_Fandal_ Posted March 12, 2010 Share Posted March 12, 2010 Hi all! Some time ago, Allan asked in this topic if it is possible to trigger secret message in 5200 version of Rescue of Fractalus. I was able to find how to trigger it disassembling cartridge dump but I need some testing on real HW because there is some weird behaviour of RoF in Atari800Win PLus emulator. What is going on? I noticed that sometimes I must press # or * keys several times to change starting level. In other words, some key clicks are ignored or not registered. Does it works the same way on real HW or is it just some emulator issue? Why am I asking? To trigger the secret message you must do this: select level 05 and press "5" key to accept the first number of activation code. Complet activation code is 05, 12, 15, 16, 11, 13, 14 and all numbers must be entered by pressing "5" key. And that is the problem in my favourite emulator as I usually must press #5 several times. I can't believe it was supposed to work this way... Could someone test this on real HW, please? F. Quote Link to comment Share on other sites More sharing options...
Shannon Posted March 12, 2010 Share Posted March 12, 2010 It'll be interesting to see if this actually exists.. Quote Link to comment Share on other sites More sharing options...
+Allan Posted March 12, 2010 Share Posted March 12, 2010 First, thank You Fandal for looking at this. I'm a bit confused about how your saying to do this. Are you saying while holding down the '5' key, select level 5 with the '#' or '*' keys and then while still holding down the '5' key hit 05, 12, 15, 16, 11, 13, 14 keys? (sorry, I can be slow sometimes. ) By the way if you hit '0' at any time in the title screen it will take to the 'Droid' demo level, even if you're holding down another key. I tried it this way on the hardware but got nothing. Allan Quote Link to comment Share on other sites More sharing options...
_Fandal_ Posted March 12, 2010 Author Share Posted March 12, 2010 First, thank You Fandal for looking at this. I'm a bit confused about how your saying to do this. Are you saying while holding down the '5' key, select level 5 with the '#' or '*' keys and then while still holding down the '5' key hit 05, 12, 15, 16, 11, 13, 14 keys? (sorry, I can be slow sometimes. ) By the way if you hit '0' at any time in the title screen it will take to the 'Droid' demo level, even if you're holding down another key. I tried it this way on the hardware but got nothing. Allan Sorry for my broken English. Select level 05 using "#" or "*" keys and then press "5" key to enter the first part of code. Then select level 12 and press "5" again. Then do the same with levels 15, 16, 11, 13, 14. Names of authors should appear then. It works in emulator. I just don't understand why some key clicks are ignored in emulator. It hapens to me very often while selecting level and it seems to happen while pressing "5" key as well. I need to know if the same issue happens on real HW. F. Quote Link to comment Share on other sites More sharing options...
+Allan Posted March 12, 2010 Share Posted March 12, 2010 Cool. It works. You ROCK Fandal. Again a big 'Thank You!' A twenty-five year old mystery solved. Allan Quote Link to comment Share on other sites More sharing options...
+Allan Posted March 12, 2010 Share Posted March 12, 2010 It worked for me on the first try once I understood how to do it. I just tried it a second time and it worked again so I think the key pressing problem is an emulator issue. Allan Quote Link to comment Share on other sites More sharing options...
iwan-iwanowitsch-goratschin Posted March 12, 2010 Share Posted March 12, 2010 Quote Link to comment Share on other sites More sharing options...
+Allan Posted March 12, 2010 Share Posted March 12, 2010 OK I jump the gun. I didn't think about the code itself. So what does 5,12,15,16,11,13,14 mean? If you do a strait letter to number code it's E L O P K M N. If you start at 5 using 'press 5 before selecting each level' as a key, you get: A H K L G I R. Any ideas anybody? Allan Quote Link to comment Share on other sites More sharing options...
_Fandal_ Posted March 12, 2010 Author Share Posted March 12, 2010 It worked for me on the first try once I understood how to do it. I just tried it a second time and it worked again so I think the key pressing problem is an emulator issue. Allan Nice to hear that! Any other mystery to solve? F. Quote Link to comment Share on other sites More sharing options...
