stilth60050 Posted May 6, 2010 Share Posted May 6, 2010 Do the 7800 home brew games of Bqn and burgertine have different lay outs at different levels like the arcade games? It does not show on the screen shots. Quote Link to comment Share on other sites More sharing options...
HammR25 Posted May 6, 2010 Share Posted May 6, 2010 Yes Quote Link to comment Share on other sites More sharing options...
Underball Posted May 6, 2010 Share Posted May 6, 2010 Beef Drop/Burgertime has all the original Arcade levels, and then a few more custom levels I believe. Quote Link to comment Share on other sites More sharing options...
kenfused Posted May 7, 2010 Share Posted May 7, 2010 (edited) Beef Drop has all 6 of the original arcade boards (and 4 extra boards that can optionally be activated). There is very slight vertical compression of a row or two from the arcade screens. This mostly affects the one board that has a lot of rows with a burger part on each since IIRC i had to do one less row than the arcade did. There are also no onions on Beef Drop burgers (they have been replaced with another ingredient) For b*nQ, IIRC the arcade had two difficulty level settings, and in expert mode the board levels are different. b*nQ only follows the arcade normal difficulty board progression. I did attempt to get board colors and the enemy/ball order to match the arcade as close as I could. I had hoped to support the arcade expert level board order and add FHMC b*nQ support, but then it would never have been finished. A character from FHMC can be activated through an easter egg though --Ken Edited May 7, 2010 by kenfused Quote Link to comment Share on other sites More sharing options...
stilth60050 Posted May 7, 2010 Author Share Posted May 7, 2010 thank you for the details, i'm glad 7800 is staying alive, thank you for new games. Quote Link to comment Share on other sites More sharing options...
