roland p Posted May 17, 2010 Share Posted May 17, 2010 How does 'hardly' and 'does not' equal a double negative? Hardly means at the very least a little bit = (positive), and does not means none = (negative). So they are not a double negative. And even if they were it is still completely permissable to use in writing. Yep, Main Entry: hard·ly Pronunciation: \ˈhärd-lē\ Function: adverb Date: before 12th century 1 : with force : vigorously 2 : in a severe manner : harshly 3 : with difficulty : painfully 4 a —used to emphasize a minimal amount <I hardly knew her> <almost new — hardly a scratch on it> b —used to soften a negative <you can't hardly tell who anyone is — G. B. Shaw>5 : certainly not <that news is hardly surprising> usage Hardly in sense 5 is used sometimes with not for emphasis <just another day at the office? Not hardly>. In sense 4b with a negative verb (as can't, wouldn't, didn't) it does not make a double negative but softens the negative. In “you can't hardly find a red one,” the sense is that you can find a red one, but only with difficulty; in “you can't find a red one,” the sense is that red ones are simply not available. Use of hardly with a negative verb is a speech form; it is most commonly heard in Southern and Midland speech areas. In other speech areas and in all discursive prose, hardly is normally used with a positive <you can hardly find a red one>. Quote Link to comment Share on other sites More sharing options...