+Mitch Posted March 12, 2010 Share Posted March 12, 2010 Nice to hear that! Any other mystery to solve? F. Sure, can you find out how to trigger the hidden invincibility code in 7800 Planet Smashers? Nice work on finding the RoF easter egg, by the way. Mitch Quote Link to comment Share on other sites More sharing options...
Kr0tki Posted March 12, 2010 Share Posted March 12, 2010 Does it works the same way on real HW or is it just some emulator issue? It's a known issue with Atari800WinPLus - it has only partially working emulation of 5200 buttons. Any other mystery to solve? There's a similar easter egg in the 8-bit Ballblazer - maybe you could check if it exists in the 5200 version? Quote Link to comment Share on other sites More sharing options...
+Allan Posted March 13, 2010 Share Posted March 13, 2010 Does it works the same way on real HW or is it just some emulator issue? It's a known issue with Atari800WinPLus - it has only partially working emulation of 5200 buttons. Any other mystery to solve? There's a similar easter egg in the 8-bit Ballblazer - maybe you could check if it exists in the 5200 version? It's got to be in there. The levels are 1-9. So some kind of combination. Allan Quote Link to comment Share on other sites More sharing options...
_Fandal_ Posted March 13, 2010 Author Share Posted March 13, 2010 (edited) Does it works the same way on real HW or is it just some emulator issue? It's a known issue with Atari800WinPLus - it has only partially working emulation of 5200 buttons. Any other mystery to solve? There's a similar easter egg in the 8-bit Ballblazer - maybe you could check if it exists in the 5200 version? It's got to be in there. The levels are 1-9. So some kind of combination. Allan That wasn't too difficult to find! You must press keys 1, 6, 7, 2, 9, 4, 3, 8 to trigger hidden credits at the same moment as is described in 8-bit version. Just be fast! Please test it on real HW. F. Edited March 13, 2010 by _Fandal_ Quote Link to comment Share on other sites More sharing options...
+Allan Posted March 13, 2010 Share Posted March 13, 2010 Does it works the same way on real HW or is it just some emulator issue? It's a known issue with Atari800WinPLus - it has only partially working emulation of 5200 buttons. Any other mystery to solve? There's a similar easter egg in the 8-bit Ballblazer - maybe you could check if it exists in the 5200 version? It's got to be in there. The levels are 1-9. So some kind of combination. Allan That wasn't too difficult to find! You must press keys 1, 6, 7, 2, 9, 4, 3, 8 to trigger hidden credits at the same moment as is described in 8-bit version. Just be fast! Please test it on real HW. F. I did it really fast but nothing. What did you have the other settings on? Did you just start the game and waited for the playfield to appear? Allan Quote Link to comment Share on other sites More sharing options...
_Fandal_ Posted March 13, 2010 Author Share Posted March 13, 2010 Does it works the same way on real HW or is it just some emulator issue? It's a known issue with Atari800WinPLus - it has only partially working emulation of 5200 buttons. Any other mystery to solve? There's a similar easter egg in the 8-bit Ballblazer - maybe you could check if it exists in the 5200 version? It's got to be in there. The levels are 1-9. So some kind of combination. Allan That wasn't too difficult to find! You must press keys 1, 6, 7, 2, 9, 4, 3, 8 to trigger hidden credits at the same moment as is described in 8-bit version. Just be fast! Please test it on real HW. F. I did it really fast but nothing. What did you have the other settings on? Did you just start the game and waited for the playfield to appear? Allan You must enter this sequence while credits "Ballblazer", "A Lucasfilm production", "Regulation Certified" are flashing. Entering secret code new message should appear. F. Quote Link to comment Share on other sites More sharing options...
Kr0tki Posted March 13, 2010 Share Posted March 13, 2010 Works for me, thanks! To be more precise: you have to start entering the code after the credits text _finished_ fading in, and you have to end before the text _starts_ fading out. So you really have around 2 seconds to enter the whole sequence. The same situation as in the 8-bit verison. After that, the programmer's names start appearing as one of the credit texts. Quote Link to comment Share on other sites More sharing options...
+Allan Posted March 13, 2010 Share Posted March 13, 2010 Thanks Krotki, It work! Two mysteries solved! Thanks again guys for all your help. Allan Quote Link to comment Share on other sites More sharing options...
