hell. I got the BXB routines pasted in via the PASTE feature in Classic99 (a little bit of a cheat, I guess, not MERGE-ing it, but the goal here is getting it to work, not being pure to original methods). Next up, extracting all that data from the original data file. Shouldn't take me too long. I have to knock off at 2 for an interview, but I'll be back at this later on. I'd love to have it done by tonight! Quote Link to comment Share on other sites More sharing options...
The Codex Posted April 29, 2010 Share Posted April 29, 2010 (edited) Man alive, that's great! I hope to check it out tonight myself, at least in a code forensics kind of way. Seriously tight code, it's a good thing we weren't up against those guys in the 30-line competition. Edited April 29, 2010 by The Codex Quote Link to comment Share on other sites More sharing options...
Opry99er Posted April 29, 2010 Share Posted April 29, 2010 A 30 line console BASIC contest..... Print loop pong would be the best thing we could get. Not having access to multiple statement lines, I'd love to see a "good" 30/10 console BASIC game. Although, Adamantyr's idea for a tape loaded console BASIC game is pretty exciting. I might pull out my old BASIC shoes and go for a walk. Quote Link to comment Share on other sites More sharing options...
InfernalKeith Posted April 29, 2010 Author Share Posted April 29, 2010 A 30 line console BASIC contest..... Print loop pong would be the best thing we could get. Not having access to multiple statement lines, I'd love to see a "good" 30/10 console BASIC game. Although, Adamantyr's idea for a tape loaded console BASIC game is pretty exciting. I might pull out my old BASIC shoes and go for a walk. I can hear the old guys now. "You know what we called OUR 'thirty line programming contest'? OUR ENTIRE CAREER! We did everything in 3.2K with half of that reserved for an 8" disk driver that someone forgot to remove from the beta code! AND WE LIKED IT!!!! We programmed uphill both ways!! In snow!!!" Actually, a big hero of mine in these matters is Jeffrey Daniels, over at the Denial Vic 20 forum. He recently released a collection of six games that run on an unexpanded 3K (!!!) Vic-20 in BASIC, and every game is a keeper. Of course, Vic BASIC is Indy 500 fast compared to TI console BASIC... Quote Link to comment Share on other sites More sharing options...
